    Tuning for smooth extrusion
    31
    3.5k
    • gnydickundefined
      gnydick
      I was really tired, I kept lowering jerk instead of increasing it, so it kept getting worse. 😕
      • gnydickundefined
        gnydick
        Thanks for the help
          Glad to help! Is the problem solved?
          • gnydickundefined
            gnydick @dc42
            @dc42 it's definitely much better.
              So it was just a case of low x and Y jerk?
              • gnydickundefined
                gnydick @Phaedrux
                @phaedrux seems to be
                • gnydickundefined
                  gnydick
                  So, I've tuned and upgraded my printer mechanics. It now prints BEAUTIFULLY. The layers are ridiculously identical. But I'm having a couple problems. Notice the two circled defects.
                  The circles I print are all oblong or misshaped, though identical at all layers.
                  The other area has a kink in the transition from the top radius to the vertical tangent edge. Again, identical at all layers.
                  I can't seem to figure out how all straight lines are phenomenally consistent, but curves are so badly rendered.0_1541783588376_IMG_20181109_090709.jpg
                  I printed a large cube with pressure advance slightly changed every 5mm and picked a setting that yielded the best overall square profile.
                  • SupraGuyundefined
                    SupraGuy
                    Every time I've seen oblong circles, it's been a case of backlash in a movement axis. This was what finally did in my I3, when I could no longer get rid of backlash in the Y axis, I took it out of service.
                    They're consistent layer for layer because the printer always goes around the circle in the same direction, usually anticlockwise around the perimeter. This means that it will still always start the straight line in the same place, but curves or changes in direction will be out, usually delayed along the axis that has the backlash problem.
                    Lead screw driven printer, powered by Duet 2 Wifi
                    MPCNC powered by Duet 2 Wifi
                    CoreXY printer driven by Duet 3 6HC
                    LowRider CNC powered by Duet 2 Wifi
                    • gnydickundefined
                      gnydick @SupraGuy
                      @supraguy That makes sense, but I don't think that's the case here. I'm going to print super slow to see if it still happens.
                      • gnydickundefined
                        gnydick
                        In the mean time, does reducing jerk help this?
                          Phaedrux Moderator @gnydick
                          @gnydick it might make it worse. The lower the jerk the longer the pause at a direction change which can lead to more plastic oozing out where you don't want it.
                          What speed settings are you using in firmware and in the slicer?
                          • gnydickundefined
                            gnydick @Phaedrux
                            @phaedrux
                            M201 X1000 Y1000 Z135 E250:250 ; accleration
                            M203 X24000 Y24000 Z2400 E5000:5000 ; velocity
                            M566 X300 Y300 Z20 E300:300 ; jerk
                            My printer is really rigid. The extruder is mounted to two linear rails, 6+ inches apart, perpendicular to each other, one over the extruder, one way behind. There really is no way for reasonably speed configured print to cause vibrations like this.
                            This configuration is what I have now after working through the weird overshot corners.
                            I took high speed video to figure that out, and saw that the carriage did indeed swing due to momentum, but now, there is no swinging, Even at a small scale. And I'm still getting results like in the photo.
                            I don't get it. My prusa mk2 can print 150mm/sec with almost no artifacting. I know they're different designs, but my duet based printer is leagues above in terms of rigidity and geometry.
                            I just don't get it.
                              300mm/min is quite low for jerk. And your max acceleration is pretty conservative as well, so I don't think your issue is there.
                              I suspect something is loose mechanically. If you grip the nozzle and wiggle it does the carriage have any play?
                              What are your slicer speed settings?
                              • gnydickundefined
                                gnydick
                                @phaedrux
                                Everything is tight as can be.
                                Actually, I just realized those are my current settings, I dialed it all back to get better results.
                                They were...
                                jerk: 1200, then 600, still problem
                                accel: I think was 2500 max and kept bumping it down.
                                Speed was and is set to
                                Max: 100
                                Perim: 60
                                Extern perim: 40
                                Travel: 80
                                Infill: 60
                                etc.
                                So now, the prints are better, but slow, as there generally isn't enough distance to reach top speed.
                                I'm used to my prusa that whizzes back and forth with acceleration between 4000-5000 and jerk is high as well, just don't remember.
                                Oh, and this is the printer from another post where I showed a 3mm diameter circle printed at a real world 150mm/sec with crazy jerk and acceleration. That was a demonstration print after fixing my carriage momentum problems.
                                • gnydickundefined
                                  gnydick
                                  I should also add, that I use a Flexion extruder. It has extremely good bite. It doesn't slip under acceleration like most conventional extruders do.
