    Duet Web Control wishlist notes and priorities
    32
    116
    19.1k
    • sigxcpuundefined
      sigxcpu
      I have two issues with DWC:
      • an old one, that controls for extrusion multiplier and speed multiplier are not working on iPhone (maybe iOS in general). If you click, sometimes the slider jumps to max, sometimes jumps to the position you clicked. Dragging does not work.
      • the down arrow history in G-code console was very handy for portable devices. The question mark for help, not so much 🙂
      LE: removed the rememberedGcodes.indexOf issue because I've read above about the wrong settings.
      • resamundefined
        resam
        @chrishamm the webcam rotation is still not working properly...
        When I change it, it is rotated correctly.
        But once I close the browser tab or reload the page, the rotation setting is lost.
        • Sir printsalotundefined
          Sir printsalot @chrishamm
          @chrishamm
          can't get around java script gcode is not a function/disconnect. Any entry in gcode field sets it off. I have performed a fresh boot load install 2.01 rtos and dwc 1.22. I erased gcode folder and am using a desktop that hasn't uploaded or connected to board in the past. It persist. I have separated every variable that could cause it on my end. It is something I can't figure out. My bl touch probe works some of the time, but not all and board will start a print via upload ignoring g28 altogether. I have no m code in my config.g to allow movement before printer is homed. Homing button indicate machine not homed but it just start run print. reset factory default,apply setting reflects not diff.
          RepRapFirmware for Duet 2 WiFi/Ethernet
          Firmware Electronics: Duet Ethernet 1.02 or later
          Firmware Version: 2.01(RTOS) (2018-07-26b2)
          Web Interface Version: 1.22
          M111 S0 ; Debugging off
          G21 ; Work in millimetres
          M555 P1 ; Set firmware compatibility to look like RepRapFirmare
          G31 X-52 Y50 Z.9 P25
          M208 X0 Y-21 Z0 S1 ; Set axis minima
          M208 X305 Y291 Z247 ; Set axis maxima
          M574 X1 Y1 S1 ; Set active low endstops
          M574 Z0
          M558 P9 X0 Y0 Z1 H5 F100 T2000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
          G31 P600 X0 Y12 Z.96; Set Z probe trigger value, offset and trigger height
          M557 X52:300 Y60:335 S40 ; Define mesh grid
          M550 Pfamily's printer ; Set machine name
          M540 PBE:EF:DE:AD:FE:ED ; Set MAC address
          M552 P192.168.1.10 S1 ; Enable network and set IP address
          M553 P255.255.254.0 ; Set netmask
          M554 P73.214.152.1 ; Set gateway
          M586 P0 S1 ; Enable HTTP
          M586 P1 S0 ; Disable FTP
          M586 P2 S0 ; Disable Telnet
          I use netgear nighthawk 7800r router
          with ethernet connection speed 431 mb/sec speed test
          firefox61.0.2/64bit
          win 10/64 bit version 1709 build 16299.431
          amd fx 8320 8 core 3.5ghz
          no usb connection 24 v psu
          • chrishammundefined
            chrishamm administrators
            Do the same problems persist in DWC 1.22.1? It is part of David's latest firmware release.
            Duet software engineer
            • resamundefined
              resam
              @chrishamm I just tested your latest 1.22.2 release from an hour ago.
              Still the same issue. The webcam rotation gets reset to 0° after a page reload.
              kuhnikuehnastundefined 1 Reply Last reply Reply Quote 0
              • resamundefined
                resam
                @chrishamm actually, I just checked the browser local storage, and it still shows the correct setting. But it seems it doesn't get loaded or applied to the iframe properly.
                When I set the rotation to 180, and click "Apply Settings", the img tag gets a new class="rotate-180" option.
                When I reload the page, this is missing, although the localStorage contains a valid json setting.
                edit:
                When I load the page, and use the dev tools in my browser at https://github.com/chrishamm/DuetWebControl/blob/a5a74e5335ff6a15279247dedf276ab2694a5d56/core/js/settings.js#L217
                settings.webcamRotation is 0,
                getLocalSetting("settings", null); returns the correct rotation setting.
                I think the issue is here: https://github.com/chrishamm/DuetWebControl/blob/a5a74e5335ff6a15279247dedf276ab2694a5d56/core/js/settings.js#L121
                >  settings["webcamRotation"].constructor
                <- Æ’ Number() { [native code] }
                >  loadedSettings["webcamRotation"].constructor
                <- Æ’ String() { [native code] }
                string vs. integer
                edit again:
                YES! I manually changed my localStorage settings from webcamRotation: "180" to "webcamRotation:180` and now it works.
                • kuhnikuehnastundefined
                  kuhnikuehnast @resam
                  @resam said in Duet Web Control wishlist notes and priorities:
                  Where did you get the 1.22.2 release from? Could only find the 1.22.1?
                  resamundefined 1 Reply Last reply Reply Quote 0
                  • resamundefined
                    resam @kuhnikuehnast
                    @kuhnikuehnast on the dev branch: https://github.com/chrishamm/DuetWebControl/blob/dev/DuetWebControl-1.22.2.zip
                    • Agniusmundefined
                      Agniusm
                      @chrishamm
                      I see new DWC but no download/upload button on mobile devices still.
                      Is it that hard to get them enabled on mobile version as this is turning out to be major pain in the a..
                      Anyway, any plans?
                      • r123undefined
                        r123
                        I can never remember the appropriate github page to check for new firmware.
                        It would be great if in Webcontrol Settings/General/Software_Information there was a direct link to this page.
                        (The page linked to would of course adapt according to the Firmware Electronics detected.)
                        Thanks!!
                          @Agniusm It's fixed now, please try out https://github.com/chrishamm/DuetWebControl/blob/dev/DuetWebControl-1.22.4-b1.zip To everyone else: This is still a BETA version so there may be some bugs in it! Use at your own risk!
                          @resam Thanks for tracking it down. AFAIR I introduced a comparison of the constructors when the settings are loaded a while back, so could you check if this issue is resolved now? At least when testing on my machine it seems to be alright.
                          @r123 Usually dc42 includes my latest stable DWC version in his firmware releases and in case you wish to get it from my own repository, I suggest you check the "Releases" tab. I publish my stable releases there, too. Clicking on my name on the Settings page of DWC will lead you to my GitHub page where you can find my DuetWebControl repo.
                          • genghisnico13undefined
                            genghisnico13
                            Would it be possible to add the possibility to select multiple files and move them? Right now you can achieve the same functionality by downloading to the PC, deleting the files on the duet and uploading to the desired folder. Since there is a workaround it's not a priority, but I think it would be a nice feature to have.
                            And perhaps showing the free space of the SD card somewhere in the G-Code Files section? I know you can see it with M39.
                            One small detail I found, in the Machine Properties section if you have a type 9 probe (BLTouch) it shows as Type "Unknown (9)", I am running version 1.22.3, in case you have already fixed it in a newer release.
                            • wilrikerundefined
                              wilriker @genghisnico13
                              @genghisnico13 said in Duet Web Control wishlist notes and priorities:
                              That's already possible. Select them via the checkboxes and then drag'n'drop them to the folder you want to move them. To go up you can use the location above the file list.
                              Manuel
                              My Tool Collection
                              genghisnico13undefined 1 Reply Last reply Reply Quote 1
                                genghisnico13 @wilriker
                                @wilriker Thanks, didn't realize that.
                                • Agniusmundefined
                                  Agniusm
                                  Would be nice to have a print button on upload completion dialog box:
                                  Upload complete! and then <<Print>> <<Close>>
                                  Just found a button for that :D. Dismiss
