    Solved - Dead duet wifi board???
    3.0k
      Do you definitely have continuity between VSSA and GND, through the PTC fuse that you added? A few ohms resistance is normal. The PTC fuse may take a while to recover after you soldered it.
      EDIT: to determine the board revision, the firmware enables the internal pullup resistor (value about 100k) on the TCK pin and then reads the input level on that pin. If it reads high then the firmware assumes that nothing is connected to that pin and the board revision is 1.0 or 1.01. If it reads low (because of the 10k resistor pulling it down to VSSA) then it assumes a 1.02 or later board.
      celulariundefined 1 Reply Last reply Reply Quote 0
      • celulariundefined
        celulari @dc42
        @dc42 said in Dead duet wifi board???:
        Yes, I have continuity between VSSA and GND. The resistance through the PTC fuse in 1.9ohm.
        It is normal to have continuity between the VSSA and TCK?
          dc42 administrators @celulari
          @celulari said in Dead duet wifi board???:
          Only via the 10K resistor that you added.
          • celulariundefined
            celulari @dc42
            Oops... I have continuity even without the resistor... But it's printing 😅😅
            • celulariundefined
              celulari
              Any clues about what may be causing the short?
                As TCK is right next to GND on the 2x5 pads where you connected the resistor, a solder bridge between those pads is the most likely explanation.
                • celulariundefined
                  celulari @dc42
                  finally figured out!
                  i've followed the instructions on the wiki page https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#VSSA_fuse for bypassing the fuse and add the 10K resistor, and solderd by this image on the wiki:
                  But!!! that picture is wrong!!!! the resistor is NOT going to the TCK, is connected to ground, as my board recently. The pad to the left is the TCK pad!
                  how do i know?
                  The proof...
                  So now my board is not dead, but upgraded!
                  The processor swap was relatively easy. if anyone wants more details, i've made a video of the process.
                    You are right, the labels next to the 2x5 pad array are wrong. The two columns should be swapped.
                    • celulariundefined
                      celulari @dc42
                      And the wiki should be updated 🙂
                        I already did that.
                        • celulariundefined
                          celulari @dc42
                          I already did that.
                          Thank you for all the help!
