    Duet Wifi setup - need help
    79
    13.7k
    • ScotYundefined
      ScotY
      Thank you. I plan to do just that.
      There are some M-codes in my current controller's configuration that are not listed in the config.g. I'm assuming it's okay to add stuff as needed? I guess it's mostly just the PID settings that I had been using, M301.
        I don't advise starting from the Mini Kossel files for a Cartesian printer because too many things need to change. Try the online configuration tool. During initial testing, it's useful to reduce the motor currents and homing speeds, to reduce the risk of damage if you don't get the files quite right.
        For PID settings, things changed with the 1.15 release. See https://duet3d.com/wiki/Tuning_the_heater_temperature_control.
        • ScotYundefined
          ScotY
          Where can I find the online configuration tool?
          Can I use this for my PID settings? It's what I was using before and, while not perfect, it worked well enough.
          M301 H1 P30 I0.02 D150
          M304 H0 P10 I0.02 D305
            You will need to change the PID settings as described in the page I linked to. Another user linked to the configuration tool a few posts back.
            • ScotYundefined
              ScotY
              Thanks, I'm not sure how I missed that…I'm in the process of using the configuration tool and have some questions.
              1. I'm assuming to set Reprap for the firmware compatibility? I'm just confused as the default config.g file says set output to look like Marlin.
              2. The settings I pulled from my old control board for acceleration was this:
              M201 X800 Y800 Z20 E10000
              Do these settings sound right and should I use them in the configurator?
              3. I don't understand the tool mapping page. Do I need to set anything here? The printer is a simple cartesian printer with heated bed and a single nozzle.
              4. What should my motor currents be set to? I'm installing the Duet Wifi into a Monoprice Mini Select and it uses JKong JK42HS34-1334AC-02F motors on X, Y, and extruder. The Z-axis motor is a weird round can motor with no markings.
              JKong motor specs:
              Current/phase 1.33 amps
              Resistance/phase 2.1 ohms
              Inductance/phase 2.5mH
              • elmoretundefined
                elmoret
                1.) Either should be OK, I'd probably stick with Marlin.
                2.) Those settings are reasonable
                3.) Should be fine leaving as is
                4.) I'd do the defaults (800mA)
                That should get you up and running, you can tweak from there.
                • ScotYundefined
                  ScotY
                  Thanks! Any idea why the z-axis acceleration is so low and the extruder so high?
                    Your extruder acceleration looks rather high to me, although it may be OK if it is a direct drive extruder with only about 100 steps/mm. I suggest you reduce it to 3000.
                    It's normal to use a low Z acceleration when the Z axis is driven by a threaded rod and has a very high steps/mm.
                    • ScotYundefined
                      ScotY
                      Good morning!
                      The extruder is a bowden type with a relatively short tube length, i.e. small printer. Steps/mm is 406.
                      The z-axis is driven by a finely threaded rod and is 1097 steps/mm.
                      I wish to integrate the infrared sensor, mine is a v1,1 version, I believe. As stock, the printer has a microswitch for the z-axis. Do I understand correctly that I do not use this micro switch for the z any longer?
                      Sounds like it's time for me to cut off the many JST style connectors from my printer and attach the Molex type. I have been holding off until I figured out enough about the Duet Wifi so as to minimize my down time.
                      Thanks again for all the help!
                        Your extruder evidently has gearing of around 3:1, so you should definitely reduce the extruder acceleration to 1000-3000 until you have time to test what it is capable of.
                        If you use the IR probe for Z homing on a Cartesian or CoreXY printer, then you don't need a Z microswitch. But you don't need to disconnect it either, so you may as well leave it in place and connected for now. That will give you a choice of how to do Z homing.
                        I assume your JST connectors are the ones with a pitch finer than 2.54mm, not the Molex-compatible ones.
                        • ScotYundefined
                          ScotY
                          Yes, you are correct, I'm using a E3D Titan extruder. Thank you, I will follow your advice.
                          The JST connectors seem to have the same pin spacing but I think the holes the pins go into are smaller? I tried to push them on but they didn't seem to want to go. Didn't want to break anything. Should they fit enough for testing? I'm thinking I really need to extend all the wiring as it's looking pretty tight in the enclosure and perhaps I should mount the Duet outside.
                          • ScotYundefined
                            ScotY
                            Ah, I should look closer before typing! The JST connectors indeed will fit onto the Duet board. The stepper motor wire coloring does not match up though. I am assuming it will be okay and rotation direction can be changed by editing the config.g?
                            Duet colors are - red/blue/green/black
                            Current wiring will be - green/black/red/blue
                            I do show resistance between the green/black and red/blue pairs so I assume this is all normal and will work.
                            • ScotYundefined
                              ScotY
                              Okay…for some reason, I thought if you connect 12v to the board, you should not connect the USB simultaneously? Is this correct?
                              • ScotYundefined
                                ScotY
                                I have everything wired up and 12v applied to the board. The LEDs are lit up but I don't really know what they mean. I can connect to the board via the web interface, but cannot connect in my slicer (Simplify3D). I'm assuming I need to connect the USB cable? If so, do I need to move a jumper beforehand?
                                • ScotYundefined
                                  ScotY
                                  I've read the Wiki again and it's not clear to me. I don't want to feed power back into my computer if I connect the USB. Puzzled…
                                  • elmoretundefined
                                    elmoret
                                    You don't need to connect via S3D, just use it to save .gcode files and upload those via the web interface. No need to connect USB.
                                    • ScotYundefined
                                      ScotY
                                      I'm have my extruder connected to E0 Heat and the thermistor on E0 Temp. I can see the temperature reading but the heater doesn't turn on using the web interface. I can get the bed to turn on and warm up with a correct temperature reading. Once again, I am confused.
                                      This is what is in the config.g below:
                                      M143 S260 ; Set maximum heater temperature to 260C
                                      M570 S150 ; Set maximum heating time to 150s
                                      M305 P0 T100000 B3950 C0.0000000000000000 R4700 L0 H0 ; Set thermistor + ADC parameters for heater 0
                                      M305 P1 T100000 B3950 C0.0000000000000000 R4700 L0 H0 ; Set thermistor + ADC parameters for heater 1
                                      • ScotYundefined
                                        ScotY
                                        Thank you, elmoret. I know it's not recommended to print via USB but I kind of like it. Seems easiest for me. Maybe I can learn to do it another way.
                                        • ScotYundefined
                                          ScotY
                                          Well crap, I figured out why the nozzle wasn't heating up! I clicked on the Heater 1 in the web interface and it went from standby to active. What purpose does this serve, aside from challenging newbies?
                                          • ScotYundefined
                                            ScotY
                                            Latest issue…extruder motor was running the wrong way. Changed M569 P3 S1 to M569 P3S0. This worked to reverse a different motor earlier today. Now, in the web interface, I cannot get the extruder motor to turn and get this error message:
                                            M120
                                            M83
                                            G1 E-5 F600
                                            M121
                                            Attempting to extrude with no tool selected.
                                            So...what the heck did I do wrong now?
