    CR-10S + Duet Wifi: Print Quality Issues
    3.3k
      It would be helpful to see a calibration cube printed before you did the conversion, and also your Marlin and Duet config settings so that we can see whether you have changed any speeds, accelerations etc.
      NexxCatundefined 1 Reply Last reply Reply Quote 0
      • NexxCatundefined
        NexxCat @dc42
        @dc42 I, unfortunately, don't have a calibration cube from prior to the conversion, but I do have a second CR-10S that is configured identically (with the exception of the Z-probe) to this one, pre-conversion of course. They both ran the same build of the firmware, same mods, etc.
        As for the Marlin config I was / am using, all the feed rates, speeds, jerk, etc are all the default:
         * Default Axis Steps Per Unit (steps/mm)
         * Override with M92
         *                                      X, Y, Z, E0 [, E1[, E2[, E3[, E4]]]]
        #define DEFAULT_AXIS_STEPS_PER_UNIT   { 80, 80, 400, 95 }
         * Default Max Feed Rate (mm/s)
         * Override with M203
        #define DEFAULT_MAX_FEEDRATE          { 2500, 2500, 100, 25 }
         * Default Max Acceleration (change/s) change = mm/s
         * (Maximum start speed for accelerated moves)
         * Override with M201
        #define DEFAULT_MAX_ACCELERATION      { 500, 500, 100, 10000 }
         * Default Acceleration (change/s) change = mm/s
         * Override with M204
         *   M204 P    Acceleration
         *   M204 R    Retract Acceleration
         *   M204 T    Travel Acceleration
        #define DEFAULT_ACCELERATION          575    // X, Y, Z and E acceleration for printing moves
        #define DEFAULT_RETRACT_ACCELERATION  1000    // E acceleration for retracts
        #define DEFAULT_TRAVEL_ACCELERATION   1000    // X, Y, Z acceleration for travel (non printing) moves
         * Default Jerk (mm/s)
         * Override with M205 X Y Z E
         * "Jerk" specifies the minimum speed change that requires acceleration.
         * When changing speed and direction, if the difference is less than the
         * value set here, it may happen instantaneously.
        #define DEFAULT_XJERK                 20.0
        #define DEFAULT_YJERK                 20.0
        #define DEFAULT_ZJERK                  0.4
        #define DEFAULT_EJERK                  5.0
        I admit that most of the settings regarding speeds & jerk were based upon other people who had done the conversion for a CR-10S, not calculated from my Marlin configuration. Rather than in-line my full Marlin config here, I've chucked it up on Github: https://gist.github.com/nexx/2e5d44e1eea566e27b831a9f222a8131
          Looking more closely at your cubes it looks like Simplify3D is alternating your start point. Try aligning it to a single corner.
          dc42undefined NexxCatundefined 2 Replies Last reply Reply Quote 0
            dc42 administrators @Phaedrux
            From your config.g:
            M566 X1200 Y1200 Z24 E300 ; Set maximum instantaneous speed changes (mm/min)
            M203 X6000 Y6000 Z900 E1500 ; Set maximum speeds (mm/min)
            M201 X500 Y500 Z100 E10000 ; Set accelerations (mm/s^2)
            From your Marlin config:
            So you have the same acceleration and jerk configured in both (allowing for jerk being in mm/min for RRF and in mm/sec for Marlin), however you have substantially higher maximum speeds (feedrate) configured in M203 than you had in Marlin.
            • NexxCatundefined
              NexxCat @Phaedrux
              Sorry for not getting back sooner, I'd been working on getting both printers set up next to each other so I can literally print two calibration cubes one after the other.
              @phaedrux said in CR-10S + Duet Wifi: Print Quality Issues:
              I'm going to print both again, with a darker filament which shows the surface quality better, and using the same g-code on both. This will have the layer transitions all pinned in the same place.
              @dc42 said in CR-10S + Duet Wifi: Print Quality Issues:
              From your config.g:
              As far as I can tell, the max feedrate in Marlin is in mm/s, and RRF is in mm/min, so wouldn't that make the Marlin ones actually much higher? (150000, 150000, 6000, 1500)? I know the Z movement speed on my CR-10 maxes out at around 1200mm/min before it starts to bind or skip.
                Phaedrux Moderator @NexxCat
                @nexxcat Yes, Marlin typically uses mm/s so your values aren't too crazy really.
                1mm/s = 60mm/min, so 6000mm/min = 100mm/s which is actually kind of low for travel moves.
                • Denisundefined
                  Denis
                  Have you solved your problem? I also got a deterioration in print quality and similar layers on Z after leaving Marlin. I have no idea why this happened ..
                  These are my prints on Duet
                  These are my prints on Marlin
                    dc42 administrators @Denis
                    @denis said in CR-10S + Duet Wifi: Print Quality Issues:
                    I'm sorry, it's impossible for me to compare the photos because they are of different faces and taken at different distances. Can you take a photo of a print of the X face from a Duet print, at the same scale as your Marlin print?
                    Also please post your Duet config.g file and the Marlin settings you were using.
                    Denisundefined 1 Reply Last reply Reply Quote 0
                    • Denisundefined
                      Denis @dc42
                      Now I can't publish the same photo, because I remade the plugs for the duet. At the moment I am working on replacing wires and connectors so that both boards can be connected. As soon as I finish, I will publish all the comparisons. (files, photos, etc.)
                      • NexxCatundefined
                        NexxCat @Denis
                        @denis Sorry, yeah. I ended up solving the issue by replacing the extruder entirely. I'm now running a Bondtech BMG extruder and prints are now the same between Marlin and Duet. Not the answer you're looking for, but I had tried everything else prior to this.
                          Thanks for letting us know. What extruder were you using before, and what steps/mm did it use @ x16 microstepping?
                            deckingman @dc42
                            His config file above shows 95 steps per mm @16X, which would indicate an ungeared extruder.
                              dc42 administrators @deckingman
                              @deckingman said in CR-10S + Duet Wifi: Print Quality Issues:
                              Thanks, Ian. In that case, using higher extruder microstepping would probably have fixed it.
                              • NexxCatundefined
                                NexxCat @dc42
                                @dc42 @deckingman Indeed. It was the stock CR-10S extruder which was ungeared with a 1.8 degree stepper. Really amazed by the quality difference the Bondtech BMG made, on both Marlin and the Duet 😃
                                Keep up the great work!
