    Make use of variables
    Firmware wishlist
    14
    40
    6.8k
    • Danalundefined
      Danal
      There is no "right or wrong" answer to having (or not) variables in G-Code.
      At the same time, the NIST standards writers for G-Code chose "not". There is a fairly deep philosophy behind this: G-Code is/was intended to be a machine control language. It is philosophically not intended to be a programming language.
      Anyone who's coded, even the simplest languages, knows that programming languages that have conditional execution and variables can have many emergent behaviours. This is highly undesirable when controlling machines that can break themselves, break parts, and injure operators.
      G-Code is specifically limited to "deterministic" behaviors. Even allowing math on a single line is a bit debateable in this philosophy; it did make it into the final standard. Nonetheless, people tend to avoid it in truly deterministic G-Code.
      The assumption is that all conditional execution, repetition, etc. will be accomplished in the generator of the G-Code, not the G-Code itself.
      Again, no right/wrong here, but knowing the background philosophy may help explain why things that seem desirable in G-Code may have been intentionally excluded.
        This week I have been designing a mechanism for conditional and looping GCode with variables. I will publish the proposal soon.
        timcurtis67undefined 1 Reply Last reply Reply Quote 2
        • timcurtis67undefined
          timcurtis67 @dc42
          @dc42 said in Make use of variables:
          Sweet! I've been waiting for this feature.
          • SupraGuyundefined
            SupraGuy
            @Googliola : For what it's worth, this seems to be a collection of shell scripts and python code. There is a Windows port of bash to execute the shell scripts, and python can be run on just about anything. You MIGHT need to do some translation of some of the different locations and so forth, but I see little reason why this can't work in a Windows environment, if you're willing to put up with some teething pains and see what needs to be changed.
            @Danal : Certainly fair point, until you get things like configuration files and macros in a "gcode everywhere" the idea that the generator should be doing all of the work is a good one. In this case though since the configuration files, and presumably most of the macros are going to be (for the largest part) hand-coded, with the exception of things like the RepRap Configuration Generator, it gets to be a bit of a pain.
            I was thinking about the things that I was talking about above, and I realized that gcc includes a facility for running things through its preprocessor without trying to run them through the actual compile process. It throws certain errors, as it expects C/C++ style comments, and not ones with a semicolon prefix, but that isn't too hard to handle.
            So for example, I have a file test.h which contains the following:
            #define DEFAULTPROBE P8 H8 F780 I1 T9000 R0.8 Z1
            #define MESHGRID X30:190 Y35:235 S20
            #define PROBEOFFSETS X0.0 Y0.0 Z-0.1
            Then there's a file called manualprobemacro.c (The .c is just more convenient for the preprocessor)
            ; manualprobe.g manually define a mesh grid without needing to probe manually 90 times
            #include "test.h"
            M558 P0
            G31 X0 Y0 Z0
            M557 X35:185 Y25:250 S75
            G29
            M558 DEFAULTPROBE
            G31 PROBEOFFSETS
            M557 MESHGRID
            Then I run gcc -E manualprobe.c
            I get some returns from gcc on stderror, since this really isn't C code, but on stdout I get
            4 "manualprobe.c" 2
            M558 P0
            G31 X0 Y0 Z0
            G29
            M558 P8 H8 F780 I1 T9000 R0.8 Z1
            G31 X0.0 Y0.0 Z-0.1
            M557 X30:190 Y35:235 S20
            Now I can probably do something with awk to fix or remove things like the # comment lines. I can probably have it redirect the .c files to .g versions which can then be uploaded en masse to the macro directory. I can probably set up a makefile so that I can just do something like make macros.
            Maybe if I ever think that I'll have more than a dozen such macros, I might go through the trouble of setting it up.
            Lead screw driven printer, powered by Duet 2 Wifi
            MPCNC powered by Duet 2 Wifi
            CoreXY printer driven by Duet 3 6HC
            LowRider CNC powered by Duet 2 Wifi
              I've put a draft proposal at https://docs.google.com/document/d/1urmNjfs2QXUZ2aFeWu6LOaj78cyfNeYZ0ofMJoQsZVk/edit?usp=sharing. It's lacking some detail, in particular the object model, but it should be sufficient to use as a basis for discussion.
              wilrikerundefined 1 Reply Last reply Reply Quote 5
              • wilrikerundefined
                wilriker @dc42
                @dc42 I personally would already been happy with just variables. Anyway very good proposal.
                Only I found one thing missing. At the requirements you state that variables need to be type-safe but in their declaration the type is only inferred from the value (at least nothing is stated). It might be safer to have the declaration include the type. But I know that these makes it more complicated and inconvenient.
                Manuel
                My Tool Collection
                • Googliolaundefined
                  Googliola
                  @dc42 I haven't had time to properly review your proposal yet - will do over the weekend. First of all: Wooooohooo, you are the most responsive dev I have met so far. Big up for your effort!!!! And in contrast to (an-)other dev of hard- & firmware, you are super friendly and quick at solving customer needs! I feel like I found the right place to base my printer kit on!
                  At first sight, I would kind of stick to the Gcode-everywhere paradigm, when it come to the simplest of all - setting and reading a variable. But as I can't read your mind πŸ‘¨β€πŸŽ“ but suspect that the RRF object model you have in mind is separate from the Gcode processor (or for any number of another reasons), the var approach seems to be unnecessarily stray from your paradigm.
                  Maybe M123 Kkeyname Vvalue is a better approach? Where KeyName could be retrieved by just adding a designator like @ or $?
                  Also, M123 could be extend by the data-type such as M123 KmyInt V3.1412 Dfloat would be reflected?
                  On another page, but related: In terms of usability of a specific product (like the e3d tool-changing printer), it would be tremendeously helpful to be able to read the current setting of commands like M558, M584 and the like by issueing a M558 A? (and get the value of A back) or M558? to get the values of all parameters back (either as string or as a named array - preference for the latter of course πŸ˜‰ )
                  One major use-case is the way you could set your z-probe offset with G31 Z$measuredZmean
                  The way I do it now is by running @Phaedrux script he provided here but with the above suggestion, there would be no need to read the mean value in the console - just get the mean value, store the value by M123 KtriggerHeight VmeasuredZmean and set triggerHeight value by G31 Z$measuredZmean
                  Except for the paper-trick, no further manual action would be required....
                  Or think about how endstops could be used (again for tool-changing) if I had a simple microswitch, I could retrieve the state of and them take according action - like if T1 parked or is a tool loaded.
                    dc42 administrators @Googliola
                    @googliola, thanks for responding.
                    The object model is just a way of referring to all the machine parameters, so it's more or less independent of the syntax of the additional commands in my proposal.
                    One concern is readability. GCode isn't very readable because you need to remember what each code does. So for things like loops, conditional blocks etc. I think it makes more sense to use keywords. The question then arises, should we also use keywords for things like setting variables, for which there isn't an existing GCode command?
                    That will be possible, because all configuration variables will be included in the object model.
                    Yes, that or something similar will be possible.
                      Googliola
                      @dc42 how would you refer to the (M558) A param value in that case?
                      • M558. A
                        or
                      • parentObject.[otherObject].value
                      While the first is self-explanatory, the other might adhere to the OM, but would complicate things for the user and documentation (but maybe much easier to develop??)
                      I think using a Gcode is more user-friendly overall.
                      Again, I don't know much about the consequences in terms of the code or the HW restrictions (cpu, ram, performance etc.)
                      • tjb1undefined
                        tjb1
                        @dc42 I would say most of industry is accustomed to Fanuc Custom Macro B and might be a good standard to follow if you are looking for industry support.
                        Sometimes its a bit convoluted to do loops or proper if statements but it works. Something I use in my programs to calculate a loop variable based on a hole diameter is below
                        IF[#510NE#4115]THEN#3000=1(LOAD WORKSHIFTS) - #3000=1 is program ending alarm
                        IF[#504EQ0]GOTO7 - Will skip ahead in program to line N7
                        IF[#507EQ0]GOTO7
                        #100=.5
                        #101=.45
                        IF[#500GE#100]THEN#3000=1(ORDER HOLE TOO LARGE)
                        IF[#500GT.35]THEN#101=[#500+.1]
                        #102=#100-#101
                        #103=FIX[#102/.012](NUMBER OF PASSES ROUNDED DOWN)
                        #104=[#102MOD2](EVEN-ODD TEST)
                        IF[#104EQ0]THEN#105=#103+2(EVEN PASS)
                        IF[#104NE0]THEN#105=#103+1(ODD PASS)
                        #106=[#102/#105](NEW DEPTH OF CUT)
                        #105=#105/2(DOUBLE PASS SPLIT)
                        and then the while loop that uses it
                        #107=0
                        WHILE[#107LT#105]DO1
                        G1 U-[#106] F6.
                        Z-1.0
                        U-[#106] F1.
                        Z.0625 F6.
                        #107=#107+1
                        END1
                        #100-#199 variables are called common and are typically cleared at program end/reset, this can be changed on some machines by changing a parameter in the control
                        #500-#999 are maintained between programs and power cycles
                        #1000 and above are typically machine variables that can be read (and sometimes modified) but these are defined in the Fanuc Operation and Maintenance handbook for the control. On Fanuc 16i/18i/21i (and possibly more) #5021-#5028 will give you the machine coordinate for the respective axis (X, Y, Z, etc...) while #5041-#5048 will give you the workpiece coordinate for the respective axis. In the above sample #4115 is the currently loaded program number.
                        This is a good reference for Fanuc Custom Macro B that I use at work, it also goes pretty deep into bitwise operations available on Fanuc.
                          @googliola said in Make use of variables:
                          Something like: machine.zprobe.maxattempts
                          Googliolaundefined 1 Reply Last reply Reply Quote 0
                          • garyd9undefined
                            garyd9
                            In regards to the proposal...
                            There are currently several different "standards" for gcodes, but they are (for the most part) compatible with each other. I can usually take a basic gcode file that prints a cube and run it on any printer's firmware (or firmware specific preprocessor such as the case of sailfish) that supports gcode. 95% of the time, that gcode file will run fine. Even if a particular flavor of gcode doesn't support a specific command, it will usually recognize that it's not supported, spit out a warning, and continue.
                            This proposal isn't a case of adding some M commands that are specific to RRF (but could be safely ignored by other processors.) This proposal is a fundamental change in the gcode "language" while trying to still call it gcode. For example, I believe that gcode defines the "G1" command as one single linear movement (potentially in more than one axis.) With this proposal, however, that G1 command might be inside a loop (that only RRF understands) and really means to make one movement 2 times, 10 times, or a hundred times.
                            To add to the issue, there's no gcode command (that I know of) that could tell a gcode processor "don't run this file as it can't be compatible with you." I suppose you could have a header that includes a "M0" command wrapped with an always false conditional similar to:
                            if 1 = 0
                            M0
                            end if
                            If a gcode processor ignores any line it doesn't understand, it would only process the "M0" and stop. (Assuming it supports M0 to begin with. Not all gcode processors do.)
                            Anyway, to get to the point, I'd suggest NOT making changes to gcode that actually change the language. If you want to write a new language, then write a new language. Not only would this prevent compatibility issues (by assuring incompatibility) but would also free you from any constraints of trying to be gcode compatible when it clearly can't be.
                              I anticipate that the new features would be used almost exclusively in macro files that are used only on printers running RepRapFirmware.
                              garyd9undefined 1 Reply Last reply Reply Quote 0
                              • garyd9undefined
                                garyd9 @dc42
                                Then perhaps call it something else (RRF-Code or Duet-Code) with a different file extension and only allow it in macros. I realize that you have a certain expectation of competence of your users, but there's a large potential for something to go wrong when these machines are being used for laser cutters, CNC, etc
                                fmaundefined 1 Reply Last reply Reply Quote 0
                                  Googliola @dc42
                                  @dc42 From a user perspective, the terminology would cause confusion and additional and maintained documentation , but then the question is how much you weigh user-friendliness.
                                  If I were in your shoes, I would probably stick to ease and coherence with known / documented guidelines. You might open Pandora box here. People might argue that common (Fanuc) standards are 'better'. Comes down to taste at the end of the day really...
                                  • botundefined
                                    bot
                                    I really like your proposal, dc42.
                                    I have only one immediate use-case that I would want to employ: check current z height, and raise then lower bed to switch IDEX tools and avoid obstacles near the bed perimeter, if current z height is insufficient to clear said obstacles. This would have to be located in the actual print gcode files, in the tool switching script.
                                    I don't see any problem with doing this, based on your proposal, but just wanted to mention a use-case that would have the script inside a gcode file for printing.
                                    edit: Upon further reflection, these commands could be contained in the firmware-based macro tool change scripts. I was thinking of a case of using slicer based tool change scripts, but that would not be necessary. Ignore my stated use case of scripts in a printable gcode file.
                                    *not actually a robot
                                      Googliola
                                      @dc42 Haven't had much time lately to follow up on my feature request. With holidays ahead, this will change soon πŸ•Ί 🀞
                                      Just been wondering how the object model is coming along and if you could make a statement about when / what version it will be implemented.
                                      Thanks in advance
                                        Thanks in advance
                                        A small amount of the object model is supported in firmware 2.02RC5 along with variable substitution, as a proof of concept. The full implementation is planned for release 2.03.
                                        • fmaundefined
                                          fma @garyd9
                                          @garyd9 said in Make use of variables:
                                          Didn't follow this thread before... I agree with @garyd9: as no slicer will generate such custom G-Code, if the goal is to use it from macros, I suggest to write a macro language, like Slic3r does, evaluated by the macro pre-processor, and keep a standard G-Code.
                                          FrΓ©dΓ©ric
                                            The additional facilities will be provided by way of additional (not replacement) syntax and will not affect the ability of RRF to run GCode produced by slicers.
