Web interface - shutting down during printing
2.6k
    gnydick
    I've had this happen when rapidly clicking the baby-step button
      @Jan-Doubrava, have you tried pressing F5 to reload the web interface?
      undefined 1 Reply Last reply 25 Nov 2018, 06:14 Reply Quote 0
        atfphoto
        This may be totally unrelated but I was having the same problem with the Ethernet port disappearing during long prints. Usually after the first hour or so.
        Turns out my motor and motor cables were not grounded. After I installed shielded cabling, the problem has never reappeared. Even with 23 hour prints I haven't had the problem return.
        Could be static.
        Monolith Delta Kossel - 1800mm x 700mm - Duet 3D Ethernet
          gnydick @dc42
          @dc42 yes, and disconnected and reconnected the cable.
            Jan Doubrava
            update - issue not resolved
            printer was not running since last time
            today small 2h print, web interface is down
            I canot connect with pronterface for M122
            repetier host returns after connect atempt
            16:04:11.737 : Ran out of output buffers at ../src/Networking/HttpResponder.cpp(950)
              Jan Doubrava
              I suspect babystep button. testing if it is related
                Jan Doubrava
                  Jan Doubrava
                  reloading did not help
                    Jan Doubrava
                    SENDING:M122
                    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01(RTOS) running on Duet WiFi 1.02 or later
                    Board ID: 08DDM-9FAM2-LW4S8-6JTDJ-3S06Q-TJZ7W
                    Used output buffers: 13 of 20 (20 max)
                    Static ram: 28476
                    Dynamic ram: 97124 of which 16 recycled
                    Exception stack ram used: 436
                    Never used ram: 5020
                    Tasks: NETWORK(ready,328) HEAT(blocked,1240) MAIN(running,544)
                    Owned mutexes:
                    Last reset 09:34:43 ago, cause: software
                    Last software reset at 2018-11-29 22:56, reason: User, spinning module GCodes, available RAM 5036 bytes (slot 3)
                    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                    Error status: 4
                    [ERROR] Error status: 4
                    Free file entries: 10
                    SD card longest block write time: 15.8ms, max retries 0
                    MCU temperature: min 29.7, current 31.5, max 33.3
                    Supply voltage: min 1.9, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0
                    Driver 0: standstill, SG min/max 0/194
                    Driver 1: standstill, SG min/max 0/185
                    Driver 2: standstill, SG min/max 0/195
                    Driver 3: standstill, SG min/max 0/1023
                    Date/time: 2018-11-30 08:31:24
                    Slowest loop: 92.72ms; fastest: 0.07ms
                    Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 120, MaxWait: 1518588ms, Underruns: 0, 0
                    Bed compensation in use: none
                    Bed probe heights: 0.079 -0.050 -0.032 -0.084 0.055
                    Bed heaters = 3 -1 -1 -1, chamberHeaters = 2 -1
                    Heater 1 is on, I-accum = 0.6
                    Heater 3 is on, I-accum = 0.1
                    Segments left: 0
                    Movement lock held by null
                    http is idle in state(s) 0
                    telnet is idle in state(s) 0
                    file is idle in state(s) 0
                    serial is ready with "M122" in state(s) 0
                    aux is idle in state(s) 0
                    daemon is idle in state(s) 0
                    queue is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 89.10ms; fastest: 0.01ms
                      Jan Doubrava
                      SENDING:M552 S0
                      WiFi module is idle
                      SENDING:M552 S1
                      WiFi module is connected to access point TRILAB24G, IP address 192.168.1.223
                      SENDING:M122
                      Used output buffers: 14 of 20 (20 max)
                      Static ram: 28476
                      Owned mutexes:
                      Last reset 09:38:09 ago, cause: software
                      Error status: 4
                      MCU temperature: min 31.4, current 31.7, max 32.0
                      Supply voltage: min 24.2, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0
                      Date/time: 2018-11-30 08:34:51
                      Slowest loop: 0.89ms; fastest: 0.08ms
                      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
                      Segments left: 0
                      Still not working
                        Is it still giving that "JSON error: unexpected token" message when you try to reload DWC, or was that a one-off message?
                        undefined 1 Reply Last reply 30 Nov 2018, 15:34 Reply Quote 0
                          Jan Doubrava @dc42
                          @dc42 yes, only M999 helped
                            Next time you get that JSON parse error message, please press F12 to get the developer console. It should display the complete unparsable JSON response. Please post that here.
                              Jan Doubrava
                              08:17:32.178 : Ran out of output buffers at ../src/Networking/HttpResponder.cpp(950)
                              again 😞
                              undefined 1 Reply Last reply 6 Dec 2018, 17:17 Reply Quote 0
                                Jan Doubrava
                                Is there a way to log info from web control into file? I need the info that has been lost douring the WC shutdown. (print time etc.)
                                  The print time is already logged to file if you enable logging using M929.
                                    dc42 administrators @Jan Doubrava
                                    @jan-doubrava said in Web interface - shutting down during printing:
                                    again 😞
                                    1. Did you have just one browser connected to the Duet before that happened, or multiple browsers/devices? I'm trying to work out what provokes this situation.
                                    2. I have made a change for 2.02RC6 to return a 503 status response to DWC if the firmware runs out of buffers. I hope this will allow the apparent deadlock to be broken.
                                      gnydick
                                      @dc42 I got the 503 error but the dwc still went dead after several minutes. It won't even TCP handshake on port 80.
                                      undefined 1 Reply Last reply 31 Jan 2020, 07:48 Reply Quote 0
                                        dc42 administrators @gnydick
                                        Is this still happening? There were changes made in RRF 2.04 and 2.05 to address the issue with running out of buffers.
                                        richardmckennaundefined 2 Replies Last reply 31 Jan 2020, 09:47 Reply Quote 0
                                        • richardmckennaundefined
                                          richardmckenna @dc42
                                          @dc42 Recently, I'm seeing this on a my Duet2 WiFi running 2.x not sure of the exact version, but will check when I go home at lunch. I've not updated it in a while as other than this it has been running fine.
                                          I access DWC to start the print usually from my iPad, leave the browser/put the iPad in standby or something along those lines. Go back to check the status an hour or so later, refresh the page as it says it has lost connection, it will not load.
                                          The strange thing about it, up until a few weeks ago it did not happen and connected fine each time. I've not updated the firmware on it in several months.
                                          Let me check what Firmware/DWC versions I'm running and if needed I will update to the latest RRF 2.x to see if it still happens.
