Firmware 2.02 Release candidate 3 now available
I hadn't thought much about this, but I'm seeing something similar.
Baby steps are configured as 0.05mm, but I'm not seeing any effect on the machine. It changes the compensation factor on the DWC, (I had it showing up to a full 3mm of compensation at one point) but it didn't move the Z axis motors at all, so far as I could see.
My last few prints, I just stopped using it, because I thought that it might be something in my Z speed/acceleration settings not letting it get started for such a small move.
This started when I upgraded to 2.02RC2, still happening with RC3, however I also changed my Z lead screws when I upgraded to 2.02RC2 from 5mm/0.8mm lead to 8mm/8mm lead (4000 steps/mm to 400 steps/mm.) I had assumed that it had to do with the change in lead screws. I don't have those values from my config.g in front of me at the moment.
@garyd9
Default change is .05mm and it does say its changed. Usually I change this value from .25 to .35. After a 5 point calibration, start a print, change this Z level to around .25 / .35 to get a good squish going.
Usually stays pretty close to that initial adjustment after many 5 point calibrations until I power off/on again. And then I have to make this adjustment again.Right now when I push the button - or + no changes are made, and as such, my prints don't always stick. This was working a 2 days ago. Appears like it stopped a day or two after I installed beta 3. I don't reboot the machine often so I may have rebooted it for the first time after installing the beta, but emergency stopping a print or something, that started this issue... Just saying that possible. Will reboot again when I get home. If that doesn't fix it will reinstall the current beta and if that doesn't help may reinstall beta 2 to confirm, as it was working for me.
Thanks
WARNING: What follows is a WAG. Well, and educated WAG, but still a guess.
I wonder what the actual gcode DWC is sending - in particular if its actually sending a M290 R0 or M290 R1.
I wonder this because there's a commit that appears to be functionally different for R0. Previously, it would call PushBabyStepping(val - current). Now it's calling PushBabyStep(val)
I really don't understand the code I'm looking at, and my initial impression is that this change fixes a bug where the absolute mode (R0) was doing relative changes instead of absolute changes.
The only change made to baby stepping in RRF 2.03RC3 is to remove the limit of +/-1mm change when using absolute mode.
Old code:
const bool absolute = (gb.Seen('R') && gb.GetIValue() == 0); float difference = (absolute) ? fval - currentBabyStepZOffset : fval; difference = constrain<float>(difference, -1.0, 1.0); currentBabyStepZOffset += difference;
New code:
const bool absolute = (gb.Seen('R') && gb.GetIValue() == 0); float difference; if (absolute) { difference = fval - currentBabyStepZOffset; currentBabyStepZOffset = fval; } else { difference = constrain<float>(fval, -1.0, 1.0); currentBabyStepZOffset += difference; }
Like I said (typed...)
@garyd9 said in Firmware 2.02 Release candidate 3 now available:
For some reason when I was staring at the diff, it wasn't clicking in my head and I wanted to be clear about that when I posted. I had intended to followup when I got home, but I'm married with children. (I think that explains everything.)
I did see some weirdness with babystepping last night myself, but that was a case of the paneldue reporting an offset of 0.00 while DWC was reporting -0.02. I think DWC was correct, but it's very difficult to measure 0.02mm while the nozzle is moving.
You can see what DWC is sending the Duet by opening the Developer Tools for your browser (usually F12), select the Network tab and then click any of the buttons and you'll see something along the lines of http://ip_address/rr_gcode?gcode=
@garyd9
I would expect it to be impossible (or close to) to measure those small changes. I just print and change it during that first layer and see the difference. But even changing it 1mm + or - doesn't do anything anymore. And that should make big obvious changes to the print.
I am back to recalibrating Z with every power on (before I discovered the baby stepping button). Not a big deal, just takes more time.Thanks for looking into this.
Hi, I have a problem when running G29 to probe the bed. For some reason the moving speed between probe point it's extremely slow. I have M558 P9 H3 F100 T2000, but no matter what T value I put, it always moves at 1.7mm/s.
It was working fine last time I used it, and I sincerely don't remember to have modified anything else (but perhaps I did...)
Any clue?
@3doeste do you have the max speed limited in your config?
@phaedrux Hi, this is my config.g, Don't mind the comments, I never change them.
M111 S0 ; Debugging off
G21 ; Work in millimetres
M555 P0 ; Set firmware compatibility to look like RRF
M564 S1 H1 ; limit movement within axis boundaries, forbid movement of axes that have not been homed; Automatic saving after power loss is not enabled
M667 S1 ; Select CoreXY mode
M208 X284 Y289 Z296 S0 ; Set axis maxima; Endstops
M574 X1 Y1 S0 ; Set active low endstops
; M574 Z0
; M558 P0; BL Touch
M307 H3 A-1 C-1 D-1
M557 X0:284 Y0:289 S20
G31 X-51.13 Y37.24 Z1.4 P25
M376 H5; Drives
M569 P0 S0 ; Drive 0 goes forwards
M569 P1 S0 ; Drive 1 goes forwards
M569 P3 S0 ; Drive 3 goes forwards
M92 X100 Y100 Z800 E801,81 ; Set steps per mm
M566 X600 Y600 Z12 E250 ; Set maximum instantaneous speed changes (mm/min)
M203 X18000 Y18000 Z1200 E1200 ; Set maximum speeds (mm/min)
M201 X3000 Y3000 Z250 E250 ; Set accelerations (mm/s^2)
M906 X1500 Y1500 Z1500 E1400 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Heaters
M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Tools
M563 P0 D0 H1 ; Define tool 0
M572 D0 S0.05 ; Set pressure advance; Network
M550 PIDITEC 3DPro ; Set machine name
M540 PBE:EF:DE:AD:FE:ED ; Set MAC address
M552 P192.168.5.111 S1 ; Enable network and set IP address
M553 P255.255.255.0 ; Set netmask
M554 P192.168.5.1 ; Set gateway
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable Telnet; CPU Temp
M912 P0 S-3; Fans
M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S0.7 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S0.7 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on -
@3doeste said in Firmware 2.02 Release candidate 3 now available:
Any clue?Run M558 without parameters, to check that the T2000 value in config.g has been read properly.
Are there any restrictions on the commands usable in M600 macro? (filament-change.g ) I tried it tonight and when it hit the M600 macro, everything froze. The macro contained the following commands:
M83
G1 E-4 F2500
G91
G1 Z20 F5000
G90
G1 X0 Y85 F5000
M291 P"Change Filament"
M300 P5000None of the moves in the filament-change.g were run as far as I could tell. It appeared to just freeze when it hit the M600. The paneldue and DWC showed a paused state, but the movement buttons and resume buttons (on both UI's) didn't do anything. The only thing I was able to do was "emergency stop" (which did work.)
Fyi
I just installed a previous version of the firmware and the baby steps are working. -
@dc42 I just done that and it’s not reading it, it shows the dame value as F, but even then it moves at 1.7mm/s.
M558
Z Probe type 9, input 0, invert no, dive height 3.0mm, probe speed 100mm/min, travel speed 100mm/min, recovery time 0.00 sec, heaters normal, max taps 10, max diff 0.01� -
About the strange notice that a motor not seems to be connected properly... As I did some tests yesterday, the message only popped up during the G32 command...? Maybe this could be a hint to find a possible problem / solution?
M558
Z Probe type 9, input 0, invert no, dive height 3.0mm, probe speed 100mm/min, travel speed 100mm/min, recovery time 0.00 sec, heaters normal, max taps 10, max diff 0.01�1.7mm/sec is about 100mm/min, so that explains it. The question is, why does it have the travel speed set to 100 instead of 2000. Do you have any M558 commands in any other files, for example homing files? If you reboot the Duet and run M558 before you home the printer or run any other commands, does it report 100 or 2000 ?
@kuhnikuehnast said in Firmware 2.02 Release candidate 3 now available:
Did you get this message when running 2.02RC3, or only with 2.02RC2 ? You don't appear to have mentioned it before in this thread.
@dc42 said in Firmware 2.02 Release candidate 3 now available:
oh, sorry. I got on RC2 as a "red window- alert". On RC3 I now get a "yellow window" that disappears after a few seconds:
Warning: motor phase A may be disconnected reported by driver(s) 0 Warning: motor phase B may be disconnected reported by driver(s) 0
But the print and anything else works fine...?
- Is this on a Duet WiFi, Ethernet, or Maestro?
- Are you able to identify which command in your bed.g file provokes it?
- Is driver 0 driving the X motor as usual, or have you used M584 to re-map another axis or extruder to driver 0?
- What current do you have that motor set to?
It is a Duet Wifi (1.03), it is the X motor, current is set to 800 (same motor as on y). I just tried to figure out what exactly is causing the message but it is really strange! It only pops up sometimes. But if, then it almost always pops up if I start a print. Then after the G32 command and somewhere around the G29. If I don't print, I can move all axis, home all axis etc... (I can even execute my S3D- start-script...?)
As slicer I use S3D, here is the start-script:G21 ; metric values G90 ; absolute positioning M82 ; set extruder to absolute mode G28 ; home axis G32 ; auto bed compensation ; G28 Z ; home z M98 PClean_Nozzle.g ; G29 ; mesh bed levelling M98 PClean_Nozzle.g ; G92 E0 ; zero the extruded length G1 X20.0 Y20.0 Z0.2 F7800 ; start point for starting line G1 X140.0 Y20.0 E10 F800 ; extrude 8mm filament along 110mm movement in x G1 X150.0 Y20.0 Z0 F7800 ; separation move Z0 to keep up nozzle preasure G92 E0 ; zero the extruded length again
and here the Clean_Nozzle.g file:
; go to start point G0 X225 Y68 Z10 F9000 ; Z not yet to prevent crash M564 S0 ; allow negative Z-value G0 Z4.5 ; start point reached G91 ; relative positioning ; start X0 Y0 front left G0 X15 Y13 F6000 ; 1. move G0 X-15 Y14 F6000 ; 2. move G0 X15 Y13 F6000 ; 3. move G0 X-15 Y0 F7000 ; end back left M564 S1 ; denie negative Z G1 Z5 ; lift Z at the end G90 ; absolute positioning
