    Issues with macros halting the printer.
    2.7k
    • brunofportoundefined
      brunofporto @dc42
      @dc42 Here it is!
      By the way... I cannot play any "tunes" without adding these timers between each M300. At least with the PanelDue attached.
      M300 S2000 P300
      G4 P300
      M300 S2000 P300
      G4 P300
      M300 S2000 P300
        dc42 administrators @brunofporto
        @brunofporto said in Issues with macros halting the printer.:
        @dc42 Here it is!
        PanelDue has no flow control, deliberately to avoid holding up the Duet. But I could implement a short queue of beeps pending in the PanelDue firmware.
          M291 P"Please wait while the bed is being heated up" R"Please Wait" S0 T0 ; Display message
          M140 S60 ; Set bed temp to 60
          G32 ; Home all axis
          M116 ; Wait for heating
          M292 Close message
          M291 P"Please wait while the bed is being heated up" R"Please Wait" S3 T0 ; Display message
          M98 P/MACROS/SUBMACROS/BEEP.G
          I'm sorry, I can't reproduce the problem using either your test macro or the full macro (I had to make up the contents of 4 more macros thai it called).
          By the way, your test macro is missing a semicolon before the comment "Close message" on the M292 line.
          How reproducible is the problem?
          My best guess as to why it is hanging is that when you cancel the M291 message box, the M292 command to tell the Duet that it has been cancelled is not being received and/or processed. So I have two suggestions:
          1. Connect a PC running YAT or Pronterface etc. and send M111 S1 P3 to enable GCodes debugging. Then you will be able to see whether the M292 command is received.
          2. Next time it appears to be stuck, try sending M292 and see whether that un-freezes it.
          brunofportoundefined 1 Reply Last reply Reply Quote 1
            brunofporto
            Just happened again...
            Freshly started board.
            G32
            Sent the macro from the 22/11/2018 message above. Appeared the messages informing that the bed and hotend would be heated. Clicked ok and.... halted.
              So did you try my suggestions?
              brunofportoundefined 2 Replies Last reply Reply Quote 0
                brunofporto
                The complete sequence and used files:
                Sent G32 and waited for it to finish:
                Executed the Macro:
                Clicked ok and then.... halted doing nothing:
                Attached bed.g, calibration macro and all sub macros related.
                6_1543257949998_bed.g 5_1543257949998_4_Calibrate_ZProbe.g 4_1543257949998_beep.g 3_1543257949998_Center_Nozzle.g 2_1543257949998_Center_Probe.g 1_1543257949998_m_set_low_speeds.g 0_1543257949998_m_set_normal_speeds.g
                  brunofporto @dc42
                  @dc42 I'll..... But the printer is far from a computer and heavy...... As soon as I am able to move it and connect an USB directly I'll try 😄
                    brunofporto @dc42
                    @dc42 Please, in order to avoid moving it unnecessarily, is it possible to monitor via telnet or something?
                      Yes, use the M586 command to enable Telnet.
                        brunofporto @dc42
                        @dc42 said in Issues with macros halting the printer.:
                        ok.... It receives the M292 command, confirms it, but the printer still busy doing nothing 😄
                        m111 s1 p3
                        Debugging enabled for modules: GCodes(3)
                        Debugging disabled for modules: Platform(0) Network(1) Webserver(2) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) WiFi(14) Display(15)
                        ok
                        m292
                        ok
                        m292
                        ok
                          Can you send M122 and get a report?
                          brunofportoundefined 1 Reply Last reply Reply Quote 0
                            brunofporto @dc42
                            @dc42 Sure! Did while "busy" doing nothing after reproducing the issue:
                            M122
                            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02RC4(RTOS) running on Duet Ethernet 1.02 or later
                            Board ID: 08DGM-956GU-DJMSN-6J9D4-3SJ6S-1BNHD
                            Used output buffers: 1 of 20 (16 max)
                            Static ram: 27476
                            Dynamic ram: 98660 of which 12 recycled
                            Exception stack ram used: 496
                            Never used ram: 4428
                            Tasks: NETWORK(ready,328) HEAT(blocked,1232) MAIN(running,1660) IDLE(ready,200)
                            Owned mutexes:
                            Last reset 00:03:59 ago, cause: software
                            Last software reset at 2018-11-26 17:26, reason: User, spinning module GCodes, available RAM 4436 bytes (slot 1)
                            Error status: 0
                            Free file entries: 9
                            MCU temperature: min 24.7, current 25.8, max 26.3
                            Supply voltage: min 24.5, current 24.6, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
                            Driver 0: standstill, SG min/max 0/250
                            Driver 1: standstill, SG min/max 0/242
                            Driver 2: standstill, SG min/max 0/162
                            Driver 4: standstill, SG min/max 0/177
                            Date/time: 2018-11-26 17:30:11
                            Cache data hit count 546791891
                            Slowest loop: 51.83ms; fastest: 0.07ms
                            I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
                            Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 237, MaxWait: 95242ms, Underruns: 0, 0
                            Scheduled moves: 35, completed moves: 36
                            Bed compensation in use: none
                            Bed probe heights: -0.024 -0.046 0.000 0.000 0.000
                            Heater 1 is on, I-accum = 0.0
                            Segments left: 0
                            Stack records: 3 allocated, 1 in use
                            Movement lock held by null
                            http is doing "M291 P"Please wait while the bed and tool is being heated up" R"Please Wait" S1 T0 " in state(s) 0 0
                            telnet is idle in state(s) 0
                            file is idle in state(s) 0
                            serial is idle in state(s) 0
                            aux is idle in state(s) 0
                            daemon is idle in state(s) 0
                            queue is idle in state(s) 0
                            Code queue is empty.
                            === Network ===
                            Slowest loop: 51.30ms; fastest: 0.02ms
                            Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(2) Telnet(0)
                            HTTP sessions: 1 of 8
                            Interface state 5, link 100Mbps full duplex
                            === Filament sensors ===
                            Extruder 0 sensor: position 8.22, ok, framing errors 0, parity errors 0, no calibration data
                              Thanks. I can see two odd things in that report:
                              It is still waiting for the M291 message box to be acknowledged, as if it hasn't received M292. So sending M292 should get it running again.
                              Doing one more move than was scheduled doesn't sound right. But I don't think this is part of the problem you are seeing.
                              I'll review the M292 handling and see if there is any way that a M292 command might be missed.
                              brunofportoundefined 2 Replies Last reply Reply Quote 1
                                brunofporto @dc42
                                @dc42 Thanks!
                                I am not sure when this issues started (I think it is with this latest 2.02 series of betas and RCs) but I did not have them before with the same macros.
                                For now I'll just comment all non critical M291 from these macros 😄
                                  brunofporto @dc42
                                  @dc42 Same issue with RC5 - not using M291 S0 T0, swapped all of them to S1. The first M291 S1 message does not even appear.
                                    If it doesn't appear, no wonder it gets stuck! It's waiting for the M292 command to be returned from DWC to tell it that you have acknowledged the message box. I can't think why it wouldn't appear, other than a network issue. Does your system have a PanelDue, and if so does the message box appear on it?
                                      brunofporto @dc42
                                      @dc42 Yes I have a PanelDue. No... it does not appear there even when the macro is executed from PanelDue.
                                      Same behavior as DWC: Right after resetting the macro works (it halts at the end of the macro but works until that). But If I execute anything before it (like a G32) it does halt after the first M291 S3 as Busy and does nothing.
