    Configuring 12864 LCD on Maestro?
    79
    23.9k
    • Agniusmundefined
      Agniusm @3dmntbighker
      @3dmntbighker, Yes, there is consensus. There are 2 ways you can connect your display.
      1. You use your cable, cut one end on it, get some dupont connectors and wire it according to this diagram:
        If encoder is reversed, you flip 2 bottom wires(as per pic) on Duets EXP2(left connector on pic)
      2. method is to use 2 10pin cables(so you need to buy another one)
        a. on duet, connect it normal way
        b. on ender 3 display, connect it flipped where locator clips face beeper.
        Duet exp1 to LCD exp1 flipped
        Duet exp2 to LCD exp2 flipped
        Dont forget to add M918 P1 E4 to your config.g
      dc42undefined 1 Reply Last reply Reply Quote 3
      • Agniusmundefined
        Agniusm
        Some more of the insights. Using two cable method lcd shows some artifacts. When connected to exp3 and using diy'ed single cable artifacts are absent
          dc42 administrators @Agniusm
          You can also reverse the encoder direction in the M918 command that configures the display and encoder.
          • 3dmntbighkerundefined
            3dmntbighker
            Thanks for all the help. My cables will arrive tomorrow.
            Has anyone determined if the Ender display can support the second SD card? And what may be lacking to add it? Just curious if a full size SD card is possible to add.
            Scratch built CoreXY with Maestro
            Heavily modified Ender 3 with Maestro
            MPCNC work in progress with Duet WiFi
              3dmntbighker
              My cables arrived, and I have the display working. It seems the default menu system with RC5 doesn't work out of the box. I messed around a bit before leaving for work, but has anyone put together a working menu system (starting point) for the Ender 3. It appears that a single file makes the whole RC5 menu system operate named "menu" that is absent on my Maestro. (edit: OK, I noticed this is mentioned in the RC5 release notes, so I guess DC is workin on it already)
              I also notice the artifacts mentioned with the two cable solution. I hope we can track down the cause at some point.
              Thanks to everyone who has pitched in.
              • Agniusmundefined
                Agniusm
                Adding SD card to the LCD is no go. You can add it as a separate module you can get on ebay for few quid:
                Just for illustration:
                https://www.ebay.com/itm/3D-printer-SD-external-card-reader-MKS-Slot-V1-1-and-MKS-Slot2-2-8-inch-U-disk/222920755412?hash=item33e71cc8d4ⓂmatuTHLib1EHTKR3OVhUcHw:rk:1:pf:0
                I have attached somewhat fixed basic menu few posts above
                  3dmntbighker @Agniusm
                  @agniusm said in Configuring 12864 LCD on Maestro?:
                  @arnd13
                  Looks like vcc, gnd, buzz and enc_sw will work on exp1, you only need to cut slot in lcd connector and flip ribbon cable?! I will try that.
                  Another way is just to cut ribbon cable and crimp dupont pins, then use connectors found on pc for power,hdd, reset. They come in multiple sizes and could be salvaged
                  I just filed off the bit on the cable connector that indexes the cable. Less than a minute and I didn't butcher the board 😉
                  Agniusmundefined 1 Reply Last reply Reply Quote 0
                  • Agniusmundefined
                    @3dmntbighker I know, but its just easier to nip the slot out with snips 🙂
                    3dmntbighkerundefined 1 Reply Last reply Reply Quote 0
                      If I want your opinion I'll tell you what it is 😉 🙂 😉
                      • Agniusmundefined
                        Agniusm
                        Sorry, what?
                        3dmntbighkerundefined 1 Reply Last reply Reply Quote 1
                          Sorry, what?
                          Kidding dude 😉
                            3dmntbighker
                            Are the menu files that M3D ships on the Maestro available zipped somewhere? My SD card bit the dust today, and I had no backup. Yeah, so a backup admin for NASA had no backup. Ughhh. I got the ones agniusm linked, but I'd like the original ones, or for that matter a zip file of the entire SD card. All I could find was the generic one without the menu directory.
                              dc42 administrators @3dmntbighker
                              I've put a copy on the ones that came on my Crane at https://www.dropbox.com/s/f6jthzr7vh8619g/MenuFiles.zip?dl=0. They may not be up to date, and they could almost certainly be simplified.
                                3dmntbighker @dc42
                                @dc42 said in Configuring 12864 LCD on Maestro?:
                                Thanks bro
                                • Cataundefined
                                  Cata
                                  I'm tired of waiting support in the duet for this lcd, buy 2 maestro to enjoy a simple lcd on my printers
                                    dc42 administrators @Cata
                                    @cata, the Duet WiFi and Ethernet do not have the hardware needed to level shift the LCD signals to 5V and gate the SPI clock for compatibility with common 12864 LCD/encoder combos. That's the main reason why the firmware builds for those boards don't include the 12864 support.
                                    Cataundefined 1 Reply Last reply Reply Quote 0
                                    • Cataundefined
                                      Cata @dc42
                                      @dc42 a level shifter is too basic to implement, not the same with the firm support. Why not implement in the firm and let the users works with the level shifter?
                                      • Vetiundefined
                                        Veti
                                        considering you need an adapter for the ramps to connect an lcd this would not be much different
                                          3dmntbighker
                                          Is anyone working on the print from SD card functions? It seems like the most glaring thing that's missing from what ships with a Maestro. I'm fully aware that this a back burner project for the devs.
                                          • Vetiundefined
                                            Veti @3dmntbighker
                                            @3dmntbighker
                                            not sure what you mean.
                                            the files uploaded to the maestro are stored on the sd card. you can select those and print them.
                                            also you can select them from the lcd and print them
