Bl-touch re-deploy after probing or z homing
5.0k
    BLV @Phaedrux
    @phaedrux
    M307 H3 A-1 C-1 D-1
    M558 P9 H5 F100 T6000
      bugm @dc42
      @dc42 said in Bl-touch re-deploy after probing or z homing:
      Is this on a Duet WiFi, Ethernet, or Maestro?
      i got the 1.01 - i erased the firmware and installed again 2.02RC2 from scratch - no difference.
      no idea what to do, replacing the wires made no difference.
      even while homing z axis alone, every 2-3 homing it keeps happening - after probing the pin deploys
      again while the bed moving down (core xy). it hits the glass before the bed went down, then retracts.
      just to check as @Blv - i installed it on my mks gen-l and it works without any issue.
        genghisnico13
        I've been having some problems with my 3D Touch (when it probes a hot bed), so I made a video to ask for a new one, is your probe behaving different from how its seen in the video?
        Sorry for the background noise around the middle, the power company is making some holes.
        undefined undefined 2 Replies Last reply 15 Oct 2018, 18:57 Reply Quote 0
          Phaedrux Moderator @genghisnico13
          @genghisnico13 How do you have the probe mounted? Your video makes it look like there is a bolt right above the top of the probe and it looks like it might be right beside a stepper motor? It uses an electromagnet and could be susceptible to pieces of metal being too close to it. If you take the probe out of the mount and just suspend it in the air and trigger it by hand, does it behave the same way?
          undefined 1 Reply Last reply 15 Oct 2018, 22:34 Reply Quote 0
            BLV @genghisnico13
            @genghisnico13 said in Bl-touch re-deploy after probing or z homing:
            Its almost identical, except that in my case its deploying the pin only one time after it already probed the point. (On your video its deploying even more).
              genghisnico13 @Phaedrux
              @phaedrux You could be right, but since the seller has already agreed to send me a new one.... I'll test it in mid air when the new one arrives (couple of months). Worst case I end up with 2 working probes.
              I assumed it was designed to be in close proximity to ferrous materials and put it in the only place with free space that doesn't limit movement length, could have been a bad choice, will see after testing.
                It's also worth remembering that high-current bed heaters can affect the trigger height of a BLTouch, although I've not heard of them causing the pin to redeploy. So if you are probing with the bed heater turned on, try turning it off, or add parameter B0 to the M558 command.
                undefined 1 Reply Last reply 16 Oct 2018, 14:00 Reply Quote 0
                  bugm
                  @dc42 Do you have any idea what should i do please?
                  I'm so frustrated and praying to the 3d printing god to get it work 😢
                    bugm @dc42
                    The heater is off always .
                      Please share your config.g, deployprobe.g and retractprobe.g files. Also run M115 to verify which firmware version is running, in case the firmware update failed.
                      undefined 1 Reply Last reply 17 Oct 2018, 15:06 Reply Quote 0
                        bugm @dc42
                        Thank you @dc42 🙂
                        M115:
                        FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02RC2(RTOS) ELECTRONICS: Duet WiFi 1.0 or 1.01 FIRMWARE_DATE: 2018-09-07b2
                        Here are my files:
                        config.g:
                        ; generated by RepRapFirmware Configuration Tool on
                        G90                                                ; Send absolute coordinates...
                        M83                                                ; ...but relative extruder moves
                        M667 S1                                            ; Select CoreXY mode
                        M550 PBugmBugm                                     ; Set machine name
                        M552 S1                                            ; Enable network
                        M587 S"********" P"********"                       ; Configure access point. You can delete this line once connected
                        M586 P0 S1                                         ; Enable HTTP
                        M586 P1 S0                                         ; Disable FTP
                        M586 P2 S0                                         ; Disable Telnet
                        M569 P0 S0                                         ; Drive 0 goes forwards
                        M569 P1 S0                                         ; Drive 1 goes forwards
                        M569 P2 S1                                         ; Drive 2 goes backwards
                        M569 P3 S0                                         ; Drive 3 goes backwards
                        M350 X16 Y16 Z16 E16 I1                            ; Configure microstepping with interpolation
                        M92 X200 Y200 Z400 E413.49                         ; Set steps per mm
                        M566 X720 Y720 Z12 E120                            ; Set maximum instantaneous speed changes (mm/min)
                        M203 X6000 Y6000 Z180 E1200                        ; Set maximum speeds (mm/min)
                        M201 X500 Y500 Z250 E1000                          ; Set accelerations (mm/s^2)
                        M906 X1600 Y1600 Z1600 E1600 I30                   ; Set motor currents (mA) and motor idle factor in per cent
                        M84 S30                                            ; Set idle timeout
                        M208 X-20 Y-20 Z0 S1                               ; Set axis minima
                        M208 X350 Y350 Z350 S0                             ; Set axis maxima
                        M574 X1 Y1 S1                                      ; Set active high endstops
                        M574 Z1 S2                                         ; Set endstops controlled by probe
                        M307 H3 A-1 C-1 D-1                                ; Disable heater on PWM channel for BLTouch
                        M558 P9 H5 F100 T7000                              ; Set Z probe type to bltouch and the dive height + speeds
                        G31 P25 X28.5 Y-5 Z0.86                            ; Set Z probe trigger value, offset and trigger height
                        M557 X15:285 Y15:285 S60                           ; Define mesh grid
                        M305 P0 T100000 B4138 C0 R4700                     ; Set thermistor + ADC parameters for heater 0
                        M143 H0 S100                                       ; Set temperature limit for heater 0 to 100C
                        M305 P1 T100000 B4138 C0 R4700                     ; Set thermistor + ADC parameters for heater 1
                        M143 H1 S260                                       ; Set temperature limit for heater 1 to 260C
                        M106 P0 S0 I0 F500 H-1                             ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                        M106 P1 S1 I0 F500 H1 T45                          ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                        M106 P2 S1 I0 F500 H1 T45                          ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                        M563 P0 D0 H1                                      ; Define tool 0
                        G10 P0 X0 Y0 Z0                                    ; Set tool 0 axis offsets
                        G10 P0 R0 S0                                       ; Set initial tool 0 active and standby temperatures to 0C
                        ; Automatic power saving
                        M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                        M564 H0                                   	   ; Let the Jog buttons work
                        ; deployprobe.g
                        ; called to deploy a physical Z probe
                        M280 P3 S10 I1	        ;deploy the probe.
                        G4 P200 	        ;delay 200ms.
                        ; retractprobe.g
                        ; called to retract a physical Z probe
                        M280 P3 S90 I1          ;retract.
                          I'm not sure about those G4 P200 commands in deployprobe.g and retractprobe.g. I'm not aware of other people using them. So I suggest you remove them and add parameter R0.2 to the M558 command instead..
                          undefined 1 Reply Last reply 18 Oct 2018, 05:20 Reply Quote 0
                            bugm @dc42
                            @dc42 it added the delay line only yesterday after someone suggested, but it not solved the problem.
                            i even upgraded to 2.02RC3 and problem still there.
                            does my config looks alright? any idea what more should i check?
                              My guess is that your clone behaves a little differently from a genuine BLTouch. You could try changing your deployprobe.g file to this:
                              M280 P3 S10 I1 ; deploy the probe.
                              G4 P200 ; delay 200ms.
                              M42 P3 S0 I1 ; stop sending the deploy command
                              undefined paul12undefined 2 Replies Last reply 4 Nov 2018, 10:12 Reply Quote 0
                                bugm @dc42
                                @dc42 I fixed the issue by switching to your mini IR module ☺
                                works great without any issue, Thanks
                                • paul12undefined
                                  paul12 @dc42
                                  @dc42 am facing the same issue, will try this method and inform the result
