    Duet Wifi fans not working
    3.2k
      If none of the fan outputs is working (even the always-on outputs):
      • Check that you have a jumper on the V_FAN jumper block, to connect the centre pin either to the VIN pin or to the 5V pin
      • If your Duet is revision 1.03 or later, check the 1A blade fuse
      • 3DRikatundefined
        3DRikat
        Thanks for you answer. None of the outputs is working (including the always-on outputs). The jumper is on the V_FAN jumper block and connects to the VIN pin. I checked the 1A blade fuse and it's working. I have the latest Duet version.
        Is there something else I can do?
          Concentrate on getting the always-on outputs working. First of all, do you have the fan red (+) and black (-) wires connected the right way round? Are you sure that the fan works?
          • 3DRikatundefined
            3DRikat
            When I started I connected it the wrong way, now it’s correctly connected. Could it be that something is broken with the fuse still in tact?
              Connecting a fan the wrong way round may have blown the MOSFET controlling any controlled fan output that you connected it to, and the 1A fuse if you connected it to an always on output. So with power off use a multimeter to check for continuity across the fuse, from the fuse to the VIN side of the fan voltage selector jumper block, and from the centre pin of that block to the positive (V_FAN) pin of the fan output.
              • 3DRikatundefined
                3DRikat
                I checked everything for continuity and everything is working. What else could I do?
                  Are you sure that the fan is still OK?
                  • 3dmntbighkerundefined
                    3dmntbighker
                    One thing counterintuitive to a lot of people is if you have one fan connected wrong or maybe bad it can kill them all. I presume it drags the supply down? It's happened to me. I got lucky and no damage occurred.
                    Scratch built CoreXY with Maestro
                    Heavily modified Ender 3 with Maestro
                    MPCNC work in progress with Duet WiFi
                    • 3DRikatundefined
                      3DRikat
                      I connected the fan to the always-on output and it's working but if I connect it to the PWM output it is not.
                        dc42 administrators @3DRikat
                        @3drikat said in Duet Wifi fans not working:
                        Which PWM output? There are 3. Of these, Fan 1 output defaults to thermostatic control based on hot end temperature, so you can't control it directly using M106 Snn command unless you disable the thermostatic function first.
                        • 3DRikatundefined
                          3DRikat
                          I tested all 3 of them. No one seems to be working.
                          • elmoretundefined
                            elmoret
                            Could you post a clear, well lit photo of the area of the board around the fan headers?
                            • 3DRikatundefined
                              3DRikat
                              • 3DRikatundefined
                                3DRikat
                                Is this ok? What is it that you can see on a picture like that?
                                • elmoretundefined
                                  elmoret
                                  I can see blown FETs, at least one, possibly two, perhaps the third is damaged in a way that is not visible.
                                  Connecting incorrectly likely damaged the FETs.
                                  • 3DRikatundefined
                                    3DRikat
                                    What can I do about that? Is it possible to replace them?
                                    • elmoretundefined
                                      elmoret
                                      Sure, if you have a hot air rework station, or are skilled with a regular soldering iron.
                                      https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers
                                      • 3DRikatundefined
                                        3DRikat
                                        I will try it. Could you please mark the components on the picture. Because I am not 100% sure which one to desolder. And do I have to order PMV40UN2 or PMV40UN2R?
