    Sensorless detection for Z max
    1.2k
      You could create a macro called HomeZmax that configures a Zmax endstop as stall detection, configures the stall detection parameters, configures temporary speed, accel, and jerk settings for the Z axis, reduces motor current, and then does a zmax homing move. All the pieces are there in the documentation to be put together.
      Something like...
      ; HomeZMax.g
      ; Called to home Z to max endstop
      ; Uses the Z axis StallGuard detection as a Z-Probe
      M291 R"Are you sure?" P"Press OK to Home to ZMax. Or Cancel to abort." S3
      M574 Z2 S3			; Set motor stall at the high end for Z Max.
      M915 (whatever driver and stall detetion parameters)
      M201 Z20 ; set whatever z axis acceleration you need for consistent stall detection without triggering false positives
      M913 Z30 ; set lower z motor current
      G91				; Relative positioning
      G1 S1 Z330 F300			; Move bed until endstop triggers
      M291 P"Probing complete. Restoring settings." S3
      M913 Z100   		      				; restore current to 100%
      M201 Z300 						; Restore acceleration
      M915 Z S63 F1 R0					; Set StallGuard sensitivity for normal movement
      M574 Z1 S2						; Use zprobe and home to Z Min.
      But this would need to be customzied for your own setup.
      • jckrayundefined
        jckray
        Yes, this is possible. I used this for a while on my printer but ended up switching to a limit switch as my printer is fully enclosed and when printing high temp materials the temperature inside the enclosure was affecting the stall guard sensitivity. This resulted in a lot of false triggers when homing to z max. If you want to give it a go I described how below.
        In your config.g
        Configure Z max endstop with stall detection via M574
        Configure stall guard sensitivity etc for the Z motor driver using M915
        Now you can home z with something similar to the following
        M400 ; make sure everything has stopped before we make changes
        G91 ; use relative positioning
        G1 S1 Z9999 F1500 ; home z
        G90 ; back to absolute positioning
        M400 ; make sure everything has stopped before we reset the motor currents
        John
        Founder of Hydra Research LLC, developers of the open-source 3D printers and providers of 3D printing services.
        https://www.hydraresearch3d.com/
        • Torroundefined
          Torro
          The thing is, my Bed is very heavy and when the Motors are disabled, it falls down. So in the end Script i added a g1 z278 and then Shut off to minimize the impact. 280mm is maximum.
          now, i want the printer to drive slowly to z max and when stall is detected, Motors off and M81.
          I'll try to write something and post it here for check.
          Thanks!
          • Torroundefined
            Torro
            I hope that should do it:
            M574 Z2 S3
            M915 P2 S10 F1 R0
            M913 Z40
            G91
            M208 Z300
            G1 S1 Z300 F500
            M18
            M81 S1
            Speeds, Motor current and the S Parameter of M915 are not final. I just guess...
            I need that only when prints are finished.
            Thanks!
            • Torroundefined
              Torro
              It works almost...
              the updated value for Z max works and it drives until it "crashes" softly.
              but the Motors try to go further.
              I tried S values from - 40 to 40.
              Z current from 30 to 50%
              Speed at F500 feels good, tried 700, same behaviour.
              The belt does not "jump" ober the pinion.
              is the S value in the Negative area more sensitive? Or the opposite?
                You may need to move faster to get a good stall.
                Torroundefined 1 Reply Last reply Reply Quote 0
                • fcwiltundefined
                  fcwilt
                  If you have a Z-min endstop and you have homed the Z axis you know where Z-max is and you only need to issue a move to that value.
                  Why is that not acceptable?
                  • Torroundefined
                    Torro @Phaedrux
                    @phaedrux said in Sensorless detection for Z max:
                    that was it! thank a lot!
                    G1 S1 Z300 F3000
                    i had to reduce the acceleration as well. But now, it´s perfect.
                    Now, i could store it in stop.g or in the endscript from s3d. which would you prefer?
                    • Torroundefined
                      Torro
                      is there any other case, than a finished print, that causes to run stop.g?
                      I have to add a M0 in the slicer endscript to activate stop.g , correct?
                      What, if the endscript contains a M81 S1? Has the M0 to stand before or after the M81? i guess before, but "remebers" the duet the command after processing the stop.g?
                        I prefer to have all my end gcode contained in stop.g and the slicer only has M0. I use multiple slicers regularly so it's easier to just modify one place than each slicer.
                        You can put your stall code in stop.g and then at the end have M81 S1
                        • Torroundefined
                          Torro
                          Ok Thanks again!
