    Duet Web Control 2.0.0-RC3 is ready
    Duet Web Control
    50
    147
    27.4k
    • whosrdaddyundefined
      whosrdaddy
      @chrishamm : Happy NY!
      RC3 is working now on my Duets, thanks for the hard work 😉
      • Wyvernundefined
        Wyvern @Jacotheron
        @jacotheron cool, I never used a a pi. First time for everything.
        • antlestxpundefined
          antlestxp
          is there a way to swap out the layer chart for the web cam feed?
          • bmonninundefined
            bmonnin
            Doesn't give me warm up time, using RC3. I do get the warm up time if I open up old web interface.
            antlestxpundefined 1 Reply Last reply Reply Quote 0
              antlestxp @bmonnin
              @bmonnin you have more than me lol. I don't get Warm-up time, last layer time, info in the layer chart or temperature chart. a refresh will get most back with the exception of the warm-up time.
              • 3dmntbighkerundefined
                3dmntbighker @burtoogle
                @burtoogle said in Duet Web Control 2.0.0-RC3 is ready:
                Spello
                I don't believe that setting sticks in 2.0 either.
                Scratch built CoreXY with Maestro
                Heavily modified Ender 3 with Maestro
                MPCNC work in progress with Duet WiFi
                  3dmntbighker
                  Could one assume that 2.0 will eventually allow you to drag and rearrange each element on the page? Or hide (delete) them? And pick from a palette to add them. It's pretty standard practice these days in web design. OpenLM is good example of this concept. Mainly just wondering if it's a design goal.
                  • nikkerundefined
                    nikker
                    @chrishamm I am really liking the updated DWC! This may be a dumb question but since you are starting a new DWC as a foundation for the future, would drag and drop/re-sizable windows ever be possible? This way anyone can set it up the way they like? Thanks for all your hard work!
                    • gnydickundefined
                      gnydick @chrishamm
                      @chrishamm
                      the baby-step button wasn't slow because it was waiting, it was slow because it was animating, right?
                      I have to disagree with your assessment of the rest, which is why it's going to take forever for DWC to be useable.
                      I have built entire content management systems in a week long before all of these fancy libraries were around.
                      It sounds like you're relying on frameworks to be silver bullets. The notion that it is a PWA is misguided. Yes, we all want it on both desktop and mobile browsers, but going along with PWA methodology is a recipe for bloat and over complication.
                      I downloaded DWC1 source, added one JS library, and was able to turn it into a drag-n-drop re-arrange-able site in less than an hour.
                      I honestly think you're working too hard on it and not realizing that at it's essence, it's a ridiculously simple web site. It doesn't need anything fancy to be awesome.
                      This doesn't need to be a PWA, it needs to be control plane that can be layed out on desktop and mobile.
                      I guarantee you, based on your experience with the system, if you were to start from scratch, you could have something awesome in less than a week's time if you adopt the notion that you're building control panels for a machine, not a Progressive Web App. The site is only going to do so many things, and that so many, is very few. There are only a small handful of technical hurdles when it comes to working with the duet web-host, once those are knocked out, which you can do instantly, because you've done it before, it would take no time at all.
                      • wilrikerundefined
                        wilriker @chrishamm
                        @chrishamm said in Duet Web Control 2.0.0-RC3 is ready:
                        • G-code pop-ups take you to the console only if you don't hit the 'X' button
                        This might be correct but the clickable area is tiny. I always try to hit the 'X' button but more often than not I get bumped to console. Using a mouse on a desktop PC.
                        Another minor issue (at least for me) that I found is in the JS console:
                        boards.js:75 Unsupported board duetwifi102, assuming Duet WiFi
                        looking at the source code of this whenever something unknown is encountered it falls back to Duet Wifi. This is not an issue if one has any version of a Duet Wifi. But once you have a Duet Ethernet other than hardware rev. 1.0 this will also make it a Duet Wifi. This will be simple to fix by just adding aliases. Just wanted to mention it.
                        Another thing I like to mention is that I like that the menu is permanently expanded on larger screens. That is something, though, that annoys me on my smaller screen (1024px width) where I always have to do one more click to expand the menu before selecting another tab.
                        Manuel
                        My Tool Collection
                        • wilrikerundefined
                          wilriker @chrishamm
                          @kraegar Drag&drop is supported in the Files category. If you want to move a file up, drag&drop it on one of the directory links at the top.
                          Hm, just tried this. I can drag files around all day but dropping does not work. It will just stop the dragging animation but the files stay where they were.
                          EDIT: And another thing I just realized: if you have a larger amount of extra temperature sensors they will mess up the layout:
                          Initially loaded it looks like
                          Then switching to Extra looks like (which is still OK)
                          But then going back to Tools leaves empty space and an extended temp graph:
                          Manuel
                          My Tool Collection
                          • Edgars Batnaundefined
                            Edgars Batna @chrishamm
                            @Edgars-Batna DWC2 uses a UI framework that follows material design and on Android the order of buttons is different from Windows. Did you have a tool selected when you tried to extrude?
                            I see no point following any specific designs. The GUI should be fit for a purpose and for a semi-industrial machine that can get damaged or can rip your fingers off there should NEVER be a change like this which reverses order of the buttons in potentially security related dialogs.
                            Yes, I tried multiple things, including selecting a tool and enabling cold extrusion.
                            In general CORS errors are equivalent to network errors. When running DWC2 on localhost and it tries to connect to another machine, the browsers do a CORS preflight check (by sending an OPTIONS request to the host to see if the other request would be actually permitted) and if that fails, DWC2 reports a CORS error. I may simplify this a bit more so that it shows 'Network error' instead of 'CORS error' when running on a Duet.
                            Then it must be a firmware issue, because my network is solid and the problem started right after updating to 2.02 and new web UI.
                            All in all I understand the move to vue.js as I've been involved with it at work. At the same time these machines that are used to produce stuff can't be put into same baskets with Farmville. I'm exaggerating, but there's just no comparison. It's my rationale, but it's up to you to decide.
                            • appjawsundefined
                              appjaws
                              @chrishamm The messages produced by macros are not being displayed on screen or in the console on this release but if I revert to the old screen everything works correctly.
                              It took a bit of getting used to not being able to drag and drop, I would prefer if this functionality could be restored in addition to the way it works now.
                              appjaws - Core XYUV Duet Ethernet Duex5
                              firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                              Ormerod 1-converted to laser engraver, Duet wifi
                              OpenSCAD version 2024.03.18
                              Simplify3D 5.1.2
                              • burtoogleundefined
                                burtoogle
                                Apologies if this has already been mentioned but I think there's a problem with the layer time chart. It appears to work OK at the start but then later it goes blank. I noticed when I reprinted a job that the second (and subsequent) prints did not have a layer time chart displayed.
                                • wilrikerundefined
                                  wilriker @burtoogle
                                  I mentioned this above somewhere. This can already happen within the same print by switching to another section of DWC and then returning to Job Status. At least in this case reloading DWC solves the issue.
                                  Manuel
                                  My Tool Collection
                                  burtoogleundefined 1 Reply Last reply Reply Quote 0
                                    burtoogle @wilriker
                                    @wilriker said in Duet Web Control 2.0.0-RC3 is ready:
                                    Yes, I think I had seen that behaviour also but couldn't remember for sure.
                                    • brandonhundefined
                                      brandonh @chrishamm
                                      @chrishamm By speed graphing, I mean the ability to see the speed of the printer over time, on the UI, just like the temperature graph. This is really useful for debugging because the instantaneous readout can be hard to keep up, and just knowing how fast the printer is going can be useful for debugging slicing and machine settings. Plus if you change these settings but want to run an older g-code file it can be handy too.
                                      I did take a look at the code and it seems pretty reasonable to add, but I doubt this is something I'd work on anytime soon.
                                      • Biggsisundefined
                                        Biggsis
                                        I could not find, if somebody already mentioned it, but in Europe the time (in the temp chart) is not displayed in "AM/PM" format. Maybe make it selectable, thanks.
                                        Hypercube Evolution User Group : https://www.facebook.com/groups/Hypercubeevolution/
                                        Kossel Delta XL / XXL User Group : [https://www.facebook.com/groups/KosselXXL/]
                                        AS-3D Druckundefined 1 Reply Last reply Reply Quote 1
                                        • AS-3D Druckundefined
                                          AS-3D Druck @Biggsis
                                          @biggsis said in Duet Web Control 2.0.0-RC3 is ready:
                                          I got AM and PM in my Temp Chart.
                                          Bild Text
                                          Best regards
                                          AS-3D Druck / Andre
                                          mudcruzrundefined 1 Reply Last reply Reply Quote 0
                                          • garyd9undefined
                                            garyd9
                                            @chrishamm
                                            I finally got around to trying this out and thought I'd share my (very early) initial impressions. These are my own impressions without taking into account things that others might have posted. While this type of feedback might result in duplicate comments, it also prevents my impressions from being "contaminated" by what I might have already read. I'm using the "Chrome" web browser on Windows 10 and MacOS against firmware 2.02. and DWC 2.0.0-RC3
                                            First, I like what I think you're trying to do here. Overall, it looks positive.
                                            However, I encountered three items that I feel are steps backward.
                                            It's more clumsy now than it was to initiate the G32 command (delta calibration, manual bed leveling assistant, etc. It runs G32.) Previously, it was a simple single button click on the primary/dashboard screen. Now, it requires multiple clicks to first drop down the "compensation & calibration" list, a mouse movement, and a second click to select the proper option. This is more annoying when you consider that "mesh" compensation isn't used on my machine and isn't enabled. (There's no mesh area defined.) To resolve this, I'd suggest reverting to the simple single function button by default and allowing an option to change this to the droplist if and only if a selection is made in the settings to enable mesh options. (Or, only present mesh options if a mesh area is defined, otherwise just be a simple button that runs G32.)
                                            Related to the above, when I run G32 using the Compensation&calibration droplist from the Dashboard, the results of the calibration do not seem to appear in the "G-Code Console" tab. I usually check the output of a calibration to ensure that the before/after numbers are somewhat close to each other (and re-run g32 if they aren't.) It seems (with DWC 2RC3) that the only way to get the G32 results to appear in the console is to run the command from the console tab to begin with.
                                            I'm not sure I like how the status/tools/temp layout renders. I get a LOT of empty whitespace and the temperature chart (which is the tallest window) gets squeezed on the far right. I've posted a screen snippet near the end of this post to illustrate the concern. Possible alternatives might be to limit the height of the temperature chart to be no higher than the max height of the status or tools box (whichever is taller) or stack the status and tools boxes over each other (which would work for single tool/single bed machines, but might be annoying for multiple tool machines.)
