Removal of support for 3-, 4- and 5-point G32 bed compensation
good idea, the whole concept with borh G32 and G29 was a bit confusing
One additional item that will still be supported is using bed.g to test Z probe repeatability, using a series of G30 commands with a S-1 parameter on the last one.
As it stands, the proposed functions are exactly what I use G32 for, ie: adjusting multiple Z lead screws.
Z probe testing is something that I should probably do, too.
I'm currently modifying my printing gcode for a 3x3 grid before printing (used to do a g32 5 point + a large occasional g29 20x20 point it adapts to, I'm finally taking the time to fully understand g29)
if I manually keep a grid of 20 x 20 for minor curves in my bed, then use a 3x3 grid each print, will the g29 printing gcode keep the 20x20 grid and be adjusted by the 3x3 grid or will the printer only print using the new grid?
I have already set up my g29 parameters for the 20 x 20 grid, so adjusting for a quick 2x2 or most likely a 3x3 after bed heating isn't an issue, it's mostly if the 20x20 grid can still be used, I don't want to spend an hour probing for each print, but the 20x20 grid allows for really nice first layers on a metal bed.
current bed leveling gcode,
; bed.g
; called to perform automatic bed compensation via G32M561 ; clear any bed transform
M400 ; dummy for Z probe, stop any moves
G28 ; home all axes
; Probe the bed at 5 points (removed for now, only g29 is loaded)
; G30 P0 X26 Y3 H0 Z-99999
; G30 P1 X26 Y300 H0 Z-99999
; G30 P2 X263 Y300 H0 Z-99999
; G30 P3 X263 Y3 H0 Z-99999
; G30 P4 X144.5 Y155 H0 Z-99999 S5
G29 S1 ; load hight map (needs to switch to a csv file)
M376 H10 ;taper the compensation after 10mmprinting gcode needs to switch g32 for a g29 loading then 3x3 probing, and a macro for 20x20 probing to a csv needs to be copied/ made.
@sheldor said in Removal of support for 3-, 4- and 5-point G32 bed compensation:
No. You can only have one type of bed compensation in effect at a time (either the old 3/4/5-point bed compensation, or mesh bed compensation), and if you are using mesh bed compensation, only one grid can be active at a time.
@dc42 darn, looks like I'll have to do something like 4x4
@Sheldor Is it really necessary to do a multipoint probe before each print? You can load the detailed heightmap and as long a your bed hadn't gone out of level or shifted it did still be relevant.
@phaedrux said in Removal of support for 3-, 4- and 5-point G32 bed compensation:
Is it really necessary to do a multipoint probe before each print? You can load the detailed height map and as long a your bed hadn't gone out of level or shifted it did still be relevant.
I have not found it necessary to probe before each print.
On my FT-5 I don't have a probe and just check the bed manually using a shim gauge once a month or so but it doesn't seem to be changing.
@fcwilt said in Removal of support for 3-, 4- and 5-point G32 bed compensation:
If you have a good Z probe, you can use it to check the bed level and tell you the levelling screw corrections needed. See https://duet3d.dozuki.com/Wiki/Using_the_manual_bed_levelling_assistant.
@dc42 said in Removal of support for 3-, 4- and 5-point G32 bed compensation:
Someday I'm going to fit a Z probe and try that out.
It takes just a few minutes to adjust the leveling screws manually using the shim gauge and the results are all I could ask for. The printer works great.
Thanks for the reminder.
@phaedrux I have dual lead screws (not independent) so unless I keep Z steppers on between prints, moving the bed or removing torque will tilt it between those two
