    Files uploaded over FTP occasionally blank
    1.4k
    • wilrikerundefined
      wilriker @Phaedrux
      @phaedrux How many files were you uploading in a row and how large are they in average? That might be relevant for reproduction.
      Manuel
      My Tool Collection
        Phaedrux Moderator @wilriker
        @wilriker they were the macro files for the firmware retraction tuning I just posted. So there was at least a dozen in the directory I first noticed on. About 15 bytes each. Also happena when uploading a single file.
        • wilrikerundefined
          wilriker @Phaedrux
          @phaedrux OK. Never used FTP to upload anything to Duet yet. I actually did upload 400 macro files (as part of my stand-still-noise-reduction-testing) as scripted curl uploads via HTTP and had no issues at all this way.
          Manuel
          My Tool Collection
          • Googliolaundefined
            Googliola
            I have the very same issue. Files are sometimes empty on duet despite successful transfer.
            Filezilla 3.36.0 on Windows 8.1 x64
            Firmware Electronics: Duet WiFi 1.02 or later + DueX5
            Firmware Version: 2.01(RTOS) (2018-07-26b2)
            WiFi Server Version: 1.21
            Web Interface Version: 1.21.2-dc42
            • token47undefined
              token47
              I upload ALL files by FTP every time I do a config change (I edit on the PC and batch upload them every time). I can say I uploaded a few hundred times now, and I've never seen this problem of empty files. Just weighting in for statistics.
                Phaedrux Moderator @token47
                @token47 try uploading these macros. There's thousands of files. At first it looks like they all go through but when you refresh the directory you see 0k file sizes.
                https://forum.duet3d.com/topic/6181/tuning-macros-menus-accel-jerk-retraction-pressure-advance
                • wilrikerundefined
                  wilriker @Phaedrux
                  @phaedrux said in Files uploaded over FTP occasionally blank:
                  I did that and I just checked (all directories... I hope you created them via script 😉 ) and there are no zero-length files. So it worked for me.
                  I used ncftp to upload from command line.
                  Manuel
                  My Tool Collection
                    Just tested uploading again. Same thing. Most of the files are 0k after refreshing.
                    Weird.
                    • wilrikerundefined
                      wilriker @Phaedrux
                      @phaedrux Have you tried doing it with ncftp? Maybe it does some extended error checking. Just guessing though.
                      Manuel
                      My Tool Collection
                        @wilriker said in Files uploaded over FTP occasionally blank:
                        ncftp
                        No, but I'll give that a shot. I've been using FileZilla as that's what's recommended. I'm on a Mac as well, so not sure if that's factoring into it or not. FTP should be agnostic though.
                        • wilrikerundefined
                          wilriker @Phaedrux
                          @phaedrux Due to some technical issues at the time of uploading I was unable to use FileZilla and had to work around using a command line tool. Default ftp does not support recursive directory upload, so I looked around and found ncftp. That's why I used it.
                          Manuel
                          My Tool Collection
                          • DonStaufferundefined
                            DonStauffer
                            I've tried FTP with FileZIlla on the Duet 2 WiFi with firmware 2.03, 2.05.1, and 3.2.2. I get randomly truncated directory listings (missing files), truncated filenames, and truncated files (it seems to copy the file up to a point and then stop).
                            I've concluded that FTP on the Duet 2 WiFi is not currently working.
                              Phaedrux Moderator @DonStauffer
                              @donstauffer What settings do you have set in your FTP client?
                              • Phaedruxundefined Phaedrux referenced this topic
                              • fcwiltundefined fcwilt referenced this topic
