    AM8 config issues - cannot home any axis
    3.0k
      Please post your config.g file as @Phaedrux requested.
      • spunone69undefined
        spunone69
        I just got my Duet Wifi setup as a CoreXY and its doing the EXACT same thing! I can open Pronterface or Simplify 3D and move the axes in any direction, but when I home any of them it moves Z up and down and X or Y moves only a few millimeters...what is the issue?
          spunone69
          And if I try to home Z it just goes up and down once or twice...
          • Thoemseundefined
            Thoemse
            Ok. Z motors run ok now that they are not in series anymore.
            Homign does not work at all though. Homing X and Y moves Z axis still.
            Homing Z axis runs the axis down into the switch that does not work and it keeps on running intothe switch - the switch actually died broke this.0_1545766351395_config.g
            • Vetiundefined
              Veti
              thats why dc posted the link. use the m119 command to test each endstop manually first.
              Thoemseundefined 1 Reply Last reply Reply Quote 0
              • Thoemseundefined
                Thoemse @Veti
                @veti
                Yeah makes sense. But can you see faults in the config.g?
                I am far from anything workable. The hotend throws out a fault. The fans have no power (allways on fans as well - 12V fans, 12V PSU).
                No endstops. A moving Z axis when tryign to home X or Y. I don't even know where to start really.
                I never had trouble with marlin but this leaves me puzzled.
                • wilrikerundefined
                  wilriker
                  So, unless you have also changed the lead screw then your steps/mm for Z are 10x too high. They should be set to 400.
                  Also your steps/mm for X and Y are too low if you did not replace the pulleys by 20T versions. Original Anet A8 has 16T resulting in 100 steps/mm.
                  Then there is no endstop for Z configured at all. And the one for Y is set to active high where default Anet wiring of the endstop is active low.
                  The original Anet motors run on Z in series - that's how I had mine running for months also with the original 12V PSU.
                  Manuel
                  My Tool Collection
                  Thoemseundefined 2 Replies Last reply Reply Quote 0
                  • Vetiundefined
                    Veti
                    M574 Y1 S1 ; Set active high endstops
                    M574 X1 S3 ; Set endstops controlled by motor load detection
                    Normally the a8 switches are NO if i remember correctly. You configured NC for Y.
                    X is stall detection and not via switch. Is that correct?
                    Check the wiring on the fans. if you swapped them the wrong way the fuse might be blown.
                    See https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans
                    . If you connect the fan the wrong way round, you may damage the fan, the Duet, or both.
                    • Thoemseundefined
                      Thoemse @wilriker
                      @wilriker
                      Thanks a lo. I will look into it. The Endstops were the wrong way round. Fault number one solved as well.
                      Sorry for my stupid questions. I am new to this. I thought the basic config of RFF config tool will get me somewhere. I found no basic values to start with for the anet.
                      X stall detection is because one switch died. I just fixed it though - back to endstop.
                      • wilrikerundefined
                        wilriker @Thoemse
                        @thoemse The easiest way to get the correct values is the use Marlin's appropriate Configuration.h and Configuration_adv.h. These have all the working values in there.
                        But this reminds me again that I wanted to create a template for Anet A8 in RRF Configurator. But that will probably only happen at the beginning of next year.
                        Manuel
                        My Tool Collection
                        • Thoemseundefined
                          Thoemse @wilriker
                          @wilriker
                          Changed steps. Thank you.
                          Edit: Fantastic. Making progress. All endstops working. Axis are homing.
                          Now On to the hotend and the no power on fans issue. I shall read up on it first though. I went at this a bit to unprepared.
                          Thanky ou very much btw. I am starting to get the hang of it.
                          • Thoemseundefined
                            Thoemse
                            Fixed the fan. I got an issue with z homing. It tries to home on top but I got a min Z endstop.
                            Considering it lifts z correctly before homing X and Y I think the Z axis direction should be correct.
                            I've added the z homing file.
                            I am sorry for all the questions.0_1545818773565_homez.g
                            • wilrikerundefined
                              wilriker @Thoemse
                              @thoemse said in AM8 config issues - cannot home any axis:
                              What happens if you issue the following commands?
                              G91
                              G0 Z5 H2
                              G90
                              It should move up 5mm. If it moves down then the direction is reversed.
                              Warning: this will try to move 5mm ignoring endstops.
                              Your homez.g looks good although
                              G1 Z5 F6000 S2    ; lift Z relative to current position
                              is unnecessary and
                              ;G90              ; absolute positioning
                              should rather not be commented out to avoid issues with anything expecting absolute positioning.
                              Manuel
                              My Tool Collection
                              • Thoemseundefined
                                Thoemse
                                Thank you. I will try that.
                                I can't use thos commands. Insufficient axis homed. Only works after homing I guess? I managed to fix it now. All axis homing against endstop fine.
                                • Thoemseundefined
                                  Thoemse
                                  Closing in to get it running. Axis Home. Endstops work. Fans work. Bed heats.
                                  Only the hotend keeps bugging me.
                                  It's a 3d Freunde e3d Full Metal Hotend.
                                  I get the error: Heater 1 fault (T0) - 2000°C
                                  I tried the original E3D thermistor values. I tried the values that work for the 3D Freunde Hotend in Marlin (B 3950) but all I get is a heater fault.
                                  The thermistor and heater are wired to E0.
                                  Heatbed works fine. Pid tuning it right now.
                                  • Vetiundefined
                                    Veti
                                    before you try to heat the hotend see if the thermistor reads room temperature and changes by externaly heating it (hand body temperature)
                                    • Thoemseundefined
                                      Thoemse
                                      Thermistor always shows 2000 C.
                                      • Vetiundefined
                                        Veti
                                        check that you have connected it to the correct plug, then measure the resistance of the thermistor using an ohm meter.
                                        • Thoemseundefined
                                          Thoemse @Veti
                                          @veti
                                          Thanks. Yep the Thermistor is dead out of the box. Plugged in a different one and it reads room temp.
                                          I got some teething issues on this one.
                                          • Vetiundefined
                                            Veti
                                            cut the cable at the crimp contact, and measure again. it might just be a bad crimp job.
