    AM8 config issues - cannot home any axis
    3.0k
    • Thoemseundefined
      Thoemse
      Just endstop. I found another thread with exactly the same issue tho. His Z also went up and down erratically.
      Apparently two z motors in series on a 12v PSU are too much. That guy fixed it by using another stepper for Z 2. I will try this in the evening.
        Have you tested your endstop switches? It sounds to me that you have configured or wired them incorrectly.
        https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Test_endstop_switches
        Two Z motors in series may be OK on 12V, depending on the type of motor.
        Thoemseundefined 1 Reply Last reply Reply Quote 0
        • Thoemseundefined
          Thoemse @dc42
          @dc42 homing doesn'
          t even get to the endstops. The z motors run uneven. First one than the other with a horrible grinding noise because x axis gets uneven as result. It is not a mechanical issue though.
            Please post your config.g file as @Phaedrux requested.
            • spunone69undefined
              spunone69
              I just got my Duet Wifi setup as a CoreXY and its doing the EXACT same thing! I can open Pronterface or Simplify 3D and move the axes in any direction, but when I home any of them it moves Z up and down and X or Y moves only a few millimeters...what is the issue?
                spunone69
                And if I try to home Z it just goes up and down once or twice...
                • Thoemseundefined
                  Thoemse
                  Ok. Z motors run ok now that they are not in series anymore.
                  Homign does not work at all though. Homing X and Y moves Z axis still.
                  Homing Z axis runs the axis down into the switch that does not work and it keeps on running intothe switch - the switch actually died broke this.0_1545766351395_config.g
                  • Vetiundefined
                    Veti
                    thats why dc posted the link. use the m119 command to test each endstop manually first.
                    • Thoemseundefined
                      Thoemse @Veti
                      @veti
                      Yeah makes sense. But can you see faults in the config.g?
                      I am far from anything workable. The hotend throws out a fault. The fans have no power (allways on fans as well - 12V fans, 12V PSU).
                      No endstops. A moving Z axis when tryign to home X or Y. I don't even know where to start really.
                      I never had trouble with marlin but this leaves me puzzled.
                      • wilrikerundefined
                        wilriker
                        So, unless you have also changed the lead screw then your steps/mm for Z are 10x too high. They should be set to 400.
                        Also your steps/mm for X and Y are too low if you did not replace the pulleys by 20T versions. Original Anet A8 has 16T resulting in 100 steps/mm.
                        Then there is no endstop for Z configured at all. And the one for Y is set to active high where default Anet wiring of the endstop is active low.
                        The original Anet motors run on Z in series - that's how I had mine running for months also with the original 12V PSU.
                        Manuel
                        My Tool Collection
                        Thoemseundefined 2 Replies Last reply Reply Quote 0
                        • Vetiundefined
                          Veti
                          M574 Y1 S1 ; Set active high endstops
                          M574 X1 S3 ; Set endstops controlled by motor load detection
                          Normally the a8 switches are NO if i remember correctly. You configured NC for Y.
                          X is stall detection and not via switch. Is that correct?
                          Check the wiring on the fans. if you swapped them the wrong way the fuse might be blown.
                          See https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans
                          . If you connect the fan the wrong way round, you may damage the fan, the Duet, or both.
                          • Thoemseundefined
                            Thoemse @wilriker
                            @wilriker
                            Thanks a lo. I will look into it. The Endstops were the wrong way round. Fault number one solved as well.
                            Sorry for my stupid questions. I am new to this. I thought the basic config of RFF config tool will get me somewhere. I found no basic values to start with for the anet.
                            X stall detection is because one switch died. I just fixed it though - back to endstop.
                            • wilrikerundefined
                              wilriker @Thoemse
                              @thoemse The easiest way to get the correct values is the use Marlin's appropriate Configuration.h and Configuration_adv.h. These have all the working values in there.
                              But this reminds me again that I wanted to create a template for Anet A8 in RRF Configurator. But that will probably only happen at the beginning of next year.
                              Manuel
                              My Tool Collection
                              • Thoemseundefined
                                Thoemse @wilriker
                                @wilriker
                                Changed steps. Thank you.
                                Edit: Fantastic. Making progress. All endstops working. Axis are homing.
                                Now On to the hotend and the no power on fans issue. I shall read up on it first though. I went at this a bit to unprepared.
                                Thanky ou very much btw. I am starting to get the hang of it.
                                • Thoemseundefined
                                  Thoemse
                                  Fixed the fan. I got an issue with z homing. It tries to home on top but I got a min Z endstop.
                                  Considering it lifts z correctly before homing X and Y I think the Z axis direction should be correct.
                                  I've added the z homing file.
                                  I am sorry for all the questions.0_1545818773565_homez.g
                                  • wilrikerundefined
                                    wilriker @Thoemse
                                    @thoemse said in AM8 config issues - cannot home any axis:
                                    What happens if you issue the following commands?
                                    G91
                                    G0 Z5 H2
                                    G90
                                    It should move up 5mm. If it moves down then the direction is reversed.
                                    Warning: this will try to move 5mm ignoring endstops.
                                    Your homez.g looks good although
                                    G1 Z5 F6000 S2    ; lift Z relative to current position
                                    is unnecessary and
                                    ;G90              ; absolute positioning
                                    should rather not be commented out to avoid issues with anything expecting absolute positioning.
                                    Manuel
                                    My Tool Collection
                                    • Thoemseundefined
                                      Thoemse
                                      Thank you. I will try that.
                                      I can't use thos commands. Insufficient axis homed. Only works after homing I guess? I managed to fix it now. All axis homing against endstop fine.
                                      • Thoemseundefined
                                        Thoemse
                                        Closing in to get it running. Axis Home. Endstops work. Fans work. Bed heats.
                                        Only the hotend keeps bugging me.
                                        It's a 3d Freunde e3d Full Metal Hotend.
                                        I get the error: Heater 1 fault (T0) - 2000°C
                                        I tried the original E3D thermistor values. I tried the values that work for the 3D Freunde Hotend in Marlin (B 3950) but all I get is a heater fault.
                                        The thermistor and heater are wired to E0.
                                        Heatbed works fine. Pid tuning it right now.
                                        • Vetiundefined
                                          Veti
                                          before you try to heat the hotend see if the thermistor reads room temperature and changes by externaly heating it (hand body temperature)
                                          • Thoemseundefined
                                            Thoemse
                                            Thermistor always shows 2000 C.
