    Triangle Labs 3D Touch, 240ohm?Wiring?
    16
    3.0k
    • petersnlundefined
      petersnl
      I'm in the same situation, other than having a spare 220 ohm resistor. Since I didn't want to risk it, I decided to order some 240 ohm resistors from Amazon 🙂 (still waiting for them to arrive.. didn't notice it was going to be shipped from Hong Kong 😞 )
      • pro3dundefined
        pro3d
        If you have a newer TL 3d touch it shoudl have a trace you can cut like on the original. Behind the connector on the rear of the probe
        Valkyrie DIY High Temp 3D Printer
        R&D - Engineering Designer - Viking 3D Printers
        https://vkingprinter.com/
        • stewwyundefined
          stewwy
          I've never managed to get my 3d touch to work reliably, had endless bed crashes
          ended up going with dc42's ir probe which has worked a treat.
          Your mileage may vary I may just have had a dud one.
          • sixfeetunderundefined
            sixfeetunder
            i am asking me the same question atm. did you solve it? i have a version without the "wire" to remove.
            • Vetiundefined
              Veti
              i had a trianglelab one and it was way to inaccurate (sd of 0.05)
              i ended up building a bfptouch.
              https://www.thingiverse.com/thing:2890290
              this gives me a standard deviation of 0.002
              kingfisherundefined 1 Reply Last reply Reply Quote 0
              • Vetiundefined
                Veti
                but check out this video. it goes into a detailed info on how to wire it up.
                https://www.youtube.com/watch?v=BgkJVgFnPaE
                • Vetiundefined
                  Veti @sixfeetunder
                  @sixfeetunder
                  didnt see that you posted in an old thread. which version of the duet do you have?
                  the 1.04 is 5V tolerant.
                  • irvelundefined
                    irvel
                    @veti said in Triangle Labs 3D Touch, 240ohm?Wiring?:
                    trianglelab
                    My Trianglelab's 3d touch fails 1 out of 4 times when probing. Maybe some extra components are needed to stabilize its operation, like a capacitor
                    • Vetiundefined
                      Veti @irvel
                      @irvel
                      have you tried adjusting the grub screw?
                      • kingfisherundefined
                        kingfisher @Veti
                        @veti Thanks, just ordered a clone, but I've got all the parts to make this
                        • Mangy_Dogundefined
                          Mangy_Dog
                          Again sorry for late reply. I wanted to wait for the official bl touch to turn up to test first...
                          So far so good... No failed z (though not homed nearly enough to be sure... still early days) and no redeploying too early at all...
                          Only issue I have with the official touch is the plastic pin. Looks painfully fragile. If there was a crash or a curled bit of pla running into it, I can see it breaking really easily. Wish they stayed with the metal pin. I wonder if it would take the metal pin from the triangle labs 3d touch?
                          Oh one thing I did notice and maybe this was why the 3d touch failed, is the led on the BLTouch dims a little when the 3 z motors ramp up the revs... As if the 5v is getting drained.
                          I've also not cut the trace behind the plug on this one. After dave mentioning that the z probe pin on the duex2 is something like 3 to 30v volt compliant...
                          Of course the hump still exists, I expected as much... Still waiting for rails to come in post then I'll fit them and print out the new carriage... Hopefully should then be rock solid.
                          Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                            Phaedrux Moderator @Mangy_Dog
                            @mangy_dog the plastic pin is tougher than you'd think, but they shouldn't be making contact with anything anyway. I've managed to catch the metal pin on the edge of the bed. Being metal didn't help.
                            With the probe mounted at the recommended height (8mm from the base of the probe to the nozzle tip.) it should be well out of the way of the print when retracted. The plastic pin has the advantage of not being effected by any nearby magnetic fields which have become more common with the magnetic build plates. They are also cheaper and easier to manufacture to tight tolerances than the older pins.
                              dc42 administrators @Mangy_Dog
                              @mangy_dog said in Triangle Labs 3D Touch, 240ohm?Wiring?:
                              That should not be happening. Have you wired the bltouch to the Duet as illustrated in the wiki?
                                Mangy_Dog
                                @dc42 at this moment, no idea if it matches wiki, though Im pretty sure I did follow that...
                                I also need to correct something i said...
                                Z is on the z pin of the 4 pin probe header on the Duet3d not the Duex2 my mistake...
                                I have 5v GND and Servo connected to PWM_5 GND is connected to both GND pins of the probe...
                                Current only the probe and Y min and max stops are sharing that same GND line.
                                  There is no "Z" pin on the 4-pin Z Probe connector of the Duet. There is an IN pin, which is where the white wire from bltouch should be connected.
