    sensorless homing on delta printer
    1.2k
    • chrisundefined
      chris
      Do the towers need endstops for sensorless homing on a delta printer?
        T3P3Tony administrators @chris
        @chris no - you home up to max on all three towers using the stall detection on the motors to stop at the top of the towers. For a delta it is highly recommended to use a Z probe for calibration. this is particularly true if you are using sensorless homing. See:
        https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing#Section_Limitations
        • chrisundefined
          chris
          cheers tony, i have the smart effector is this ideal to use as a z probe?
            @chris yes!
            • Danalundefined
              Danal
              Personal opinion: Specifically on a Delta, eliminating $6 to $10 worth of switches and wire is a very poor tradeoff to the imprecision of stall-detect endstops.
                T3P3Tony administrators @Danal
                @danal I agree if you do not probe before every print. If you are happy to run a probing routine before every print then its fine.
                Danalundefined 1 Reply Last reply Reply Quote 1
                • Danalundefined
                  Danal @T3P3Tony
                  @t3p3tony said in sensorless homing on delta printer:
                  Good point. Probing makes the absolute endstop-bed relationship irrelevant.
