    Zortrax M200 Duet Conversion
    99
    25.5k
      deckingman
      @dc42:
      Try using https://configurator.reprapfirmware.org/ to generate your configuration files. One thing it doesn't yet get right is the homez.g and homeall.g files if you use a microswitch for Z homing instead of a Z probe.
      And the other thing it doesn't do right is configuring the microstepping. It generates M350 X16 X16 X16 X16 I0 (that's for 1 extruder) when it should be M350 X16 Y16 Z16 E16 I1. i.e. it doesn't set microstepping for Y,Z and the extruder(s) but more importantly, it turns microstepping off when the default is on.
      • Corexyundefined
        Corexy
        OK, so which firmware setting should I use?
        I'll go through page by page, and ask the "for dummies" questions as I go.
        I did reverse the X and Y motors as mentioned above, and actually got it to home against the end stop switches…small noob victory!
        • iDeveloundefined
          iDevelo
          Set it to Marlin. Leave your motors at 16x micro stepping then edit your config.g after you have uploaded it and set the I parameter in the M350 line to 1
          • Corexyundefined
            Corexy
            @iDevelo:
            Thank you.
            So I've gone through the configurator and haven't changed much other than the dimensions of my bed, probing points offset, I've made XY probing active high/high end, Z probe at high end.
            All other values I've just left as is.
            My concern now is the heater probe settings.
            I have a standard Zortrax thermistor on the bed with a resistance of 123.5kohm, and an S3D PT100 on the extruder. (I will change the bed to a PT100 later, but want to see it work for now).
            Also should I use PID or bang bang for the bed?
            The PT100 is connected to RTD1 on the daughter board, and the thermistor is connected to the bed sensor plug on the board near the bed heater terminal block.
            I haven't changed any of the offset/jerk/current/etc settings as I'd assume they are set at a reasonable starting point and can be tweaked later as we see how this all goes.
            Also, if I go to finish the configuration, it gives me 13 files to download.
            Do I delete all the files already on my Duetwifi's SD and replace it with all of these, or just the config.g file?
            Bit frustrating as I'm on the other side of the world and have to wait for people in other timezones before I can move on, but I really appreciate (and need) all the assistance.
            Cheers again
              The configuration tool gives you the option to download a zip file. If you do that, you can upload that zip file via the General tab of the Settings page of DWC, and it will upload all 13 files in one go.
              • Corexyundefined
                Corexy
                @dc42:
                Ok, thank you.
                Do I delete the existing files first or will it overwrite them?
                Can you help with the other questions regarding settings?
                  It will overwrite them.
                  The only other configuration question I saw in your previous post is whether to use PID or bang bang for the bed heater. I suggest you start with bang bang and switch to PID when you have run auto tuning on the heater.
                  • Bobblejotundefined
                    Bobblejot
                    Go to Zortrax and get the specs for your machine e.g stepper motor sizes thermistor types etc… , its basically an ultimaker clone so for basic parameters
                    X axis homes to min
                    Y axis homes to max
                    Z axis homes to max
                    X axis steps per mm 160 ; 1.8° steppers 16x micro stepping GT2 belts 20T Pulleys
                    Y axis steps per mm 160 ; 1.8° steppers 16x micro stepping GT2 belts 20T Pulleys
                    Z axis steps per mm 800 ; 1.8° steppers 16x micro stepping TR8 Lead Screw
                    or
                    X axis steps per mm 320 ; 0.9° steppers 16x micro stepping GT2 belts 20T Pulleys
                    Y axis steps per mm 320 ; 0.9° steppers 16x micro stepping GT2 belts 20T Pulleys
                    Z axis steps per mm 1600 ; 0.9° steppers 16x micro stepping TR8 Lead Screw
                    normally xy are 0.9° degree and z is 1.8°
                    so..
                    You need to check your stepper motor specs to be sure.
                    X axis max speed 18000 # mm/min
                    Y axis_max speed 18000 # mm/min
                    Z axis max speed 4800 # mm/min
                    X max travel 213 # max travel in mm for alpha/X axis when homing
                    Y max travel 179 # max travel in mm for beta/Y axis when homing
                    Z max travel 195.8 # max travel in mm for gamma/Z axis when homing
                    X axis current 1.3a ; 1300ma
                    Y axis current 1.3a ; 1300ma
                    Z axis current 1.0a ; 1000ma
                    E current 0.8 or 1.0a ; 800ma or 1000ma
                    E steps per mm 800 # Steps per mm for extruder stepper
                    E default feed rate 2700 # Default rate ( mm/minute ) for moves where only the extruder moves
                    E acceleration 1000 # Acceleration for the stepper motor, as of 0.6, arbitrary ratio
                    E max speed 45 # mm/s
                    E retract_length 5 # retract length in mm
                    E retract feedrate 45 # retract feedrate in mm/sec
                    E retract zlift length 0.15 # zlift on retract in mm, 0 disables
                    These are just sort of basic settings for an ultimaker clone, they will need to be tweeked for your Zortrax. But they might give you a starting point or just confuse you more 🙂
                    • Corexyundefined
                      Corexy
                      @Bobblejot:
                      X axis homes to min
                      Y axis homes to max
                      Z axis homes to max
                      or
                      so..
                      Thanks very much.
                      Zortrax will not tell me a thing, they are very difficult that way which is the reason for this project.
                      I would suspect all the steppers are basic 1.8 degrees, and I have taken resistance measurements for all of them before I started if that will help. I'll use your settings for 1.8 deg with 20T pulleys for starters.
                      I should point out that the Z screw is 12mm by 4mm pitch. I have replaced one in the past. Does that mean I'd use 1600 steps/mm for 1.8 deg stepper?
                      Are these ultimaker dimensions? My Zortrax's physical travel dimensions are 195/195/175 respectively, so I'll use those?
                      X axis homes to min
                      Y axis homes to max
                      Z axis homes to max
                      X and Y limit switches are both in the front left corner of the gantry in the Zortrax. Will this still apply?
                      Thanks very much for such a detailed reply.
                      While this is all new to me, this config tool is certainly helpful.
                      • Corexyundefined
                        Corexy
                        @dc42:
                        Sorry, yes a couple of my questions were worded as statements.
                        I have a standard Zortrax thermistor on the bed with a resistance of 123.5kohm, connected to the bed sensor plug on the board near the bed heater terminal block.
                        I have an S3D PT100 on the extruder connected to RTD1 on the daughter board.
                        What settings would I use for these in the config tool?
                          For the bed thermistor, if you measured the resistance as 123k at room temperature, it is probably 100k at 25C. So enter 100000 as the R25 value. Try 4000 for B and zero for C. Leave the sensor channel set to ADC0.
                          For the nozzle, just set the sensor channel to RTD1 which means the first PT100. The other parameters don't matter then.
                          • Corexyundefined
                            Corexy
                            OK,
                            So at this point I have it sort of starting to work.
                            As I've got a million questions no doubt regarding setting it up, I think I'll start a new thread in "tuning and tweaking" and save this thread for Zortrax specific mods and developments.
                            I must say the wifi is working fine with my portable router sitting beside the machine and my laptop right at the other side of the house.
                            Thank you very much for the help so far.
                              Bobblejot
                              Yep those were the dimensions used for the ultimaker bed, so use your Zortrax dimensions.
                              Sorry for your 12mm lead screw i dont know what thread pitch Zortrax are using.
                              Do you have a serial number for the printer because you could always download the latest firmware from their site. Then you can get all the original values from the actual firmware as starting point.
                              For your limit switches it will probably be
                              X axis homes to max
                              Y axis homes to min
                              Z axis homes to max
                                Bobblejot
                                Oh forget to say, when i saw your pictures it didn't look like there was a ground connection from your power supply to the chassis probably would be a good idea since its a metal cased printer.
                                • Corexyundefined
                                  Corexy
                                  @Bobblejot:
                                  X axis homes to max
                                  Y axis homes to min
                                  Z axis homes to max
                                  Cheers mate, sorry I just saw this.
                                  Zortrax keeps their firmware under lock and key, it apparently can't be viewed or whatever.
                                  If you see my other thread, I'm starting to get there as you'll see.
                                  Seems I have to tweak some speeds for that sweet spot where the steppers don't resonate noisily, still pretty green with this sort of thing.
                                  Please feel free to comment over there, I'll try to keep this thread to the nuts and bolts of the conversion.
                                  I'll look at an earth strap if there isn't one there somewhere.
                                  Loving the paneldue, and made a mount that sits it at 45deg right where you can use it, using existing mounting holes.
                                  Soooooo much better to use than a tiny display with a jog dial right down the bottom where it's a little difficult to view.
                                    @Corexy:
                                    Check that your M350 command in config.g has parameter I1 not I0. The config tool used to generate I0 by default until very recently.
                                    • Corexyundefined
                                      Corexy
                                      @dc42:
                                      @Corexy:
                                      Got that.
                                      To be honest this machine has sat broken for a long time on the floor.
                                      It seems to be getting happier as I use it. A little grease on the axis' might not go astray either….
                                        Bobblejot
                                        No problem, its looking good. The firmware can be found at http://support.zortrax.com/downloads/firmware/?printers=m200 al you need is the serial number of your machine.
                                        • Corexyundefined
                                          Corexy
                                          @Bobblejot:
                                          Yes but it's a .bin file which I can't seem to open.
                                          I ran the "search for a program to open this file" function and got nothing.
                                          I'm pretty crap on computers though…if you PM me I'll give you a serial number if you'd like to have a look.
                                          • Corexyundefined
                                            Corexy
                                            Homing in on a result.
                                            This cable strain relief might be temporary, as I've got some cable chain on the way and might use it flat across the top of the printer.
                                            Messing around with a 0.3mm/raft/ABS/S3D print here, and it's going ok.
                                            Certainly room for improvement and dialing in, but it's off to a decent start.
