    Z probe offset always prints in the air.
    1.9k
    • andreweundefined
      andrewe
      Hi. I've just set up my duet 2 wifi and can't get the z offset from my probe to work. The probe is triggering well I have it connected to the z probe and the power and negative is on the LCD port. It always seems to print 3mm above what is set? I have been using these instructions:
      " Checking the trigger height
      The Z probe trigger height must not vary significantly with XY position. Measure the trigger height of your Z probe at various XY positions and make sure it is consistent. To measure the trigger height:
      Make sure there is no filament stuck to the nozzle (you may want to do this test with the nozzle hot)
      Cancel any existing bed compensation by sending M561
      Send M208 S1 Z-3 to temporarily allow Z moves down to Z=-3mm. This is to ensure that you can lower the nozzle all the way to the bed in step 5.
      Command the print head to the coordinates you want to probe. To probe the centre, send G1 Z1.
      Command the print head down in small steps until the nozzle just touches the bed or just grips a sheet of paper. You may need to send M564 S0 to allow movement lower than where the firmware thinks Z=0 is. You may also wish to create a macro to lower the head by e.g. 0.02mm to get greater accuracy (G91 followed by G1 Z-0.02).
      Send G92 Z0 to define that height as Z=0
      Command the nozzle up 5mm (G1 Z5)
      Send G30 S-1 to probe the bed without resetting the Z=0 position
      Read off the Z height from the web interface. That is the trigger height.
      Repeat the previous two steps a couple of times to make sure you are getting a consistent result
      Repeat steps 4-10 for the other XY positions you want to check.
      On a delta printer, it can be quite hard to achieve a consistent trigger height. Z probes that are mounted on the effector are sensitive to any tilting of the effector, because it affects the relative heights of the Z probe and the nozzle. You can reduce this effect by mounting the probe as close to the nozzle as possible. Probing solutions that use the nozzle itself as the probe are usually not affected by effector tilt, but some types are sensitive to the XY position of the nozzle for other reasons.
      Once you are satisfied with your trigger height result (should be between 0 and 1mm, depending on your printer), open your config.g file (this can be found in your DuetWebControl), find the G31 command and enter your trigger height as a negative value in the Z parameter (ex. G31 X0 Y0 Z-.43)."
      my settings are :
      ; generated by RepRapFirmware Configuration Tool v2 on Sun Nov 18 2018 15:41:33 GMT+0000 (Greenwich Mean Time)
      M550 P"AM8" ; Set machine name
      M552 S1 ; Enable network
      M587 S"TP-LINK_F694" P"04121963" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M92 X100.00 Y100.00 Z400.00 E97.00 ; Set steps per mm
      M566 X360.00 Y360.00 Z144.00 E180.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X396000.00 Y396360.00 Z43200.00 E180000.00 ; Set maximum speeds (mm/min)
      M201 X2000.00 Y2000.00 Z100.00 E10000.00 ; Set accelerations (mm/s^2)
      M906 X500.00 Y500.00 Z500.00 E700.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout ; Set idle timeout
      M208 X235 Y210 Z230 S0 ; Set axis maxima
      M574 X1 Y1 S0 ; Set active low endstops
      M558 I1
      M574 Z1 S2 ; Set endstops controlled by probe
      M558 P5 H5 F120 T5000 I1 ; Set Z probe type to switch and the dive height + speeds
      G31 P500 X0 Y51 Z-3.71 ; Set Z probe trigger value, offset and trigger height
      M557 X30:200 Y55:150 S30 I1 ; Define mesh grid
      M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
      M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I1 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      M572 D0 S0.2
      ; homeall.g
      ; called to home all axes
      G91 ; relative positioning
      G1 S1 X-235 Y-215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 S1 X-225 Y-215 F360 ; move slowly to X and Y axis endstops once more (second pass)
      G1 S1 Z-230 F1800 ; move Z down stopping at the endstop
      G90 ; absolute positioning
      G92 Z-3.71 ; set Z to axis minimum (you may want to adjust this)
      ;G91 ; relative positioning
      ;G1 S2 Z0 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
      ; homez.g
      ; called to home the Z axis
      G1 S1 Z-235 F1800 ; move Z down until the endstop is triggered
      G92 Z-3.71 ; set Z position to axis minimum (you may want to adjust this)
      ;G1 S2 Z5 F100 ; lift Z relative to current position
      Many Thanks
      Andy
        @andrewe said in Z probe offset always prints in the air.:
        The Z parameter in the G31 command is the nozzle height at which the Z probe triggers, so for most types of Z probe it should be positive. If you are coming from Marlin, this is the opposite of the sign of the M851 Z parameter in recent versions of Marlin.
          It looks like you aren't using G30 in your homing files to actually probe the bed. You are using a G1 Z move to seek the endstop and then a G92 to set the Z position. You'll need to remove those and replace them with G30 to use the Z probe.
          • andreweundefined
            andrewe
            Thanks, I'm trying again now. So when I Send G30 S-1 to probe the bed without resetting the Z=0 position where am I taking the positive number from the top right in Machine status or from the gcode console.
            Thanks
            Andy
              Phaedrux Moderator @andrewe
              @andrewe The G30 S-1 response will be in the console. Your process for measuring the trigger height is correct, but your homing files aren't making use of the results.
              • andreweundefined
                andrewe
                I've got this in my home files now.
                ; homeall.g
                G30
                ; homez.g
                G1 S1 Z3.57 F1800 ; move Z down until the endstop is triggered
                G92 Z3.8 ; set Z position to axis minimum (you may want to adjust this)
                Many thanks Andy
                  You should remove this from homeall:
                  And add an X Y move to position the probe where you want the bed probed before you call G30
                  And remove this from homez:
                  And add the same X Y move and a G30.
                  • andreweundefined
                    andrewe
                    @phaedrux said in Z probe offset always prints in the air.:
                    Thanks for your help I've got a lot further and am actually printing on the bed now 🙂 I don't understand how to do the X Y move to position the probe where you want the bed probed. If use the baby stepping and added 0.2mm do I need to add or subtract that from the hight I set in the config.g?
                    I've got soo much to learn about RepRap.
                    Thanks Andy
                      Usually you want to probe the center of the bed. So you would move the print head to an x and y position that places the probe in the center.
                      You would need to add a line before the G30 that looks like
                      G1 X150 Y150 ; move probe to center
                      G30 ; probe the bed
                      G1 X0 Y0 ; move back to home position
                      You'll have to adjust the x and y values to get your probe to the center and whatever your home position is.
                        I'm not exactly sure what you are asking about baby stepping. Do you mean to say that you still need to make a baby stepping adjustment after measuring the trigger height?
                        If your measured value is 2mm, and you need to lower the nozzle by -0.2 then you would subtract that from your 2mm in config.g if you wanted to make that a permanent change. Is that what you mean?
                        • andreweundefined
                          andrewe
                          Yes, I was 0.2mm too close to the bed so used the baby stepping to raise the nozzle.
                            @andrewe Before you change the trigger height, check to make sure that your e steps are calibrated. Over extrusion on the first layer can be mistaken for printing too close. The trigger height should be accurate, especially if you've measured it several times while the bed and nozzle are heated up and the result is consistent.
                              It's also possible that your bed isn't perfectly flat (few are) and so Z=0 is only really true at the position where the bed was probed. You would have to use mesh grid compensation to probe many points across the bed to create a heightmap, which is then compensated for in real time by adjusting the z height to keep the nozzle at a consistent distance from the bed.
                              https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
                              • andreweundefined
                                andrewe
                                To be fair the bed is pretty shabby It was an Anet A8 and came bent from new. The bed, 1x end stop and the motors are all that's left now. I have a feeling its too out of true even for mesh compensation but I can see that working watching the z screws constantly moving.
                                I use a Prusa spring steel sheet with PEI on it, all held in place with magnets and bulldog clips.
                                I've got a new bed on its way in the post next week but I know how to set the probe up now thanks to yourselves. I think I'll look at different probes and try and get it as close to the nozzle as I can.
                                Thanks for all your help
                                All the best Andy
