    Got my paneldue... It says "connecting" and controls nothing...
    PanelDue
    10
    49
    6.6k
      Phaedrux Moderator @Steve Lynch
      @steve-lynch It should just work.
      If you go to the setup page on the PanelDue, what firmware version does it show at the top?
      Steve Lynchundefined 1 Reply Last reply Reply Quote 0
      • ShawnCundefined
        ShawnC
        The baudrate should be 57600. Try again. I have the same issue earlier.
          Check that the baud rates on both the PanelDue Setup page and in the M575 P1 command in config.g on the Duet are both set to 57600.
          • Steve Lynchundefined
            Steve Lynch @Phaedrux
            @phaedrux 1.21.2 (12b1) is what it says.
              @steve-lynch If you've checked the commands as David says above and it's still not working, you can try flashing the latest firmware. Instructions here: https://miscsolutions.wordpress.com/paneldue/
                Steve Lynch
                Hello, Thanks for the reply..
                There was not an M575P1 command anywhere in my Config.g Perhaps the Paneldue instruction page should include this?
                The Paneldue instructions make no mention of this anywhere.
                So I searched the M Codes Until I found an explanation.. I set my board using this command: M575 P1 B57600 S1
                I reboot the Paneldue and the Duet.. Still nothing. Just "Connecting"
                Here's my complete Config.G do you see any problems? I've done everything every youtube tutorial, or forum post has suggested.. Thanks so much!
                ; generated by RepRapFirmware Configuration Tool v2 on Thu Dec 20 2018 18:06:49 GMT-0500 (Eastern Standard Time)
                M575 P1 B57600 S1 ;Set baud rate Duet Board.
                M575 P0 B57600 S1 ;Set baud rate USB
                M550 P"My Printer" ; Set machine name
                M552 S1 ; Enable network
                ;*** Access point is configured manually via M587
                M586 P0 S1 ; Enable HTTP
                M586 P1 S0 ; Disable FTP
                M586 P2 S0 ; Disable Telnet
                M564 H0
                M569 P0 S0 ; Drive 0 goes forwards
                M569 P1 S1 ; Drive 1 goes backwards
                M569 P2 S0 ; Drive 2 goes forwards
                M569 P3 S0 ; Drive 3 goes forwards
                M569 P4 S0 ; Drive 4 goes forwards
                M584 X0 Y1:4 Z2 E3 ; Apply custom drive mapping
                M92 X80.00 Y80.00 Z400.00 E415.00 ; Set steps per mm
                M566 X480 Y480 Z12.00 E1200.00 ; Set maximum instantaneous speed changes (mm/min)
                M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; Set maximum speeds (mm/min)
                M201 X1200 Y1200 Z250.00 E250.00 ; Set accelerations (mm/s^2)
                M906 X1200 Y1200 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M208 X290 Y290 Z360 S0 ; Set axis maxima
                M574 X1 Y1 Z0 S1 ; Set active high endstops
                ; ** BLTouch
                M307 H3 A-1 C-1 D-1 ; disable heater 3, BLTouch - servo pulse on heater 3 pin (expansion 😎
                M558 P5 X0 Y0 Z1 H5 F200 T5000 ; Type 5 for BLTouch (Normally closed switch on Z-probe inputs)
                G31 X33.00 Y0.39 Z2.74 P5 ; Z=trigger height, P=trigger value, not needed for contact probe, X/Y distance from nozzle
                M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
                M305 P1 B4725 C7.06e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                M106 P0 I0 S0 F500 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                M106 P1 F500 I0 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                M563 P0 D0 H1 ; Define tool 0
                G29 S1 ; load stored bed height map
                  @steve-lynch said in Got my paneldue... It says "connecting" and controls nothing...:
                  I think it's not mentioned because it's already the default.
                  Did you try updating the PanelDue firmware?
                  What firmware are you running on the Duet?
                  Double check the cable continuity and that the pins are going to the right places? It's oftentimes a cabling issue of some sort.
                  Otherwise I'm not sure what else to do or check.
                    Steve Lynch
                    This post is deleted!
                      Steve Lynch
                        Steve Lynch
                        Firmware on board is updated to 2.02 from 8 days ago.. Paneldue is updated to the latest firmware 1.22.1(28b1) The screen showed the firmware update progress, and said when it was rebooting and all, but it still says "connecting" after re-boot, and no control..
                        Continuity confirmed... It's only 4 conductors.. not hard to keep straight.
                        Hmmmm.
                          Steve Lynch
                          Firmware Version: 2.02(RTOS) (2018-12-24b1)
                          WiFi Server Version: 1.21
                          Web Interface Version: 1.22.6
                          Web Interface by Christian Hammacher
                          Licensed under the terms of the GPL v3
                            Steve Lynch
                            Tried it with the ribbon cable interface as well.. it powers it, it shows firmware upgrade status, but it does not "connect".
                            Everyone said "dude, they're more trouble than they're worth"... But I see a lot of folks using them successfully..
                            I'm at a loss here.
                            resamundefined 1 Reply Last reply Reply Quote 0
                            • resamundefined
                              resam
                              @Steve-Lynch does the PanelDue tell you anything on the console tab?
                              I used to see a few error messages when I set the wrong baud rate...
                              Can you inspect the PCB, and verify that the connection headers are good? Maybe there is a bad solder joint or crack in the PCB? (high-def pictures maybe?)
                                Steve Lynch
                                overall
                                view
                                  Steve Lynch
                                  connector closeup top
                                  • resamundefined
                                    resam
                                    I don't see obvious problems on the PCB - but maybe @dc42 spots something...
                                    If you use the 4-pin connector, try switching the wires of the two data pins (DIN, DOUT).
                                      Steve Lynch
                                      I do PCB Repair, and under my scope, there is no break, or bad solder joint... Aside from that, both interfaces do not work.. (ribbon cable, or 4 pin) I have several of each, so it's not the cable, and I have continuity from the solder joint on the duet to the solder joint on the paneldue..
                                      • resamundefined
                                        resam
                                        @Steve-Lynch whats the story with the lifted pad / pin in the top left corner, close to RA2/RA7?
                                        Since you seem to be familiar with the topic: do you have a scope? Can you probe the UART pins of the SAM4S directly? just to make sure the traces are all fine.
                                          Steve Lynch
                                          That connector, the (X4 connector) was broken off in shipping. While I did email filastruder, I've been told by others that the connector isn't used, so It should not be an issue. The traces leading to the pads are fine, but the pads themselves were ripped off it seems.
                                          I have a Microscope, not oscilloscope.. lol. I replace blown capacitors and power supplies and repair traces and stuff, I'm wasn't trying to be "mr. know it all", I just was establishing that I had checked beyond the obvious...
                                          And I tried swapping din dout, that didn't do anything as expected (rx to rx - Tx to Tx)
                                          • resamundefined
                                            resam @Steve Lynch
                                            Do you mean it shows a progress bar when you upgrade the DuetWifi firmware?
                                            This would mean the connection DOES work...
