    SD Card becomes unreadable after gcode upload attempt
    3.2k
      That does sound very unfortunate. Did it happen spontaneously, or are you aware of anything that might have triggered it, such as a short in the wiring?
      • CodonExeundefined
        CodonExe
        I smelled the smoke and quickly unplugged it, I am looking through everything now to see if I can find what went wrong.
        Rostock Max V2, Duet Wifi, IR Probe, PanelDue 7" LCD, Heated Enclosure, Firestop cans, Thermally Fused 12v E3D V6, Berd Air, Floating Thermally fused 24v Bed, Aluminum heat spreader, PEI, Dual 12v PSUs in series.
          I'll talk to T3P3 about replacing your board and PanelDue. We'll probably want the Duet WiFi back to try to diagnose what went wrong, so please don't replace any parts or clean off any burn marks.
          • CodonExeundefined
            CodonExe
            Ok I wont, thanks for looking into that!
              T3P3Tony administrators
              We will sort out a replacement of both and as David said it will be good to get your original ones back to diagnose what happened.
              • CodonExeundefined
                CodonExe
                You guys are great! Thank you!
                • Zesty_Lykleundefined
                  Zesty_Lykle
                  Hmm, My SD card is also showing the problem that I cannot write a new file to it.
                  Previously, I could switch off and rebooted, and was able to get access to the files back, and write new ones.
                  But now it will no longer accept print files. I can print files already on there, but if I try to write a new file I loose file management on the SD card, I cannot see any of my previously uploaded files.
                  I had made a backup image, had to use another SD card and it works again, now with the new card.
                  Now I have no more TV (SD card used was for Kodi)
                  At least I can print.
                  I will try formatting the old card and reusing it, just to see what happens.
                  Lykle
                  Design, make and enjoy life
                  Co Creator of the Zesty Nimble
                    Before you reformat it, you could try putting it in a PC and running disk tools to see if the file system has become corrupted.
                    • capundefined
                      cap
                      Anther sd card related question why are the boards shipped with a class 4 sd card is it worth the upgrade to class 10 are is the board limited to class 4 speeds also poeple ask for a sacred slot but I think a full size USB would be better for stick drives are full external hhd/ssd
                      warning brain may explode
                        The standard speed ratings are for writing data in the large chunks typical of a digital camera. In a 3D printer the chunks we can buffer up are much smaller, so Class 10 is not necessarily better than class 4 in this application. See http://forums.reprap.org/read.php?416,664836,664853#msg-664853.
