    Simple heater question SOLVED
    30
    3.6k
    • SupraGuyundefined
      SupraGuy
      Addendum: If you want to make it adjustable power output, then a power regulator is really the only way.
      So if you don't mind throwing away the power (Have a high wattage resistor strapped to a heat sink in series) then your 14 ohm one will give you 10W at the heater. You figure the dissipated power for the overall circuit, then calculate the voltage across each device in the circuit, like a standard voltage divider, then work out the power from there.
      For example a 10 ohm resistor in series would give a total series resistance of 24 ohm, TPd is 24W with 14W at the heater cartridge and 10W at the resistor. (simple case) this is probably close enough to your 15W case (9.85 ohms gives you close to 15W, if I've done my math right.)
      3 Ohm in series gives you 17 ohm total series resistance, TPd is 34W, with 28W at the heater cartridge and 6W at the resistor.
      Lead screw driven printer, powered by Duet 2 Wifi
      MPCNC powered by Duet 2 Wifi
      CoreXY printer driven by Duet 3 6HC
      LowRider CNC powered by Duet 2 Wifi
      • Vetiundefined
        Veti
        25W
        https://www.aliexpress.com/item/1pcs-24V-25W-heater-cartridge-heating-tube-for-Ultimaker-2-UM2-extended-3D-printer-4x15mm-head/32854405391.html
        https://www.aliexpress.com/item/24V-25W-reprap-cartridge-heater/32624515976.html
        35W
        https://www.aliexpress.com/item/3D-Printer-Ultimaker-2-UM2-Hotend-Heat-Cartridge-3D-Printer-DIY-Part-24V-30W-1-4M/32810827757.html
        20W
        https://www.aliexpress.com/item/5PCS-x-Heater-Cartridge-for-HotEnd-J-Head-6-15mm-12V-20W-free-shipping/32277000217.html
          deckingman
          Seriously guys, all I want to do is a quick and cheap evaluation. Basically just a heater tune with various wattage heaters.
          Bunging a series resistor in, is both quick and cheap. It'll cost me about £1.00 to £2.00 per resistor. I don't care about wasting half the power for a quick 5 minute test. I don't want to spend money on a buck/boost supply that I'll never use again. Nor do I want to build an adjustable power regulator. Nor do I want to buy heater cartridges from China that I'll only use for one quick test at £10 a pop.
          Not wishing to be too blunt and thanks anyway, but my question was answered by @Martin1454 at 9.30 this morning.
          • wilrikerundefined
            wilriker
            One last solution (based on @SupraGuy's ideas) which is both cheap and allows you to modify the wattage of the heater would be to buy a 10-pack of LM2596 based buck-down converters together with a 10-pack of small heatsinks.
            They come from China and take a while but cost less than 10 bucks altogether (I assumed you wanted to test all the heaters (you talk in plural in your OP) at the same time. The advantage is that you can adjust the power by regulating the voltage instead of swapping out resistors.
            Manuel
            My Tool Collection
            • SupraGuyundefined
              SupraGuy
              All I was doing there is reminding you that the half the power you waste doesn't go into the heater, so the answer @Martin1454 gave you wasn't correct -- at least not completely. I was assuming that you wanted to simulate the various wattages at the heater block.
              High power resistors seem to be cheaper where you are. Around here, as soon as you get past 5W, they start getting about the same price as the odd wattage heater cartridges, and they aren't available in the same kinds of values.
              If I were doing this, I'd probably end up using a few 5W devices and series/parallel them to get the resistance that I want. High wattage devices aren't available in better than 5% precision, and if you're lucky, you can get them in E12 series values. (Or completely screwball values that are obviously for specific purposes.) As such, it's going to be somewhat tricky to get the specific values for 5W increments
                deckingman
                https://www.ebay.co.uk/p/50w-6-Ohm-Load-Resistor-for-Car-Indicator-LED-Lamp-A1t5-L7n5/1781926492?iid=282905388857&chn=ps
                • Surgikillundefined
                  Surgikill
                  Why do you care what power it is? It's all PID controlled anyway, by using a lower power heater it's just going to take longer to heat up and have a harder time holding temperature.
                  wilrikerundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                  • wilrikerundefined
                    wilriker @Surgikill
                    @surgikill As he said in his OP he needs to evaluate something.
                    Manuel
                    My Tool Collection
                    Surgikillundefined 1 Reply Last reply Reply Quote 0
                      Surgikill @wilriker
                      @wilriker Would help if we knew exactly what was going on.
                      Also, if all is he looking to do is change power at the heater block he can change the PWM duty cycle and get the same results. If he's looking to increase power draw on a FET or something then he would need some power resistors.
                      wilrikerundefined 1 Reply Last reply Reply Quote 1
                      • wilrikerundefined
                        wilriker @Surgikill
                        @surgikill I cannot disclose any details but he needs to find an appropriate amount of heating power that suffices his project.
                        But you are right. PWM of the heater connectors could really work in this case easiest. Since this is purely about evaluation and not something trying to use a 12V heater on a 24V VIN this will probably work without any additional hardware.
                        Manuel
                        My Tool Collection
                          Surgikill @wilriker
                          @wilriker Well, I have the equations here if he's interested. It's cheaper than going out and buying power resistors too.
                            deckingman @Surgikill
                            @surgikill said in Simple heater question SOLVED:
                            How do you know that when I haven't given any details about the application? You know nothing about the thermal masses involved because I haven't given any details. You know nothing about the desired temperatures and desired rise times because again, I haven't given any details. You know nothing about the flow rate and temperature differential of any incoming fluids because I haven't given any details. You know nothing about how many heaters are involved and what their configurations and orientations are, with respect to each other and with respect to the design as a whole.
                            So how do you know that lower powered heaters are going to have a hard time time holding temperature? Or I just use a high powered heaters and rely on PID? And what happens when a FET fails and the PID gets stuck on full power and burns someone's house down?
                            And I'm not going to provide that information because this is a prototype design of something that may end up as a marketable product and I don't want to give out any details at this time. The only thing that is relevant to this thread is my first sentence, quote " I have a need to evaluate some heater power requirements." And my question was answered in the first reply.
                            End of.....
                            Surgikillundefined 1 Reply Last reply Reply Quote 2
                              Surgikill @deckingman
                              @deckingman Hope you have a good day. Please remove the stick out of your ass before you sit down somewhere.
                                A Former User @Surgikill
                                Trap 2
                                  Surgikill @A Former User
                                  @calvinx I mean he's arguing with an engineer.The whole point of a FET failing and burning somebodies house down is bullshit. If you wanted to get a heater cartridge that topped out at a certain temp (say 300C), short of using a resistive wire that increases resistance with temp, it's going to be a shit design with not enough power, unless you are only trying to hold 50-80C, which I'm assuming he isn't because he's talking about high temp heater cartridges.
                                  Furthermore, he talks about a lower power cartridge being able to perform the same as a higher power cartridge. This just isn't true. A higher power cartridge will have decresaed rise times and be more responsive to environment variables such as moving air. There's no arguing that, it's just physics. The only reason you would want to use a lower power cartridge is for either size or power requirements.
                                  IDK if he had a bad day or what, but if he's as smart as he is posturing then there was no need to create this post in the first place.
                                  A Former User? deckingmanundefined 2 Replies Last reply Reply Quote 0
                                    As an engineer, have you never heard of a Sanity check ? I'm a Mechanical Engineer, but I would never profess to think I know any more than the next man, we can all learn something from others, and to tout the "I'm an engineer" line smacks very much of arrogance im afraid.
                                    Surgikillundefined 1 Reply Last reply Reply Quote 3
                                      @surgikill
                                      I don't think I'm the one having a bad day here - in fact I'm pretty chilled.
                                      I don't really want to get into a discussion with someone who has to resort to personal insults, nor someone who seems to have some sort of paranoia syndrome, but I think you need to re-read my posts before you go off on a rant.
                                      I never said that a low power cartridge would work as well as high power one. Read what I wrote again. You rightly say that a high power cartridge will have decreased rise time. However, because you don't know anything about the application, you don't know that a rapid rise time is in fact undesirable in this case.
                                      As for the FET failure, as an engineer you will know that they can fail in a way that means they are fully on. So, if you are using a PID to control a heater using PWM, and that heater is too highly rated for the application then you will know that in the event of a FET failing fully on, the heater could reach a dangerously high temperature and cause a fire. This is why when you tune a heater, the predicted maximum temperature is reported and flagged as a potential fire hazard. You think this is bullshit? Then I am singularly unimpressed by your claim to be an engineer.
                                      Suggest you take a chill pill and re-read what has actually been posted before you launch into your next rant.
                                      Oh and BTW, I don't have a Donkey but if I did, why would it have a stick in it and why would I need to remove it before sitting down?
                                      wilrikerundefined 1 Reply Last reply Reply Quote 2
                                      • wilrikerundefined
                                        wilriker @deckingman
                                        @deckingman said in Simple heater question SOLVED:
                                        Maybe, because once you sat down it will be harder to find the motivation to get up again to finally take that stick out of the donkey - the poor animal should not suffer longer than necessary. 😂 (Sorry, couldn't resist 😁 )
                                        Manuel
                                        My Tool Collection
                                          @calvinx Yes I have. I'm sorry but if you read the exchange I had with wilriker I simply threw ideas out there and then had a rant thrown at me. The only reason I question his capabilities is because he became extremely defensive of his decision without even providing anything to back it up. That usually reeks of somebody that has no clue what they are talking about. I'm sorry that I responded with the same level of arrogance I received in his post. Maybe I should just lay down and let him have his way with me?
                                          @deckingman You seemed to want the cheapest way out of it from what I read in the previous posts. You also said that you are going to have your own cartridges made. You could still use PWM for testing purposes then get your own cartridges made, be my guest. All I'm trying to do is help YOU not run around wasting money like I have done before, but apparently you knew what you wanted to do from the start, which was use power resistors. Be my guest. Don't understand why you come here for advice and then get pissed about it though.
                                          I'm also not going to get into the FET failure. If you really want a detailed answer then I'll provide it assuming you aren't an ass about it, but simply put you will have extremely poor performance if you are looking for a heater cartridge to work at 200-300C but not exceed 400C
                                            Who said anything about a working temperature of 200-300C? I certainly didn't.
                                            There you go again with your assumptions. I'm not arguing with anything you say, just pointing out that the "facts" as you state them are based on false assumptions which in turn are based on some pre-conceived notion of what it is I'm working on.
                                            You have no idea of the application or configuration because I haven't given any details. Yet for some reason you know better than I what it is I need. You go off on a rant that I'll get extremely poor performance for a heater cartridge that will work at 200 -300 deg C and not exceed 400C. That may be factually correct but it's irrelevant because I'm not looking at those temperatures. I never said I was. For all you know I could be working on something that'll re-heat my coffee to 60 deg C when it gets cold.
                                            As for PWM vs a series resistor - you might be right. I have never disputed that if you calm down a bit and actually read what I have written. As it happens, I do have reservations that simply limiting the max PWM value would give an accurate simulation of a higher resistance heater. I don't know enough about the PID algorithm that Duet uses to have an opinion. I wonder about things like the dead time for instance and how that might be different between a fixed value resistor and a lower value resistor being fed at half PWM . Maybe it wouldn't matter - I don't really know. But I'd rather use a series resistor as I believe (rightly or wrongly) it will give me a more accurate simulation. The reason for starting this thread was that I just needed a quick confirmation on the application of Ohms law because it was some 50 years ago when I was taught that and I haven't used it much since.
                                            So if you just calm down a bit and read what I've actually written, the only thing I have an issue with is that you are basing your recommendations on some pre-conceived notion of what it is I am working on, which in actual fact is quite a way off the mark.
