Paneldue 7i not connecting to Duet 2 wifi
813
    Excelon
    After setting up the Duet 2 Wifi and getting the printer functioning (not printing but all axis working) I connected the Paneldue 7" but in the top right hand corner it displays "CONNECTING".
    Duet 2 wifi is running 2.02RC5
    Paneldue is V2 running 1.21.2
    I am a total noob so please excuse if I am missing the obvious but I am switching over 2 machines to Duet 2 wifi boards.
      1. On the Settings page of PanelDue, check that the baud rate is set to 57600.
      2. If you have a M575 P1 command in your config.g file on the Duet, check that the B parameter in it is also 57600.
      3. Are you using the ribbon cable or the 4-way cable? If it's the 4-way cable, check that the Transmit and receive data pins are properly connected.
      undefined 2 Replies Last reply 15 Dec 2018, 17:41 Reply Quote 0
        Excelon @dc42
        @dc42 FIXED!!! Thank you. More questions to come...
          Excelon @dc42
          @dc42 Question.... Should I be able to see the contents of the SD card in the Duet board from the Paneldue?
          undefined 1 Reply Last reply 15 Dec 2018, 17:46 Reply Quote 0
            dc42 administrators @Excelon
            @excelon said in Paneldue 7i not connecting to Duet 2 wifi:
            Yes, press the SD card icon on the Control page and you should see the GCodes file list.
            undefined 1 Reply Last reply 15 Dec 2018, 17:51 Reply Quote 0
              Excelon @dc42
              @dc42 When I do it says "Files on card 0"
                Do you have any files in the /gcodes folder of that SD card?
                undefined 1 Reply Last reply 15 Dec 2018, 18:05 Reply Quote 0
                  Excelon @dc42
                  @dc42 At the time, no. I transferred a file over to the /gcode folder and was able to see it on the Panledue. It's my understanding that you are only able to see files in the /gcode folder to select for printing?
                  undefined 1 Reply Last reply 15 Dec 2018, 18:41 Reply Quote 0
                    Yes, you can see files in /gcodes and its subfolders. If you press the Macros button, you can see files in /macros and its subfolders.
                    3 out of 9
