Your Duet rejected the HTTP request: page not found
Firmware installation
20.4k
    elmoret
    The LEDs near the drivers are to indicate endstop status, not stepper motor power. I would recommend reading the documentation:
    https://duet3d.dozuki.com/
      sleepless
      none of the leds come on except the vin
        sleepless
        i will just have to give in to duets engineering oversight and change my fans to 5v. there should be a big clear note on when buying this board. Also right now i need help with the motor problems
        undefined 1 Reply Last reply 25 Oct 2018, 17:02 Reply Quote 0
          sleepless
          can i get a direct line with support please. the forum response time is too slow for me
          undefined 1 Reply Last reply 25 Oct 2018, 17:03 Reply Quote 0
            T3P3Tony administrators @sleepless
            @sleepless ypou do not need to change the fans to 5V - as has been mentioned previously you can set them to VIN or 5V.
            VIN can be between 12V and 24V, either 12V or 24V are the most common.
            when you say none of the LEDs come on other than VIN, looking at step 6 here:
            https://duet3d.dozuki.com/Guide/2.)+Wiring+your+Duet/9#s27
            are the 5V and 3.3V LEDS not lit? in which case there may be no 5V present. Have you set it to use external 5V? the default is internal 5V, set but a jumper marked 5V EN, next to the Fan voltage select jumper:
              @sleepless said in Your Duet rejected the HTTP request: page not found:
              We do not provide phone support I am afraid. It would make the cost of the hardware prohibitive for most people.
                sleepless
                oh ok i was supposed to leave the existing jumper and add the otherthanks for clearing that up i will try again
                undefined 1 Reply Last reply 25 Oct 2018, 17:37 Reply Quote 0
                  @sleepless Yes, the board should have come with a jumper on V_Fan selector and on 5V EN, did it not? where did you get the board from?
                    sleepless
                    ok now everything lights up proper thank you
                      sleepless
                      I am connecting the duet2 wifi to my robo3d r1 plus and the and am having issues with the z a y motors.not working. I am looking over my crimp jobs now
                        sleepless
                        Where do i connect the led lights?
                        undefined 1 Reply Last reply 25 Oct 2018, 20:30 Reply Quote 0
                          @sleepless which LED lights?
                          worth working through this documentation:
                          https://duet3d.dozuki.com/Wiki/Step_by_step_guide
                            sleepless
                            Im not tech savvy like that and dont understand what alot of that is talking about. Is there a problem with using the motors from the robo r1 plus?
                            undefined undefined 4 Replies Last reply 25 Oct 2018, 20:45 Reply Quote 0
                              sleepless
                              i hate this whenever i turn off/on the board the network has a hard time rediscovering it. Is there a work around for this?
                                sleepless
                                can i please get a direct line with a support member this forum takes way too long
                                  Phaedrux Moderator @sleepless
                                  @sleepless The Robo3D R1 has a metal enclosure doesn't it? Where do you have the Duet installed? The printer enclosure could be interfering with the wifi signal.
                                  See here to try and trouble shoot your wifi connectivity
                                  https://duet3d.dozuki.com/Wiki/WiFi_disconnections_and_AJAX_timeout_errors
                                    How can you expect to use this printer if you can't be bothered to read up on how it works?
                                      You'll need to know the specs of those motors. Check for a model number if the manufacturer hasn't given you any information. At the minimum you need to know the rated current they can handle, and then set the duet to use about 70-85% of that. So if the motors are 1500ma, set the current to 1000ma to 1200ma
                                      https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors
                                      undefined 1 Reply Last reply 25 Oct 2018, 20:52 Reply Quote 0
                                        sleepless
                                        Well every other 3d printer company offers support and I can spend time chatting with them learning about their machines. And recieve normal troubleshooting help and not have to use a forum to wait for a response. I know how my printers work. I know how the fw works, but this is another level of knowledge, and I am admitting my ignorance and requesting someone to take me by the hand and walk me through this like any other companies support would do if requested of them.
                                        undefined undefined 2 Replies Last reply 25 Oct 2018, 20:54 Reply Quote 0
                                          sleepless @Phaedrux
                                          @phaedrux ok i will call robo3d and get the information thank you
                                          undefined 1 Reply Last reply 25 Oct 2018, 20:57 Reply Quote 0
                                          21 out of 178
