    Axis stop working....
    hard
    2.1k
    • peirofundefined
      peirof
      hi,
      i have do what do you say.... and news:
      M122 AFTER POWER ON AND HOMING:
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02RC4(RTOS) running on Duet WiFi 1.02 or later
      Board ID: 08DGM-956GU-DJMSN-6J1DJ-3S86S-K9RBH
      Used output buffers: 1 of 20 (7 max)
      Static ram: 27476
      Dynamic ram: 98612 of which 0 recycled
      Exception stack ram used: 344
      Never used ram: 4640
      Tasks: NETWORK(ready,400) HEAT(blocked,1232) MAIN(running,3524) IDLE(ready,200)
      Owned mutexes:
      Last reset 00:02:47 ago, cause: power up
      Last software reset at 2018-11-25 08:00, reason: User, spinning module GCodes, available RAM 4616 bytes (slot 3)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04417000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
      Error status: 0
      Free file entries: 10
      MCU temperature: min 21.8, current 28.0, max 28.1
      Supply voltage: min 24.2, current 24.5, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
      Date/time: 2018-11-29 07:42:02
      Cache data hit count 600795165
      Slowest loop: 3.16ms; fastest: 0.07ms
      I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 234, MaxWait: 129453ms, Underruns: 0, 0
      Scheduled moves: 5, completed moves: 5
      Bed compensation in use: none
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 14.11ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        WiFi firmware version 1.21
        WiFi MAC address 5c:cf:7f:76:73:23
        WiFi Vcc 3.33, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 15048
        WiFi IP address 192.168.1.200
        WiFi signal strength -34dBm, reconnections 0, sleep mode modem
      i haved manual move the axis near end stops, and X axis NOT move up, to endstps, but moves down and after down... seems how only moves down... maybe axis endstops its triggered??
      and... second test... after homing, i have comisioned Duet Z move... and this motors works.... but only to a limit....
      • peirofundefined
        peirof
        NEWSSSSSSSSSSSSSSSSSSSSSS, FIND IT, THINK....
        GGRRRPSSS I HATE WIRES
        • MikeBundefined
          MikeB
          i have the same issue. and it doesn't show any movement but i hit homing. z axis just buzzed a very long time. i wanted to hit reset but new i would lose data so i let it go. i did try turn off motors during and nothing stopped it. feeling so frustrated and alone!
          • MikeBundefined
            MikeB
            10:41:45 AM
            M122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet WiFi 1.02 or later
            Board ID: 08DGM-9T6BU-FG3SN-6JKD8-3SD6S-9VZHD
            Used output buffers: 3 of 20 (9 max)
            Static ram: 28380
            Dynamic ram: 95784 of which 0 recycled
            Exception stack ram used: 348
            Never used ram: 6560
            Task NETWORK ready, free stack 460
            Task HEAT blocked, free stack 1256
            Task MAIN running, free stack 3624
            Last reset 00:04:55 ago, cause: software
            Last software reset at 2018-12-09 10:36, reason: User, spinning module GCodes, available RAM 6560 bytes (slot 0)
            Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
            Error status: 0
            MCU temperature: min 33.4, current 33.7, max 34.2
            Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0
            Driver 0: standstill, SG min/max 0/196
            Driver 1: standstill, SG min/max 0/0
            Driver 2: standstill, SG min/max 0/45
            Date/time: 2018-12-09 10:41:44
            Slowest loop: 4.75ms; fastest: 0.07ms
            Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 236, MaxWait: 204372ms, Underruns: 0, 0
            Scheduled moves: 14, completed moves: 14
            Segments left: 0
            === Network ===
            Slowest loop: 14.22ms; fastest: 0.01ms
            • WiFi -
              WiFi MAC address 84:f3:eb:41:d5:02
              WiFi Vcc 3.42, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 17112
              WiFi IP address 10.0.0.2
              WiFi signal strength -41dBm, reconnections 0, sleep mode modem
              === Expansion ===
            • MikeBundefined
              MikeB
              z axes just humming like not enough current.
              this was working perfect for weeks.
              i just dont understand.
              • peirofundefined
                peirof
                have you tried to connect the stepper not working to another axis?
                  dc42 administrators @MikeB
                  @mikeb said in Axis stop working....:
                  The most likely reason is a bad crimp connection in that motor cable. A failed driver chip is another possibility.
                  • MikeBundefined
                    MikeB
                    i will ohm out the wires and try to use different axis driver. thank you for response! thank you
                    • MikeBundefined
                      MikeB
                      ok i hooked up two spare motors and what happened was both are buzzing but one turned as normal and other was back and forth couple of steps. think check crimps one one not turning as normal.
                      • Catalin_ROundefined
                        Catalin_RO
                        As a side note to this issue, and any other issue that might be related!
                        I had a project in which we used huge amounts of connectors pretty much identical to the ones used on the Duet boards. It was not the first project, as I had very good previous experience with the same type of connectors. Some if the guys crimping the pins on the wires misplaced them in the crimping tool and they have squeezed the contact area way to much. We had to get the pins out of the plastic bodies and re-spring them for quite a few of the cables. The problems were random, so finding the actual cause was anything but simple!
                        Also, we saw that even "compatible", these connectors are not 100% identical between manufacturers, with slight variations in the latching dents and the actual pin shape. If all sourced from the same manufacturer, everything is OK. But this is a relatively low cost connector, though a pretty well designed one, so there are a lot of manufacturers and only few suppliers guarantee the manufacturer (go for big suppliers like Farnell, Mouser, DigiKey, TME in order to have guaranteed supplier, but avoid generic ones - like Multicomp for Farnell). I think on Duet the connectors are from Wurth!
                        • MikeBundefined
                          MikeB
                          im still using supplied ones from e3d.
                          • MikeBundefined
                            MikeB
                            update...i updated my firmware and that fixed my motor issue on z axes.
                            but now i have no controle of my eo heater and the bed thermister is what both eo and bed are displaying. crazy
                            MikeBundefined 1 Reply Last reply Reply Quote 0
                            • MikeBundefined
                              MikeB @MikeB
                              @mikeb ALL FIXED NOW. i fixed numbering of heaters and thermisters. the configurator had it all messed up. never did that before. was same config as before. guess update changed something. THANKS FOR ALL HELP EVERYONE.
                              • MikeBundefined
                                MikeB
                                ok now z motors stuttering again. started in middle of a print! i just cant win
                                • MikeBundefined
                                  MikeB @MikeB
                                  @mikeb i figured out one of the motors has let the carriage get in a bind(one side 3/4 turn off). ?
                                  • MikeBundefined
                                    MikeB
                                    think i will get e3d 2.0a stepper x1 and go overhead belt drive to remedy this. think im having motor issues. and i wont have to check that they are equal all time also(x2 z motors now). if anyone has a clue whats going on please tell me.
