    Closed Loop Control of Stepper Motors with Rotary Encoder
    32
    7.1k
    • AJ Quickundefined
      AJ Quick
      I suppose the driver you linked will work. The servo will complete its movement when the system stops sending step signals. It will be the same as a stepper motor.
      You can hook up the feedback trigger for error into the e-stop for that particular axis and then setup a trigger to run code when the servo error is triggered though. So if for some reason the servo is unable to complete its motion (stuck motor for example) it will send an e-stop signal.
      johnundefined 1 Reply Last reply Reply Quote 0
      • Danalundefined
        Danal
        This comes up a lot... and I have to ask... what problem are you trying to solve?
        Hundreds of Thousands? of 3D printers and small CNC machines never miss a step in their normal operation. If they do, it is because of a loose belt or a total jam or something else a closed-loop to the motor won't fix.
        Why add expense and complexity to something that works?
        Apologies in advance if you have a unique application...
          dc42 administrators @john
          @sean said in Closed Loop Control of Stepper Motors with Rotary Encoder:
          @dc42, with the external stepper driver, will we see the same type of behavior from the Duet? Meaning, if we use the breakout to send the logic commands to the external driver, will the Duet know when the move has completed and send the 'ok' back only after the desired position has been reached?
          The "OK" response to a M400 command won't be sent until the M400 command has completed, which won't happen until all moves commanded prior to the M400 command have completed.
          • johnundefined
            john @AJ Quick
            @aj-quick said in Closed Loop Control of Stepper Motors with Rotary Encoder:
            Based on @dc42's response below, that seems to be the case. The error catching will be enormously helpful. I ordered the part I linked and will get it next week.
            • johnundefined
              john @Danal
              @danal I wouldn't say "won't fix" because when we deploy our product it will be difficult to service without incurring a lot of costs (travel or shipping, as an example). Closing the loop on the motion system is peace of mind to know that the duet and external driver are working together to maintain the expected position. And then when something off nominal happens, like a loose belt, or a bit of zip tie, or w/e pops up in the environment, the external driver's fault feature will allow us to shut the machine down before it damages itself extensively.
              Absolutely appreciate the question, and it is a good point to remind us that the external driver doesn't solve design flaws or assembly errors that may lead to an issue. We still need to be conscious of our choices there.
              • JoergS5undefined
                JoergS5 @john
                This post is deleted!
                • johnundefined
                  john @dc42
                  @dc42 I received the external driver and expansion board. I have not had any luck getting it to work so far.
                  Driver = https://www.omc-stepperonline.com/index.php?route=product/isearch&search=CL57T
                  Motor= https://www.automationdirect.com/adc/shopping/catalog/motion_control/stepper_systems/dual_shaft_and_encoder_stepper_motors/stp-mtr-17048e
                  Setup=
                  (Driver) to (Duet Breakout) on Drive 5
                  PUL+ to STEP+
                  PUL- to STEP-
                  DIR+ to DIR+
                  DIR- to DIR-
                  ENA+ to ENA+
                  ENA- to ENA-
                  From my config file:
                  ; Motor Remapping
                  M584 X5 Y1:2 V0 U3 Z4;
                  M569 P0 S1 ;
                  M569 P1 S1 ;
                  M569 P2 S1 ;
                  M569 P5 S1 R1 T2;
                  M906 X2000 Y2000 Z0 U0 ; Set motor currents (mA)
                  The stepper motor has encoder feedback, so first I connected only the stepper motor wires (A+/- B+/-) to the Duet and commanded the stepper motor just fine. When I plug the stepper into the external driver, I noticed that the stepper motor gets hot (about 55+ C) after 10 minutes. That seems to be too high (also data sheet says- 20 to 50 C). I checked the amp setting in M906, and you can see its 2A, as suggested in the motor spec sheet.
                  For the dip switch settings, SW1-SW4 are simple, they just control the encoder resolution (set to default for now). SW5 to SW8 though, I am having a hard time understanding their connection to the config.g settings under M569. In the GCode documentation it says "backwards" or "forwards" for the S parameter - how does this relate to CW or CCW as the Driver seems to indicate?
                  Currently, with the dip switches all set to OFF, I have (on the ext. driver)
                  DIR=CCW,
                  Auto Tuning = Yes,
                  Pulse Mode = PUL/DIR, and
                  Pulse Edge = Rising
                  When I command a X+1 movement from DWC, the shaft seems to click forward, but if I do it another time the movement isn't the same, and a third X+1 causes the motor to vibrate erratically.
                  Any guidance you can provide would be greatly appreciated!
                  JoergS5undefined johnundefined 2 Replies Last reply Reply Quote 0
                  • JoergS5undefined
                    JoergS5 @john
                    @sean your motor gets hot because you set 2A, which is too much. Please see https://forum.duet3d.com/topic/3073/what-should-i-set-my-motor-currents-to-via-m906/3 or similar threads, to set between 50 and 80% of 2A.
                    After getting too hot (> 80 °C internal) the neodym magnets get damaged. I would check that the stepper is still ok. You can measure the A+/- and B+/- resistance and compare it with the datasheet information.
                    • johnundefined
                      john @john
                      @sean Based on this diagram from the driver data sheet:
                      I updated my M569 command to:
                      M569 P5 S1 R1 T2.5:2.5:5:0
                      On the external driver I have the Motor DIR set to CW, and the S1 parameter in M569 set to "Forward" because that seems to make sense.
                      R1 set to Enable High, because enabling the driver from the chart looks like a high command.
                      And the Step Pulse timing seems to correspond to:
                      Taa:bb:cc:dd (firmware 1.21 and later)
                      aa: Minimum driver step pulse width, t3
                      bb: step pulse interval, t4
                      cc: direction setup time, t2
                      ddL direction hold time, 0
                      This is still causing my motor to vibrate after 1 or 2 X+1 commands.
                      • johnundefined
                        john
                        @joergs5 Thanks for the response. I adjusted my R parameter in M569 to R1, active high, and the motors seem to stay cool.
                        • johnundefined
                          john @john
                          @sean I followed the steps on this post, to see if the voltage coming from the expansion breakout was too low for my ext. driver. I didn't suspect so, and it didn't change the behavior of the motor.
                          • JoergS5undefined
                            JoergS5 @john
                            @sean Maybe you should split your analysis first to know which component is not working correctly, so using this controller with another stepper and then testing the stepper with a different controller.
                            The controller has ALM connections. I remember a discussion about this setting here:
                            https://forum.duet3d.com/topic/3519/yet-another-external-driver-question/2
                            (different controller, but maybe comparable meaning).
                            • johnundefined
                              john @JoergS5
                              @joergs5 That approach makes sense - my hang up is that i don't know if the settings on the Duet are matching the dip switch settings on the external driver. Questions like fwd v. CW, or Pulse edge rising v. falling, etc.However, I will mix & match drivers w/ motors to see if the issues are consistent.
                              I don't believe ALM has any bearing on the issues I'm facing. The ext. driver has a flashing LED that tells me when there is an issue, so the ALM connections are just to notify you elsewhere, such as activating a trigger on the Duet as @dc42 points out in the post you linked.
                              • JoergS5undefined
                                JoergS5 @john
                                @sean Some more ideas: if your tests give no result, you could provide information how your wiring is: which pins you connected, which PSU and connected where (controller for stepper needs 24-48 V e.g.), especially where you connect the + signals. Your T parameters are at the edge of the minimium values, I would try longer times.
                                (In case you don't know) CW means clockwise, CCW counterclockwise, so I would set this switch to PUL/DIR.
                                I would not set/use ENA, because it is enabled if unconnected.
                                • johnundefined
                                  john @JoergS5
                                  @joergs5 , the external driver has a dip switch for
                                  "SW5, Motor DIR: off=CCW or on=CW"
                                  "SW7, Pulse Mode: off=PUL/DIR or on=CW/CCW."
                                  I currently have it set to PUL/DR and CW to align with the Duet firmware "Forward." (This makes more sense to me than CW aligning with Backward).
                                  • JoergS5undefined
                                    JoergS5 @john
                                    @sean If you have an oscilloscope, looking at the signals would be another idea. I bought one myself (Hantek 6022) to look at controller signals. Not a quick solution, but maybe you experiment as often as me so that it pays off...
                                    There is a youtube about CL57T, maybe you get some hints:
                                    https://www.youtube.com/watch?v=S8c6c4CYZUU
                                    • johnundefined
                                      john
                                      Update: I believe the issue was the external driver had a default amp setting of 8A, and the stepper motors I was using were only 2.0 A. When I finally was able to get into the external driver firmware (pro tip: order the RS232 compatible cable AND a serial-to-USB from amazon or something), I could toggle the amperage setting from 8A to 2A and create or turn off the vibrating motor issue I was experiencing.
                                      With the omc-stepperonline driver and stepper motors, the pulse timing in M569 is set to 7.5. Anything less and the stepping from the motor sounded like grinding. 7.5 sounds pretty smooth.
                                      • Da Sid Monundefined
                                        Da Sid Mon
                                        I tried using the Closed Loop Stepper Drive/motor combo from Stepperonline. Motors ran OK but from my experience these drives are not truly closed loop. There is no makeup for error and I've switched to a REAL solution. They're Great but NOT cheap (Quality usually isn't)... https://www.teknic.com/products/clearpath-brushless-dc-servo-motors/clearpath-sd/
                                        • johnundefined
                                          john @Da Sid Mon
                                          @da-sid-mon What do you mean "no makeup for error?" I am not saying they are perfect, but the driver-motor combo that I indicated above does attempt to correct the lost steps. The bigger problem that I don't see either of the solutions (mine or your linked servos) is that debris / mechanical fault causing lost steps won't be remedied by closed loop. The only thing that these solutions do in my mind is indicate steps were lost BEFORE you find out after the thing runs into a wall.
                                          I'm genuinely curious about your implementation. These systems are new to me.
                                          • Danalundefined
                                            Danal
                                            Hmmm... I'm a little reluctant to be "that guy", but at the same time, there does seem to be some discussion of "makeup lost steps" and "find an error before the machine hits something". May I point out that no amount of sensing from the motor shaft will detect a loose belt, or a loose pulley. These two causes are BY FAR the most common reasons for the "controlled point" not being physically where the firmware commanded. A sensor on the motor shaft literally cannot "see" either of these.
                                            I'll be the first to say that a sensor on the motor shaft CAN, maybe, sense a "Jam", a failure to actually move when commanded, aka a "missed step", either because something got in the belt/screw or because the "control point" hit something or similar. At least some of the time a sensor will detect these.
                                            So can TMCxxxx stall detect. Particularly, detecting the case of "things are so far off the machine just hit a travel limit" is extremely reliable.
                                            So... I'm back to my original question: Encoders on steppers seems to be expense and complexity that accomplishes very little or nothing, vs. current state-of-the art drivers and steppers.
                                            Of course, this is a free opinion and worth every penny. 🙂
