Fans, Extruder Heaters Pulse Many Times on Startup and Reset
On firmware startup and after reset, the Fan PWM and Extruder heaters pulse and flicker many times. When using these to control other peripherals (e.g. lights, SSR) they peripherals all strobe 3-10 times at startup or upon reset. Is there any way to disable this pulsing of the FAN PWM and Extuder heater outputs? Thanks.
@b3d Do you by any chance use a Duex expansion board? If so, this behaviour seems to be fixed in the latest firmware https://github.com/dc42/RepRapFirmware/releases/tag/2.02RC4
Yes, DuetWifi + Duex5. Upgraded today to:
Firmware Version: 2.02RC4(RTOS) (2018-11-18b5)
WiFi Server Version: 1.21
Web Interface Version: 1.22.5Pulsing is better, but there is still one big pulse upon firmware Reset on the Fan/PWM and Extruder Heater outputs on the Duet5, that are tripping the SSRs connected those modules.
@b3d Yes, I get this too. I don't have anything other than heaters connected to heater outputs but my hot end fan does a "double blip" on start up or reset - like it boots, then instantly boots again. It's not a big deal for me though.
@deckingman said in Fans, Extruder Heaters Pulse Many Times on Startup and Reset:
Have you tried 2.02RC4? You should find it is now a single blip.
@b3d said in Fans, Extruder Heaters Pulse Many Times on Startup and Reset:
When you say a big pulse, how long does it last? I see one pulse at startup, but it is very short.
EDIT: I've found the reason for the heaters blipping at startup. It will be fixed in 2.02RC5. Fan 1 output is intentionally on at startup until turned off in config.g because we intend it to be used for the hot end heatsink fan. Fans 0 and 2 should stay off.
@dc42 said in Fans, Extruder Heaters Pulse Many Times on Startup and Reset:
Yes - and I mentioned the double blip thing is still present in that RC4 thread as well. It's not a big deal though.
