    DuetWiFiFirmware minor release 1.15c
    Firmware installation
    11
    79
    12.2k
    • curieosundefined
      curieos
      It seems you changed the way the E endstops work (using them for FSR board). I no longer have to have a jumper to change it to NC. Almost had an issue during a print just now.
      She/Her
      I work at a local 3D printing shop.
      Printers: Micron+ w/Duet 3 Mini, in-progress adaptation of the Jubilee REL onto an E3D MS, Prusa i3 MK3S.
        No, I haven't made any changes in that area.
        • curieosundefined
          curieos
          Then I'm not quite sure what happened. I made a print two days ago with auto calibration and it worked fine. I then loaded the new firmware yesterday, started another print, and it wasn't probing the bed anymore since it was already triggered. I didn't make any changes to my config file other than to adjust for the z offset.
          She/Her
          • curieosundefined
            curieos
            After a restart the behavior has reverted back to normal. Not sure what caused it.
            She/Her
            • Toddimusundefined
              Toddimus
              I just had the same problem with the FSR sensors (JohnSL board). With 1.15c when I try an auto bed calibration on my delta, it says the endstops are already triggered. No hardware change. Reverted back to 1.15b and it works again. I tried rebooting the duet wifi, but that didn't help.
              I do have a 17 point bed.g file. 10 points on perimeter and 6 points halfway in and one in the center. Don't know if that matters.
              I do have the jumper on the JohnSL board to make the board look like (I think) a normally closed switch. This didn't get changed between firmware.
              Not sure why but it is something different in 1.15c.
              • Sakeyundefined
                Sakey
                Having the same problem, going from 1.15b to 1.15c . Worked fine with 1.15b but 1.15c bring up " Z probe warning: probe already triggered at start of probing move" .
                  Those of you who are having Z probe trouble going from 1.15b to 1.15c, what probe type do you have set in M558, and how do you have the probe connected?
                  • Sakeyundefined
                    Sakey
                    Mines connected 3x fsr to JohnSL board to the duet via e0 endstop I think. Set at 4 on m558.
                    Worked fine in 1.15b, upgraded to 1.15c no longer working so downgraded again and back up and running. Hope that helps DC!
                    • Toddimusundefined
                      Toddimus
                      Mine is connected to the E0 endstop.
                      Jumper on JohnSL board is set for NC
                      M558 P4 X0 Y0 Z0
                      M574 X2 Y2 Z2 S0 // hall effect switches at the top of each delta tower
                      G31 X0 Y0 Z0 P500
                      Thanks DC
                      • sgaundefined
                        sga
                        Do you ever sleep?Thx for the update!!!
                        • lignumaquaundefined
                          lignumaqua
                          Not sure if this is a Duet WiFi firmware issue, or chrishamm's web page. Running 1.15c with web interface 1.12 on a brand new Duet WiFi on a brand new CoreXY. All is working fine, very quiet and no problems! 🙂
                          Very minor issue, the web page always reports that the build has 500 layers, no matter how many there really are. (This model actually has 236 layers.)
                          EDIT: The root cause is likely that the model height is incorrect
                          Always comes through as 100mm.
                            deckingman
                            I seem to remember reading something somewhere about the firmware finding the object height by reading the last G1 Z command in the gcode file. If you have a G1 Z at the end of your print to lift the head, that can screw it up. You can still lift the head but use G0 instead of G1 (does the same thing I think).
                              lignumaqua
                              @deckingman:
                              Aha! Thank you, that is precisely the problem. I have a G1 Z100 in my ending script. I'll change that to G0 Z100.
                                A workaround for that is to put a comment starting with upper case E on the end of that G1 line. I'm not sure that using G0 instead of G1 will make any difference.
                                  deckingman
                                  Found where I'd read that about G0 - it was here https://miscsolutions.wordpress.com/2014/06/11/five-tips-for-using-dc42-firmware-on-the-reprappro-ormerod/. No offence intended but if G0 doesn't work, maybe you should amend you blog David.
                                    lignumaqua
                                    Using G0 fixed the problem. Many thanks for the help.
                                    • Toddimusundefined
                                      Toddimus
                                      @dc42:
                                      Any more thoughts on this issue?
                                      I know you are quite busy, and hopefully have a life outside 3D printing, so I understand any delay. 🙂
                                        Sorry I won't be able to look at this for several more days. I've already looked at the code changes in 1.15c and I didn't find anything to explain it.
                                        If you wish, you could try connecting the fsr board to the Z probe connector instead of E0 and use probe type 5.
                                        • guywinslowundefined
                                          guywinslow
                                          Just code my board in the mail 1 week ago. had to print a Case. Got wired and mounted today.
                                          Improvements:
                                          Stepper control vast improvement.
                                          Temperature control wall much stabler, terns off when the gcode changes the temperature wall its printing.
                                          Working on reproducing it right now
                                            guywinslow
                                            OK, Cant reproduse
