    Laser Filament Monitor 'SW' PCB Pads
    laser monitor filament
    1.6k
    • SnowCrashundefined
      SnowCrash
      I got Duet's newly released laser filament monitor a while back but only now starting to look into hooking it up in my rig & I have the following questions which I'm hoping to get some info on:
      (1) on the sensor's PCB there are a couple of round pads marked 'SW'. Looking at the schematics they seem to me to be intended for connecting an external reset switch - is this correct? and if so, has anyone utilized this feature? How useful is it to have?
      (2) What would be the best background color (if any) for the inner chamber where the sensor's 'camera' chip is located (i.e. where the filament runs and inspected by the chip)? does the color even make a difference in this context?
      Many thanks in advance.
      SnowCrash
        1. It's for an optional filament presence switch.
        2. It must be printed in black.
        SnowCrashundefined 1 Reply Last reply Reply Quote 0
          SnowCrash @dc42
          @dc42 said in Laser Filament Monitor 'SW' PCB Pads & Inner Chamber Color:
          Thanks for the very quick response, @dc42!
          Could you please elaborate on what 'an optional filament presence switch' is and what it does?
            A filament presence switch is a simple switch that tells the sensor whether filament is present or not. So it can tell the Duet instantly when a spool runs out. But it's not really needed, because the end of the filament will pass through the filament monitor, which should detect loss of motion before the end reaches the extruder drive.
              SnowCrash @dc42
              So the voltage across these pads alternates between High & Low on the basis of filament presence regardless of the main signal from the monitor module? does this functionality exist out-of-the-box or are tweaks needed?
                You need to change the filament monitor type in the M591 command to enable the filament presence switch.
                  SnowCrash
                  I had another look at the schematics for the filament sensor and I'd like to know if I got this straight (it seems like my previous understanding of the SW pads' function wasn't right):
                  If I bridge the SW 'jumper-pads' (J1) - then the Signal Output (i.e. OUT on P1) becomes a binary output, that is, High for 'no filament' & Low for 'filament present' (or, perhaps, vice versa)?
                  Also, what is the purpose of the M2 pads (according to the schematics they bridge PA0 & PA1 on the ATtiny)?
                    dc42 administrators @SnowCrash
                    @snowcrash said in Laser Filament Monitor 'SW' PCB Pads - Unsolved:
                    No. One of the 16 bits in the position report returned to the Duet is the switch status.
                    To make it easier for us (or anyone else) to prototype new functionality.
                      SnowCrash @dc42
                      @dc42 said in Laser Filament Monitor 'SW' PCB Pads - Unsolved:
                      Ok, so... was my original understanding correct? that is, the voltage reading between the 2 pads (High/Low) serves as an indicator for filament present/not-present?
                      In what why exactly? could you please give an example?
                        Our intention is that if you want to add a filament presence switch, you add a switch that shorts those 2 pads together when filament is present.
                        No, because we haven't used them yet.
                          SnowCrash @dc42
                          Ok, thanks
