Precision Piezo for E3D V6 Threaded Heatsink
I had a look at this earlier before posting this, I should have specified that the machine is a Corexy and not a Delta. I have been trying to search for how you have implemented the contact sensor with the heatsink but wasn't able to find much information. Is there any chance you are planning on developing something like this for a Cartesian system.
you could also have a look at this thread link text
@dougal1957 Thank you so much, I never saw that page
I have a threaded heatsink and it should be trivial to design a mount for it and the Orion. The only reason I haven't done it yet is that nobody's asked for it and as far as I can see the uptake of threaded heatsink has not been huge. Give me a day or two and I'll see what I can come up with.
Idris
Well if you can design a mount for it, I would be happy to purchase the Orion module for testing, ideally later I would try to incorporate the design to work with my aluminium milled part.
@rikesh942018 said in Precision Piezo for E3D V6 Threaded Heatsink:
I wanted to know if anyone has tried the Precision Piezo Sensor on the E3D Threaded Heatsink design:
I have actually just done this with a mini kossel that I am retrofitting. It does not use the smart effector, but one of my own design. It is presently in pieces awaiting linear rails however.
@zzing said in Precision Piezo for E3D V6 Threaded Heatsink:
Mind sharing the design? I can try to look into adapting the design for my machine.
First prototype mount for the threaded heatsink. Print with 0.2mm layer height.
Idris
@moriquendi said in Precision Piezo for E3D V6 Threaded Heatsink:
Idris
Thanks for the quick design, you have a new buyer for the Orion Module
@moriquendi Idris If you remember I asked about this some time ago but I was more interested in a bare pub that would take the threaded heatsink however this solution may well work for me. Do you have a render showing how it all fits together?
Doug
I don't think (at the moment) that there's sufficient market for a PCB specifically for the threaded heatsink though hopefully that will change, the groove mount is... suboptimal.
This however involves much less investment.
Green is the new part specific to the threaded heatsink.
Blue is a standard Orion top piece, either screwmount (shown) or threaded or a custom part.
Purple is the Orion PCB.Idris
@moriquendi ah so the thread it integral to the mount then?
Yes, it's actually very secure even when tightened by hand.
@moriquendi how about in a heated chamber tho?
May well print one and check it out tho and order a orion to see how it works out.
I think that you would be able to print a mount in nylon or some other material that would hold up in a heated chamber up to the temperature where the piezos would become unreliable anyway (somewhere around 80c I would expect)
Idris
@zzing Thanks for uploading this
@rikesh942018 I've just uploaded the step file to thingiverse, follow the link above.
Idris
I sent the file to Shapeways and expecting the print later today in SLS printed Nylon should be ok I hope.
