    Heater faults with numerous different heaters and thermistors
    3.2k
    • Fodenundefined
      Foden @Phaedrux
      @phaedrux I've gone through about 1/2 a dozen heaters and thermisters and several heat blocks all with the same issue. I have LOTS of spares now. 😀 If i have the fan at full speed it fails - the link is obvious now but it wasnt until deckingman and dc42 pointed it out.
      My hot end assembly is a quick-removal type and I have tried 3 different versions of that, each with their own RJ45 pinvout board for cabling . It's definitely the fan cooling bouncing back onto the head/thermister.
      Last test for today is running with fan at 35%, i rotated the hotend 90o and its holding up way better than before. I also up'd the print speed to 200% to stress everything else, loose cables, PSU etc - all good so far
      Fodenundefined 1 Reply Last reply Reply Quote 0
      • Fodenundefined
        Foden @Foden
        @foden fan at 45%
        • Fodenundefined
          Foden @Foden
          @foden fan at 55% still holding temp
          • Fodenundefined
            Foden @Foden
            @foden hmmm, another thought struck me as I'm doing this test. My previous cooling,,that failed, was in steps of 25%. Now I'm doing it in 5% steps, possibly the fan fired up way too fast for the thermister to react? I'm at 75% currently - may try that tomorrow as I'm fed up of testing and its late 😉
            • Fodenundefined
              Foden @Foden
              @foden last one tonight. Fan at 100% with hot end rotated 90%. I think he issue was fan related but not quite what we thought. Will test tomorrow with the same setup i have now, but think the fan was firing up too fast for the thermister/heater to cope. As i have the fan running now at 100% and the temp is holding perfectly
                How did you have the fan set when running a PID tune?
                • Fodenundefined
                  Foden @Phaedrux
                  @phaedrux I think the fans where off, hot end and bed, when i was running autotune, which i see, now, would be another contributing factor
                  Will re-run autotine with fan on and see what happens
                  • Fodenundefined
                    Foden @Foden
                    @foden Update - bed fan would be off when i was running the hot end autotune. Hot end fan comes on automatically at 45C
                    • Fodenundefined
                      Foden @Foden
                      @foden Sooo, when previously running the H/E autotune without the bed fan i got a heater too powerful and dropped the power value. After Phedrux query i re-ran the autotune with the fan at 85% and on full power I did not get the over power warning. I had no idea the bed fan would have such an impact on the H/E. I don't have that issue with my Maker Select IIIP (almost completely rebuilt running on RAMPS 1.4)
                      I now need to design a shorter, or stronger fan duct that won't droop and make contact with the print. Trying a very short one just for now
                      Thanks again for all that read my ramblings and helped out!
                        If you can, print your duct in ASA or polycarbonate. Quite a bit more heat resistant.
                        • Fodenundefined
                          Foden @Phaedrux
                          @phaedrux Thanks Phaedrux, haven't printed with either of those - will take a look
                            Phaedrux Moderator @Foden
                            @foden ASA is close to ABS. Polycarbonate is another beast altogether.
                            • Fodenundefined
                              Foden @Phaedrux
                              @phaedrux As seems to be the way with all things 3d, find a fix for one issue and another pops-up. Just noticed my x carriage has a lovely crack in it :o(
                              Have to reprint and dismantle to get it replaced - sigh - oh well.....
                                Building a 3D printer is a never ending gift of projects.
                                • Fodenundefined
                                  Foden @Phaedrux
                                  @phaedrux LMAO - so true, so true my friend. I've learnt so many skills and other things I didn't know I needed to have that I can't believe I got this far in life without them 😎
                                  • Fodenundefined
                                    Foden
                                    Thanks again everyone, my DuetWifi and HEVO are back in sync. Have put back my BLTouch to replace the Orion as it was ticking me off, once i get some better prints I mat put it back.
                                    BLTouch is now dialed in and I just need to tweak the prints to stop extraneous links between parts - another self inflected issue I'm sure.
                                    Not replacing the cracked carriage until it fails completely - it's a royal PITA replacing it and setting up again IMHO
                                    Have made note to self that whenever I monkey around with the hotend and/or carriage I run an autotune, fan on fill, before i do anything else ;o)
