Problems with new Laser Filament Monitor
@insertnamehere, in addition to submit a warranty claim, please can you:
Check the printed parts that the filament monitor PCB fits between, to make sure that the surfaces that mate with the PCB are flat, and there are no blobs or other blemishes that might stress the PCB when the screws are tightened.
Tell us what material you printed them in.
I have just added a note in the fitting instructions to advise looking for blobs that might stress the PCB. It may be that we also need to increase the thickness of the lower printed part, perhaps depending on what material it is printed with.
We don't know whether the cracked sensor is our fault because of a manufacturing defect or because we didn't make the printed part thicker in our housing design, or something you did. In these cases we give the customer the benefit of the doubt. So please make a warranty claim.
Thanks you. -
Printing with eSun olive green PLA tonight. Pretty crap numbers.
Duet3D laser filament monitor on endstop input 3, disabled, allowed movement 40% to 120%, check every 3.0mm, current position -7.3, brightness 91, shutter 17, measured minimum 27%, average 81%, maximum 204% over 4232.4mm
Back to eSun yellow PETG, and my average was 84%. My minimum was -1%.
Regarding the filament monitor, can we use Prusa MK3 filament sensor as well? Can it be connected to E0 end stop?
@shawnc said in Problems with new Laser Filament Monitor [SOLVED]:
No it cannot be used because it does not have the control circuitry on it.
No. The Prusa filament monitor uses a raw I2C interface to communicate between the sensor and the processor (and it's level shifted to 5V). We rejected that approach because I2C is a bad choice for connecting devices over more than a few cm, because of its poor noise immunity, the lack of any error detection, and the difficulty of recovering from I2C protocol errors. It may be possible to get it working reliably enough in a closely controlled system like a genuine Prusa i3, but it would be a support nightmare if used more widely, e.g. in home-build printers.
Solutech clear green PETG
Duet3D laser filament monitor on endstop input 3, disabled, allowed movement 40% to 120%, check every 3.0mm, current position -1.7, brightness 107, shutter 17, measured minimum 31%, average 79%, maximum 97% over 17533.6mm
Matterhackers Ryno clear:
Duet3D laser filament monitor on endstop input 3, disabled, allowed movement 40% to 120%, check every 3.0mm, current position -5.7, brightness 99, shutter 17, measured minimum -4%, average 69%, maximum 93% over 7284.9mm
So far my filament success rate hardly warrants using this sensor. Many dip into negative numbers.
This post is deleted! -
@hayseed_byte said in Problems with new Laser Filament Monitor [SOLVED]:
hayseed_byte 5 Nov 2017, 23:09
I really thought if I spent $180 on a board that it'd pretty much work out of the box and come with some clear instructions. I'm pretty handy with tools (I'm an industrial maintenance tech) but I've been working on this thing for two solid days and I'm still not printing. One of my Z steppers wouldn't do anything but stutter so I poked around with my multimeter for about an hour but didn't really change/repair anything and now both Z steppers are working fine but the Y stepper is going in the wrong direction. It was working fine before. Seems like random problems. Damn thing doesn't want to stay connected over wifi, either.
The cheap GT2560 I had wouldn't let me update the firmware and I got tired of having to change the stepspermm for the z-axis (upgraded to leadscrews from threaded rod). I ordered a $40 RAMPS that was basically DOA so I thought I'd go ahead and spend the money and get what everyone said was the best controller on the market because I was starting to get tired of working on my printer more than I was printing. Dropped $180USD and I've been working on it all weekend. A lot of that was spent re-crimping those damn PITA connectors, though.
I don't mean to rant. I'm just really disappointed. The cheap board had some annoying problems but at least I could print. A lot of time and money spent to make my printer worse off that it was before.
Right back at you maintenance boi.
3D Solutech black PLA
Duet3D laser filament monitor on input 3, disabled, allow 40% to 120%, check every 3.0mm, current pos 4.0, brightness 95, shutter 17, measured min 15% avg 47% max 77% over 3105.0mm
I thought I had improved things by installing a clip on top of the Bondtech to keep the sensor from moving around as much with retraction. There goes that theory.
3D Solutech silver PLA
Duet3D laser filament monitor on input 3, disabled, allow 40% to 120%, check every 3.0mm, current pos -0.5, brightness 104, shutter 17, measured min -2% avg 91% max 196% over 986.7mm
That's about the worst I have seen.
Yes, that's bad! I'm surprised, I would have expected silver PLA to be easy for the sensor to track.
@dc42 Having a lot of trouble (needed to turn it off!!!) with purple PLA from Cliever (Brazilian manufacturer)
The average below 50% but the total length very close to the theoretical from slicer - so that is curious.
@brunofporto said in Problems with new Laser Filament Monitor [SOLVED]:
The total length is the length commanded (not measured).
I've removed the [SOLVED] for this thread as clearly some users are still having issues.
Filamentum Rupunzel Silver
Duet3D laser filament monitor on input 3, disabled, allow 15% to 125%, check every 3.0mm, current pos -0.4, brightness 79, shutter 15, measured min 40% avg 93% max 181% over 12606.4mm
I have a had quite a few prints with no issues lately, but here we go. This may be no surprise with the glitter, but this is amazing filament. I started a Google Sheet to track the numbers in case I want to start actively managing each filament to adapt the laser to the filament.
