    Files uploaded over FTP occasionally blank
    1.4k
      Phaedrux Moderator @wilriker
      @wilriker they were the macro files for the firmware retraction tuning I just posted. So there was at least a dozen in the directory I first noticed on. About 15 bytes each. Also happena when uploading a single file.
      • wilrikerundefined
        wilriker @Phaedrux
        @phaedrux OK. Never used FTP to upload anything to Duet yet. I actually did upload 400 macro files (as part of my stand-still-noise-reduction-testing) as scripted curl uploads via HTTP and had no issues at all this way.
        Manuel
        My Tool Collection
        • Googliolaundefined
          Googliola
          I have the very same issue. Files are sometimes empty on duet despite successful transfer.
          Filezilla 3.36.0 on Windows 8.1 x64
          Firmware Electronics: Duet WiFi 1.02 or later + DueX5
          Firmware Version: 2.01(RTOS) (2018-07-26b2)
          WiFi Server Version: 1.21
          Web Interface Version: 1.21.2-dc42
          • token47undefined
            token47
            I upload ALL files by FTP every time I do a config change (I edit on the PC and batch upload them every time). I can say I uploaded a few hundred times now, and I've never seen this problem of empty files. Just weighting in for statistics.
              Phaedrux Moderator @token47
              @token47 try uploading these macros. There's thousands of files. At first it looks like they all go through but when you refresh the directory you see 0k file sizes.
              https://forum.duet3d.com/topic/6181/tuning-macros-menus-accel-jerk-retraction-pressure-advance
              • wilrikerundefined
                wilriker @Phaedrux
                @phaedrux said in Files uploaded over FTP occasionally blank:
                I did that and I just checked (all directories... I hope you created them via script 😉 ) and there are no zero-length files. So it worked for me.
                I used ncftp to upload from command line.
                Manuel
                My Tool Collection
                  Just tested uploading again. Same thing. Most of the files are 0k after refreshing.
                  Weird.
                  • wilrikerundefined
                    wilriker @Phaedrux
                    @phaedrux Have you tried doing it with ncftp? Maybe it does some extended error checking. Just guessing though.
                    Manuel
                    My Tool Collection
                      @wilriker said in Files uploaded over FTP occasionally blank:
                      ncftp
                      No, but I'll give that a shot. I've been using FileZilla as that's what's recommended. I'm on a Mac as well, so not sure if that's factoring into it or not. FTP should be agnostic though.
                      • wilrikerundefined
                        wilriker @Phaedrux
                        @phaedrux Due to some technical issues at the time of uploading I was unable to use FileZilla and had to work around using a command line tool. Default ftp does not support recursive directory upload, so I looked around and found ncftp. That's why I used it.
                        Manuel
                        My Tool Collection
                        • DonStaufferundefined
                          DonStauffer
                          I've tried FTP with FileZIlla on the Duet 2 WiFi with firmware 2.03, 2.05.1, and 3.2.2. I get randomly truncated directory listings (missing files), truncated filenames, and truncated files (it seems to copy the file up to a point and then stop).
                          I've concluded that FTP on the Duet 2 WiFi is not currently working.
                            Phaedrux Moderator @DonStauffer
                            @donstauffer What settings do you have set in your FTP client?
                            • Phaedruxundefined Phaedrux referenced this topic
                            • fcwiltundefined fcwilt referenced this topic
