    Mesh Grid - Result is not ok
    2.9k
      Phaedrux Moderator @lui2004
      @lui2004 said in Mesh Grid - Result is not ok:
      Error: Z probe already triggered before probing move started
      Try increasing your dive height perhaps? I'm not super familiar with the behaviour of the IR probes.
      I can't tell from the number grid if that's an improvement or not. Does the image look more consistent?
      lui2004undefined 1 Reply Last reply Reply Quote 0
      • Wyvernundefined
        Wyvern
        Is there any direct lighting around your machine? is your machine around any natural (outside) lighting? I have read that florescent lighting and possibly LED lighting can cause issues.
        • lui2004undefined
          lui2004 @Phaedrux
          @phaedrux Hi
          no the image is still the same nothing change
          hope everybody can help me to solve
          • lui2004undefined
            lui2004 @Wyvern
            @wyvern Hi
            no, no direct lighting to the machine.
            only normal natural lighting and no LED or somthing else
              Are the thick whites lines on the bed in your photo part of the bed, or part of a print? If they are part of the bed then it's possible that you may get a different trigger height when you probe over them, compared to probing over the dark grey areas.
              The only types of lighting that affect the IR sensor are direct bright sunlight (no clouds in front of the sun), and bright tungsten halogen light. If the sensor detects too much of either, the LED will blink rapidly.
              UnderDoneSushiundefined 1 Reply Last reply Reply Quote 0
              • UnderDoneSushiundefined
                UnderDoneSushi @dc42
                @dc42 https://i.ytimg.com/vi/YGnV8EXvhzs/maxresdefault.jpg
                It part of the logo, when I saw this I was going to assume it was causing problems. OP's probe also looks like it is over the edge of the bed?
                • antlestxpundefined
                  antlestxp
                  its hard to tell but it almost looks like the logo is clear or doesn't have black. that will trip up an ir sensor
                    Yes, the probe points will probably need to be adjusted so that the sensitive area of the IR sensor (roughly under the cylindrical black capacitor) are never off the edge of the bed or over the white areas of the logo.
                    • lui2004undefined
                      lui2004
                      Hi
                      Yes i found out The white areas are the problem.
                      I have tested with black matt paper the mesh is flat / green now.
                      How can i set new probe points only of The black bed for G29?
                      You have an example for me ?
                      Sorry my english is bad
                        The probing grid for G29 is defined by the M557 command. You would need to chose the X and Y spacings and the range to avoid the white logo.
                        Alternatively, if you can probe with a piece of black paper lying flat on the bed, do that. If the printer is mechanically stable, you shouldn't need to probe very often. For most prints you can load the height map produced by the last probing you did, by sending command G29 S1.
                        • lui2004undefined
                          lui2004 @dc42
                          @dc42 i will test it to load the highmap and to print
                          I have order PrintBite in Black Matt hope this will work with your mini ir
                          Thanks
