    Firmware 2.02 Release candidate 3 now available
    Firmware installation
    31
    104
    16.2k
    • BlueDustundefined
      BlueDust
      Z Baby Stepping doesn't seem to work any more.
      I just updated DWC to 1.22.4 to see if that would fix it, and it did not.
      Current version
      Firmware Electronics: Duet Ethernet 1.02 or later
      Firmware Version: 2.02RC3(RTOS) (2018-10-17b2)
      Web Interface Version: 1.22.4
      Is anyone else having this problem?
      Fun, that 3 letter word with "u" in the middle.
      garyd9undefined 1 Reply Last reply Reply Quote 0
      • garyd9undefined
        garyd9 @BlueDust
        @bluedust said in Firmware 2.02 Release candidate 3 now available:
        It seems to be working for me from both the 1.22.4 DWC (that was just put out today) and from the PanelDue 1.22 released a couple days ago. (It's annoying from the Paneldue due to the "response" popups, but it seems to work.)
        What symptoms are you seeing that suggest it's not working?
        BlueDustundefined 1 Reply Last reply Reply Quote 0
        • claustroundefined
          claustro
          M557 now supports a P parameter to set the number of X and Y points, as an alternative to using the S parameter to set the spacing
          So I can write M557 X30:260 Y15:245 P9
          Instead M557 X30:260 Y15:245 S57.5
          and the firrmware automatically calculate probe point spacing right?
          i
            dc42 administrators @claustro
            @claustro said in Firmware 2.02 Release candidate 3 now available:
            i
            Yes, that's correct.
            Googliolaundefined 1 Reply Last reply Reply Quote 0
            • fmaundefined
              fma @k3lag
              @k3lag said in Firmware 2.02 Release candidate 3 now available:
              @dc42 updated to 2.02rc3 and dwc 1.22.4-b1. Since upgrading whenever I scroll down in DWC it automatically scrolls back up a couple seconds later. Very irritating. I'm using Safari 12.0. This hasn't been a problem with any previous version. It seems to print fine however.
              Could it be related to this bug? https://www.thingiverse.com/thing:2448907
              On previous versions of Chromium, I was able to set the 'enable-scroll-anchoring' to true, and it fixed the problem. But in recent versions, this flag does not exists anymore, and the bug came back (on Thingiverse, I didn't try Duet latest firmware).
              Frédéric
              • BlueDustundefined
                BlueDust @garyd9
                @garyd9
                I press the neagtive or positive buttons and the nozzle doesn't get any closer or further from the bed. I use this all thr time adjust the squish during the first layer.
                I didn't reboot my printer a second time after installing the 3rd beta of the firmware. I will do that when I get home and see if that fixes it.
                • garyd9undefined
                  garyd9 @BlueDust
                  @garyd9
                  How big are your baby steps configured for? Does DWC claim that the baby steps are taking place? (It shows the current babystep.) On mine, I never actually measured the nozzle distance to ensure that the babysteps were happening, but I know that I'm about 0.04mm too high on my manual level, and if I don't babystep, everything curls up.
                  • SupraGuyundefined
                    SupraGuy
                    I hadn't thought much about this, but I'm seeing something similar.
                    Baby steps are configured as 0.05mm, but I'm not seeing any effect on the machine. It changes the compensation factor on the DWC, (I had it showing up to a full 3mm of compensation at one point) but it didn't move the Z axis motors at all, so far as I could see.
                    My last few prints, I just stopped using it, because I thought that it might be something in my Z speed/acceleration settings not letting it get started for such a small move.
                    This started when I upgraded to 2.02RC2, still happening with RC3, however I also changed my Z lead screws when I upgraded to 2.02RC2 from 5mm/0.8mm lead to 8mm/8mm lead (4000 steps/mm to 400 steps/mm.) I had assumed that it had to do with the change in lead screws. I don't have those values from my config.g in front of me at the moment.
                    Lead screw driven printer, powered by Duet 2 Wifi
                    MPCNC powered by Duet 2 Wifi
                    CoreXY printer driven by Duet 3 6HC
                    LowRider CNC powered by Duet 2 Wifi
                    • BlueDustundefined
                      BlueDust @garyd9
                      @garyd9
                      Default change is .05mm and it does say its changed. Usually I change this value from .25 to .35. After a 5 point calibration, start a print, change this Z level to around .25 / .35 to get a good squish going.
                      Usually stays pretty close to that initial adjustment after many 5 point calibrations until I power off/on again. And then I have to make this adjustment again.
                      Right now when I push the button - or + no changes are made, and as such, my prints don't always stick. This was working a 2 days ago. Appears like it stopped a day or two after I installed beta 3. I don't reboot the machine often so I may have rebooted it for the first time after installing the beta, but emergency stopping a print or something, that started this issue... Just saying that possible. Will reboot again when I get home. If that doesn't fix it will reinstall the current beta and if that doesn't help may reinstall beta 2 to confirm, as it was working for me.
                      Thanks
                      • garyd9undefined
                        garyd9 @BlueDust
                        @bluedust
                        WARNING: What follows is a WAG. Well, and educated WAG, but still a guess.
                        I wonder what the actual gcode DWC is sending - in particular if its actually sending a M290 R0 or M290 R1.
                        I wonder this because there's a commit that appears to be functionally different for R0. Previously, it would call PushBabyStepping(val - current). Now it's calling PushBabyStep(val)
                        I really don't understand the code I'm looking at, and my initial impression is that this change fixes a bug where the absolute mode (R0) was doing relative changes instead of absolute changes.
                        garyd9undefined tjb1undefined 2 Replies Last reply Reply Quote 0
                          The only change made to baby stepping in RRF 2.03RC3 is to remove the limit of +/-1mm change when using absolute mode.
                          Old code:
                          const bool absolute = (gb.Seen('R') && gb.GetIValue() == 0);
                          float difference = (absolute) ? fval - currentBabyStepZOffset : fval;
                          difference = constrain<float>(difference, -1.0, 1.0);
                          currentBabyStepZOffset += difference;
                          New code:
                          float difference;
                          if (absolute)
                          	difference = fval - currentBabyStepZOffset;
                          	currentBabyStepZOffset = fval;
                          else
                          	difference = constrain<float>(fval, -1.0, 1.0);
                          • garyd9undefined
                            garyd9 @garyd9
                            Like I said (typed...)
                            @garyd9 said in Firmware 2.02 Release candidate 3 now available:
                            For some reason when I was staring at the diff, it wasn't clicking in my head and I wanted to be clear about that when I posted. I had intended to followup when I got home, but I'm married with children. (I think that explains everything.)
                            I did see some weirdness with babystepping last night myself, but that was a case of the paneldue reporting an offset of 0.00 while DWC was reporting -0.02. I think DWC was correct, but it's very difficult to measure 0.02mm while the nozzle is moving.
                            • tjb1undefined
                              tjb1 @garyd9
                              @bluedust
                              You can see what DWC is sending the Duet by opening the Developer Tools for your browser (usually F12), select the Network tab and then click any of the buttons and you'll see something along the lines of http://ip_address/rr_gcode?gcode=
                              • BlueDustundefined
                                BlueDust @garyd9
                                @garyd9
                                I would expect it to be impossible (or close to) to measure those small changes. I just print and change it during that first layer and see the difference. But even changing it 1mm + or - doesn't do anything anymore. And that should make big obvious changes to the print.
                                I am back to recalibrating Z with every power on (before I discovered the baby stepping button). Not a big deal, just takes more time.
                                Thanks for looking into this.
                                • 3DOesteundefined
                                  3DOeste
                                  Hi, I have a problem when running G29 to probe the bed. For some reason the moving speed between probe point it's extremely slow. I have M558 P9 H3 F100 T2000, but no matter what T value I put, it always moves at 1.7mm/s.
                                  It was working fine last time I used it, and I sincerely don't remember to have modified anything else (but perhaps I did...)
                                  Any clue?
                                  Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                    Phaedrux Moderator @3DOeste
                                    @3doeste do you have the max speed limited in your config?
                                    3DOesteundefined 1 Reply Last reply Reply Quote 0
                                    • 3DOesteundefined
                                      3DOeste @Phaedrux
                                      @phaedrux Hi, this is my config.g, Don't mind the comments, I never change them.
                                      M111 S0 ; Debugging off
                                      G21 ; Work in millimetres
                                      M555 P0 ; Set firmware compatibility to look like RRF
                                      M564 S1 H1 ; limit movement within axis boundaries, forbid movement of axes that have not been homed
                                      M667 S1 ; Select CoreXY mode
                                      M208 X284 Y289 Z296 S0 ; Set axis maxima
                                      M574 X1 Y1 S0 ; Set active low endstops
                                      ; M574 Z0
                                      ; M558 P0
                                      ; BL Touch
                                      M307 H3 A-1 C-1 D-1
                                      M557 X0:284 Y0:289 S20
                                      G31 X-51.13 Y37.24 Z1.4 P25
                                      M376 H5
                                      M569 P0 S0 ; Drive 0 goes forwards
                                      M569 P1 S0 ; Drive 1 goes forwards
                                      M569 P3 S0 ; Drive 3 goes forwards
                                      M92 X100 Y100 Z800 E801,81 ; Set steps per mm
                                      M566 X600 Y600 Z12 E250 ; Set maximum instantaneous speed changes (mm/min)
                                      M203 X18000 Y18000 Z1200 E1200 ; Set maximum speeds (mm/min)
                                      M201 X3000 Y3000 Z250 E250 ; Set accelerations (mm/s^2)
                                      M906 X1500 Y1500 Z1500 E1400 I30 ; Set motor currents (mA) and motor idle factor in per cent
                                      M84 S30 ; Set idle timeout
                                      M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
                                      M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                                      M563 P0 D0 H1 ; Define tool 0
                                      M572 D0 S0.05 ; Set pressure advance
                                      M550 PIDITEC 3DPro ; Set machine name
                                      M540 PBE:EF:DE:AD:FE:ED ; Set MAC address
                                      M552 P192.168.5.111 S1 ; Enable network and set IP address
                                      M553 P255.255.255.0 ; Set netmask
                                      M554 P192.168.5.1 ; Set gateway
                                      M586 P0 S1 ; Enable HTTP
                                      M586 P1 S0 ; Disable FTP
                                      M586 P2 S0 ; Disable Telnet
                                      ; CPU Temp
                                      M912 P0 S-3
                                      M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                      M106 P1 S0.7 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                      M106 P2 S0.7 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                        dc42 administrators @3DOeste
                                        @3doeste said in Firmware 2.02 Release candidate 3 now available:
                                        Any clue?
                                        Run M558 without parameters, to check that the T2000 value in config.g has been read properly.
                                        • garyd9undefined
                                          garyd9
                                          Are there any restrictions on the commands usable in M600 macro? (filament-change.g ) I tried it tonight and when it hit the M600 macro, everything froze. The macro contained the following commands:
                                          M83
                                          G1 E-4 F2500
                                          G91
                                          G1 Z20 F5000
                                          G90
                                          G1 X0 Y85 F5000
                                          M291 P"Change Filament"
                                          M300 P5000
                                          None of the moves in the filament-change.g were run as far as I could tell. It appeared to just freeze when it hit the M600. The paneldue and DWC showed a paused state, but the movement buttons and resume buttons (on both UI's) didn't do anything. The only thing I was able to do was "emergency stop" (which did work.)
                                          • BlueDustundefined
                                            BlueDust @BlueDust
                                            Fyi
                                            I just installed a previous version of the firmware and the baby steps are working.
