    My custom Cartesian
    My Duet controlled machine
    14
    152
    23.2k
    • wilrikerundefined
      wilriker @Phaedrux
      @phaedrux Travel combing is once again something that is enabled by default in Cura so I used it. 😁
      Thanks for your profile, I will check it and see what I can adapt into my profile from it.
      Re stringing: I think I need to tune this independent of the slicer. Mainly because I use firmware retraction but also as I think that I could use much faster retraction speed than I currently do. But I have to find out how fast I can retract.
      I need to tune a lot of things on my printer still. Acceleration, jerk, retraction... So good that I don't need this printer for anything but tinkering on the printer. šŸ™‚ I mean seriously, that's how it is. 😁
      Manuel
      My Tool Collection
      • wilrikerundefined
        wilriker
        New motors were delivered yesterday. I originally had planned to change my Z axis to belt-n-pulley setup with a 2:1 gearing (via different sized pulleys) but then there was this package waiting for me when I came home. 😁
        I measured their lengths and interestingly they differ. 3 of 4 are 46.98mm long and the remaining one is 47.16mm long. Very strange for being the same motors from the same manufacturer delivered in one box.
        I then filed flats on all shafts of the motors and started with replacing X motor (as it is easiest). Now my X axis can run 250mm/s - which at 220mm axis length + 3000mm/s² accel means it takes around 1s to get from one side to the other. Looks totally crazy as I am not used to these speeds! šŸ˜‚
        So far I cannot tell that (at same speeds as before) this motor is quieter (or louder) than the original Anet motor.
        I have wired connectors to all other motors already and will replace them today as well.
        In the process of re-tensioning my X belt I though saw that my (printed) belt tensioner was partly broken so currently printing a new one. I wanted to do this last night but all attempts failed due to an "improvement" I added to my extruder earlier last night. It was supposed to achieve better internal guiding but instead it just resulted in filament jams. 🤦
        Manuel
        My Tool Collection
        • stewwyundefined
          stewwy
          May i recommend a bondtech style extruder, night and day compared to a titan clone or mk8.
          Much less grinding of the filament, which is highly constrained, and I'm sure my extruder motor runs cooler
          pretty cheap if you buy just the gears and bearings and print the rest ☺
          P.S. how did you get on with the motors I have some on the way?
          • wilrikerundefined
            wilriker @stewwy
            @stewwy Thanks. In fact, Bondtech is on my list in case I ever run into problems - which I did not yet even with the MK8. But I never printed anything but PLA and some PETG so far. I guess once I get into flexibles this will be another story. Still I have not yet even mounted my Titan clone. Lately I have no time for tinkering on the printer at all (and this won't change before November at best) and still some modifications that I will revert - and I did not yet even post details about the mod in the first place in this thread.
            But once I get that done I will update here anyway. šŸ™‚
            Regarding the motors: I am very happy with them. They are not much quieter than the stock Anet ones (which would have been a nice bonus) but they have so much torque they just don't care about the weight they throw around. šŸ˜‚
            Manuel
            My Tool Collection
            • wilrikerundefined
              wilriker
              Here are two small updates. In the second to last image above one can see that the plug was still exposed and I also wrote that it does no longer look like that already at the time of posting the image. So here is how it looks now:
              Also I did some experimentation with my Z axis. I changed it from direct-driven via flexible coupler to a belt-driven approach where I also introduced a 2:1 reduction ratio to get my 8mm lead down to a 4mm lead. The motor is shifted to the front and attached with a separate motor holder bracket. The lead screw sits inside a printed base with a thrust bearing in the bottom and a 608ZZ bearing to take the radial forces from belt tension.
              But as I mentioned earlier I will revert this approach. The main reason for this decision is that it is virtually impossible to get the motors well aligned because the screws that fix the holding brackets to the frame are covered by the motor once it is installed. So this is an extremely tedious mount-check-unmount-adjust-loop that so far has not yielded the results I am very happy with. The belt tension is influenced a lot more than I would ever have expected by moving the motor only 10th of a millimeter. So this is no fun to do.
              I already have all the parts on my desk because I will not simply go back to how it was before but will also replace the lead screw by a 2mm lead and the coupling will be replaced by a zero-backlash jaw coupling that will eventually be suspended on a thrust bearing that sits on the motor housing so the motor shaft gets relieved of the axial downward forces. Images will follow once this is done. šŸ™‚
              Manuel
              My Tool Collection
                deckingman @wilriker
                @wilriker
                Manuel,
                Is that motor mount bracket slotted where it fixes to the extrusion so that you could raise it a bit higher? If so, you could turn the motor 180 degrees so that the shaft is pointing down, and mount the motor on top of the bracket. Then you would be able to get at the fixing bolts to set the belt tension. Or would that mean that you lose too much travel in Z due to the bed hitting the motor? Just a thought.........
                Edit. If you fitted the pulley the other way round on the motor shaft, you probably might need need to move the bracket vertically (but that won't help the bed hitting the motor).
                2nd Edit. Just scrolled up to see your original pics and it looks like the gantry moves in Z not the bed, so it might work if there is enough clearance to fit the motor that way.
                • wilrikerundefined
                  wilriker @deckingman
                  @deckingman
                  Hi Ian,
                  Thanks for this idea. It might work. The brackets are slotted and also mounted at the outside of the frame. And the bed runs strictly inside the frame (with some clearance) so there is no way the bed could ever collide with the motors - if it does I guess I have a whole different set if issues. šŸ˜‚ And yes, it's an i3 style Cartesian where the X gantry moves in Z. Whether or not the extruder carriage collide with the Z motor I cannot say right now but I don't think this would be an issue - could also be solved by just using longer belts to get the motors a little bit more to the front.
                  Anyway this approach might still not work due to some reinforcement struts (no idea how to describe this better) that are part of the bracket and makes sure it cannot fold on itself. In the image below you can see a little bit better what I mean (sorry for the bad quality, just have nothing better at hand right now)
                  They might be in the way of the belt path and I do not know whether the slots will allow me to move the motor high enough up so that an upside-down mounting approach would be able to align with the pulley on the lead screw horizontally. I might compensate a little bit by making the lead screw base a little less tall (my English is not at its best today 🤦) but there is not much to gain there. I guess 1mm max to not risk the structural stability of the base since it is not supported at the bottom (because usually this is where the motor is mounted).
                  Also having the motors where they are now also makes it very hard to get to my leveling screws since the motors are perfectly aligned to in the way. 😁 Turning them upside-down is probably the only way to make this situation even worse. šŸ˜‚
                  And last I am looking forward to a 2mm lead. Not that I ever had any issues with 8mm lead. šŸ˜„
                  EDIT: Looking a little bit closer on the image above I don't think these struts are in the way of the belt path. But from what I can tell the slots for mounting won't allow me to raise it enough to get a good alignment of the belt horizontally.
                  Manuel
                  My Tool Collection
                  • OBELIKSundefined
                    OBELIKS
                    Do you need to move it up?
                    I think that if you move the bearing on the screw above the pulley (attach it to the vertical extrusion), both pulleys will be roughly aligned.
                    P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
                    Original Prusa i3 MK3S
                    • wilrikerundefined
                      wilriker @OBELIKS
                      @obeliks said in My custom Cartesian:
                      I think this might result in a very odd and unfavorable angle to fix the bearing. If you look at the picture of the full printer in the second post you can see that it is quite a distance from the vertical extrusion to the lead screw.
                      Still, reverting-with-improvements will give me the best solution, I think. I will get an even finer Z resolution and free access to my leveling screws again. And from what I read in another thread these jaw couplings should also reduce noise a little bit (which is nice but honestly not really important on the Z axis). šŸ™‚
                      Manuel
                      My Tool Collection
                      • OBELIKSundefined
                        OBELIKS
                        Oh, I didn't notice the distance.
                        • wilrikerundefined
                          wilriker @OBELIKS
                          @obeliks Yeah, the recent images are misleading in this aspect. šŸ˜‰
                          Manuel
                          My Tool Collection
                          • stewwyundefined
                            stewwy
                            Just converted to a 2mm lead screw, now I can print at any layer height to 2 significant digits without worrying about height accuracy.
                            i.e. 0.10, 0.11, 0.12..... etc
                            Previously, with a 'normal' lead screw, the only accurate heights where , 0.1, 0.15,0.2....etc.
                            first print is on as I type ☺
                            oops, meant to mention, you are unlikely to need a reduction ratio because the torque needed is much reduced from an 8mm pitch.
                            Torque needed should be about 25% of what is needed for an 8mm pitch, the number of steps has changed from 400 to 1600.
                            • wilrikerundefined
                              wilriker @stewwy
                              @stewwy said in My custom Cartesian:
                              Just did the same today. šŸ˜‰ Images will follow.
                              That seems odd to me. What lead did your lead screw have previously? On 8mm lead it would be 0.04mm increments. To get to 0.05mm increments it would have needed a lead of 10mm. I rarely came across this type of lead.
                              I never used the reduction ratio because of lack of torque. I only used it to convert a physical 8mm lead into a logical 4mm lead. 😁
                              Manuel
                              My Tool Collection
                              • stewwyundefined
                                stewwy
                                @wilriker said in My custom Cartesian:
                                You are right, we had a party last night so still a little hazy!
                                Note to self: don't press submit without thinking it through lol
                                  deckingman
                                  As well as better resolution, you get other benefits too from using a finer lead. Effectively you get better gearing so can use a smaller motor or a single motor to drive say 3 screws via a single belt. The shallower helix angle also means that if you have a heavy bed, it will be less likely to drop under it's own own weight. I did a bit of a write up on my blog almost two years ago which explains things https://somei3deas.wordpress.com/2017/01/31/z-axis-lead-screws/
                                  stewwyundefined 1 Reply Last reply Reply Quote 1
                                  • stewwyundefined
                                    stewwy @deckingman
                                    @deckingman said in My custom Cartesian:
                                    That write up is one of the things that prompted me to order one, so thanks ☺
                                      deckingman @stewwy
                                      Blimey - that's 3 people who have read it ☺
                                      wilrikerundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                      • wilrikerundefined
                                        Does that include me already? Because I read it, too. 😁
                                        Manuel
                                        My Tool Collection
                                          Phaedrux Moderator @deckingman
                                          @deckingman I read the whole rag front to back when I was planning out my printer. There must be a few of us with more time than sense. 😜
                                          • OBELIKSundefined
                                            OBELIKS
                                            Definitely, that is a very helpful blog.
