Your Duet rejected the HTTP request: page not found
Firmware installation
20.4k
    sleepless
    it looks like im in the -70 range which is bad. so i just need to be patient and wait for the network to see it.
      T3P3Tony administrators @sleepless
      @sleepless your Wifi does not appear to be up properly:
      Failed to get WiFi status
      Please can you send the following:
      M552
      M552 S1
      Also please share your config.g here
      undefined 1 Reply Last reply 26 Oct 2018, 00:49 Reply Quote 0
        sleepless @T3P3Tony
        @t3p3tony [0_1540514887260_config (1).zip](Uploading 100%)
        undefined 1 Reply Last reply 26 Oct 2018, 01:24 Reply Quote 0
          Phaedrux Moderator @sleepless
          @sleepless I think you'll have to upload it as a plain text file, or just copy and paste the contents into a post.
            sleepless
            ; generated by RepRapFirmware Configuration Tool on Wed Oct 24 2018 18:43:01 GMT-0700 (Pacific Daylight Time)
            M550 PRobo_Duet1 ; Set machine name
            M551 Psafety13 ; Set password
            M552 S1 ; Enable network
            ;*** Access point is configured manually via M587
            M586 P0 S1 ; Enable HTTP
            M586 P1 S0 ; Disable FTP
            M586 P2 S0 ; Disable Telnet
            M92 X80 Y80 Z800 E723.38 ; Set steps per mm
            M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
            M203 X18000 Y18000 Z180 E1200 ; Set maximum speeds (mm/min)
            M201 X500 Y500 Z5 E25 ; Set accelerations (mm/s^2)
            M906 X1000 Y1000 Z1000 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X230 Y254 Z200 S0 ; Set axis maxima
            M574 X1 Y2 Z1 S1 ; Set active high endstops
            M558 P5 H5 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
            G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
            M557 X15:215 Y15:239 S20 ; Define mesh grid
            M143 H0 S110 ; Set temperature limit for heater 0 to 110C
            M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
            M143 H1 S300 ; Set temperature limit for heater 1 to 300C
            M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
            M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
            M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
            M563 P0 D0 H1 ; Define tool 0
              sleepless
              anyone can help with the robo3d r1 plus auto level and z home setup?
                sleepless
                OK I got all axis to home but cant get it to auto level. I read this https://forum.duet3d.com/topic/4737/zprobe-robo3d-r1/9 but am still confused. please help
                  Have you gone through https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe ?
                  undefined 1 Reply Last reply 31 Oct 2018, 00:14 Reply Quote 0
                    sleepless
                    Should my z endstop be plugged into the z probe area instead of the z endstop area on the board? Sorry Im feel like im just getting more and more confused
                    undefined undefined 2 Replies Last reply 29 Oct 2018, 20:50 Reply Quote 0
                      @sleepless said in Your Duet rejected the HTTP request: page not found:
                      That's up to you depending on which probe mode you choose. Either mode 4 or mode 5 (or one of the slight variations (mode 6, 7, or, 8 which use different connection options.)
                      https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
                      Mode 4
                      The trigger signal is read from the E0 endstop circuit. You can choose whether the signal is high or low when triggered. In firmware 1.15 and earlier this is done by using M574 E0 S1 to select active high, or M574 E0 S0 to select active low. In firmware 1.16 and later, use I1 in the M558 command to select active low, otherwise it defaults to active high. The device connected to the E0 STP pin must be able to sink 1.5mA for the Duet 2 WiFi and Duet 2 Ethernet, 0.3mA for the Duet 2 Maestro, or 2.1mA for the Duet 0.6 or 0.8.5.
                      Mode 5
                      A switch or digital output device connected between the IN and GND terminals of the Z probe connector. Similar to mode 4 except that the Z probe connector is used. The input must be active high when triggered, or in firmware 1.16 and later you can use the I1 parameter in the M558 command to select active low. The only pullup resistor is the 100K nominal pullup in the microcontroller so the sink current requirement is tiny.
                      Mode 6
                      Similar to mode 4 except that the E1 endstop input is used.
                      Mode 7
                      Similar to mode 4 except that the Z endstop input is used.
                      Mode 8
                      Similar to mode 5 except that the input is not filtered, for slightly faster response. Supported in firmare 1.20 and later.
                      It would help to know what type of switch it's using for the Z axis endstop, but I think you may want to use Mode 8, which would connect your switch to the Z probe connector.
                        @sleepless do you have both a Z probe and a Z endstop or just a probe? Generally a Z probe would be plugged into the prob header.
                        edit @Phaedrux provided a far more detailed answer, posts crossed.
                        undefined 1 Reply Last reply 29 Oct 2018, 20:54 Reply Quote 0
                          Phaedrux Moderator @T3P3Tony
                          @t3p3tony The Robo3D appears to have 2 end stop switches wired in parallel for the z axis.
                          At least that's what I gathered from the thread linked above.
                          It looks like they used mode 4, inverted, wired to the z endstop pins.. But I think mode 8 connected to the z probe pins would also work.
                            sleepless
                            Thanks everyone so to clarify I am using the robo3d r1 plus stock endstops and autolevel. It uses microswitches that get triggered when the x axis is lifted off the endstop by the nozzle touching the bed. I will move the z endstop to the z probe connection and give it a go
                              sleepless
                              z probe seems to need the plug wired differently am I seeing that correctly?
                                sleepless
                                forgot to mention I only have endstops no z probe
                                  sleepless
                                  what is parameter I1?
                                  Connect it between the STP and GND pins of the E0 connector and select mode 4. If it is a normally-closed microswitch, then with version 1.15 or earlier firmware use M574 E0 S1 to select active high trigger level. For normally-open contacts (not recommended), send M574 E0 S0 instead. With 1.16 or later firmware, include parameter I1 in the M558 command if you are using a normally-open switch.
                                  Ok so if I understand this correctly I need to plug my Z endstop into the E0 Stop. I need to connect the black wire to the GRD and the Red wire into the E0 Stop pin ports. Then I need to send M558 parameter I1?
                                    I1 will invert the signal. That's an upper case i.
                                      sleepless
                                      Thanks for the quick replies ok ill give it a shot and see what happens. If the Z doesnt trigger how do I troubleshoot?
                                        You can test the switch itself by connecting it to an endstop connector and seeing if the light turns on and off when it's triggered. Then it's just a matter of being connected with the wires to the right place for the chosen mode.
                                        That linked thread seems to indicate that it should work in this configuration but as a fall back you could use it as a simple endstop switch.
                                          sleepless
                                          Should I be following these instructions for the change in Homeall.g
                                          Bed probing file
                                          If you use mesh bed compensation (which is recommended in most cases) or no bed compensation, you can skip this section. This section is about using the older 3, 4 and 5 point bed compensation, using probe points defined in the bed.g file.
                                          The commands in bed.g are executed when you send the G32 command. So this file should contain your bed probing script. Here is a typical 5-point bed.g file for a printer with a 200 x 200mm bed:
                                          M561 ; clear any existing bed transform
                                          M401 ; deploy Z probe if necessary
                                          G30 P0 X10 Y10 Z-99999 ; define 4 points in a clockwise direction around the bed, starting near (0,0)
                                          G30 P1 X10 Y190 Z-99999
                                          G30 P2 X190 Y190 Z-99999
                                          G30 P3 X190 Y10 Z-99999
                                          G30 P4 X100 Y100 Z-99999 S0 ; finally probe bed centre, and calculate compensation
                                          M402 ; retract the Z probe
                                          G1 X0 Y0 F5000 ; move the head to the corner (optional)
                                          60 out of 178
