Web interface - shutting down during printing
2.6k
    chrishamm administrators
    You can reboot WiFi by creating and running a macro file that contains
    M552 S0
    M552 S1
    When the printer becomes unusable again, could you send the output of M122 from a USB connection?
    Duet software engineer
      Jan Doubrava
      how do I run that macro when I can not connect to a web interface?
      "M122: Diagnose" surely I can.
      undefined 1 Reply Last reply 22 Nov 2018, 14:15 Reply Quote 0
        chrishamm administrators @Jan Doubrava
        @jan-doubrava You could do this either via USB or register a trigger via M581 and use an external switch. Nevertheless it would be nicer to resolve this problem but I am not sure what exactly could be causing your problem. Unfortunately I cannot reproduce it with my printer. Perhaps an M122 dump will help.
          gnydick
          I've had this happen when rapidly clicking the baby-step button
            @Jan-Doubrava, have you tried pressing F5 to reload the web interface?
            undefined 1 Reply Last reply 25 Nov 2018, 06:14 Reply Quote 0
              atfphoto
              This may be totally unrelated but I was having the same problem with the Ethernet port disappearing during long prints. Usually after the first hour or so.
              Turns out my motor and motor cables were not grounded. After I installed shielded cabling, the problem has never reappeared. Even with 23 hour prints I haven't had the problem return.
              Could be static.
              Monolith Delta Kossel - 1800mm x 700mm - Duet 3D Ethernet
                gnydick @dc42
                @dc42 yes, and disconnected and reconnected the cable.
                  Jan Doubrava
                  update - issue not resolved
                  printer was not running since last time
                  today small 2h print, web interface is down
                  I canot connect with pronterface for M122
                  repetier host returns after connect atempt
                  16:04:11.737 : Ran out of output buffers at ../src/Networking/HttpResponder.cpp(950)
                    Jan Doubrava
                    I suspect babystep button. testing if it is related
                      Jan Doubrava
                        Jan Doubrava
                        reloading did not help
                          Jan Doubrava
                          SENDING:M122
                          RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01(RTOS) running on Duet WiFi 1.02 or later
                          Board ID: 08DDM-9FAM2-LW4S8-6JTDJ-3S06Q-TJZ7W
                          Used output buffers: 13 of 20 (20 max)
                          Static ram: 28476
                          Dynamic ram: 97124 of which 16 recycled
                          Exception stack ram used: 436
                          Never used ram: 5020
                          Tasks: NETWORK(ready,328) HEAT(blocked,1240) MAIN(running,544)
                          Owned mutexes:
                          Last reset 09:34:43 ago, cause: software
                          Last software reset at 2018-11-29 22:56, reason: User, spinning module GCodes, available RAM 5036 bytes (slot 3)
                          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                          Error status: 4
                          [ERROR] Error status: 4
                          Free file entries: 10
                          SD card longest block write time: 15.8ms, max retries 0
                          MCU temperature: min 29.7, current 31.5, max 33.3
                          Supply voltage: min 1.9, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0
                          Driver 0: standstill, SG min/max 0/194
                          Driver 1: standstill, SG min/max 0/185
                          Driver 2: standstill, SG min/max 0/195
                          Driver 3: standstill, SG min/max 0/1023
                          Date/time: 2018-11-30 08:31:24
                          Slowest loop: 92.72ms; fastest: 0.07ms
                          Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 120, MaxWait: 1518588ms, Underruns: 0, 0
                          Bed compensation in use: none
                          Bed probe heights: 0.079 -0.050 -0.032 -0.084 0.055
                          Bed heaters = 3 -1 -1 -1, chamberHeaters = 2 -1
                          Heater 1 is on, I-accum = 0.6
                          Heater 3 is on, I-accum = 0.1
                          Segments left: 0
                          Movement lock held by null
                          http is idle in state(s) 0
                          telnet is idle in state(s) 0
                          file is idle in state(s) 0
                          serial is ready with "M122" in state(s) 0
                          aux is idle in state(s) 0
                          daemon is idle in state(s) 0
                          queue is idle in state(s) 0
                          Code queue is empty.
                          === Network ===
                          Slowest loop: 89.10ms; fastest: 0.01ms
                            Jan Doubrava
                            SENDING:M552 S0
                            WiFi module is idle
                            SENDING:M552 S1
                            WiFi module is connected to access point TRILAB24G, IP address 192.168.1.223
                            SENDING:M122
                            Used output buffers: 14 of 20 (20 max)
                            Static ram: 28476
                            Owned mutexes:
                            Last reset 09:38:09 ago, cause: software
                            Error status: 4
                            MCU temperature: min 31.4, current 31.7, max 32.0
                            Supply voltage: min 24.2, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0
                            Date/time: 2018-11-30 08:34:51
                            Slowest loop: 0.89ms; fastest: 0.08ms
                            Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
                            Segments left: 0
                            Still not working
                              Is it still giving that "JSON error: unexpected token" message when you try to reload DWC, or was that a one-off message?
                              undefined 1 Reply Last reply 30 Nov 2018, 15:34 Reply Quote 0
                                Jan Doubrava @dc42
                                @dc42 yes, only M999 helped
                                  Next time you get that JSON parse error message, please press F12 to get the developer console. It should display the complete unparsable JSON response. Please post that here.
                                    Jan Doubrava
                                    08:17:32.178 : Ran out of output buffers at ../src/Networking/HttpResponder.cpp(950)
                                    again 😞
                                    undefined 1 Reply Last reply 6 Dec 2018, 17:17 Reply Quote 0
                                      Jan Doubrava
                                      Is there a way to log info from web control into file? I need the info that has been lost douring the WC shutdown. (print time etc.)
                                        The print time is already logged to file if you enable logging using M929.
                                          dc42 administrators @Jan Doubrava
                                          @jan-doubrava said in Web interface - shutting down during printing:
                                          again 😞
                                          1. Did you have just one browser connected to the Duet before that happened, or multiple browsers/devices? I'm trying to work out what provokes this situation.
                                          2. I have made a change for 2.02RC6 to return a 503 status response to DWC if the firmware runs out of buffers. I hope this will allow the apparent deadlock to be broken.
                                          11 out of 25
