    Multi color printing with Prusa's MMU V2 & Duet?
    91
    23.0k
    • Bester42undefined
      Bester42
      You are perfectly right.
      The reason to use an extra Arduino (clone) is Prusa Research contantly improving and updating not only the printers firmware, but also firmware of mmu.
      So by adding an extra Arduino (Clone) you add only a cost of 3-4€, but making maintence much more easy.
      Also an Arduino is not an multitasking system. So checking gpio's, constantly control extruder movement, you have to make shure not to interfeare with the mmu's functions. So it would require much more programming skills.
      Using an extra Arduino the code would be much more easy. It's strictly single task.
      1. Watch rotation of extruder
      2. If unload detected, send comand to mmu
      3. Watch rotation of extruder
      4. If movement (1-5mm) detected, send comand to load and Insert filament 1...5
      5. If a filament sensor detects Filament Inserates (or mmu tells thad loading ist completed) give signal to the printer.
      6. Goto 1.
      I do not think Prusa will change comands a lot in future (maybe add "success" comand from printer if the printhead filament sensor detects loaded filament - but due to bad relability of prusas sensor I do not think this coming soon). So an "Interface-Arduino" is much simplier than modding mmu-firmware, much more easy to modify.
      • gavatron3000undefined
        gavatron3000
        Might be another idea to use this fellas version of the firmware for Arduino but modify it to change via multiplexer or a digital IO somehow. That way the duet initiates the changes but it fully controlled by the Arduino. He's also added another sensor to the system
        https://github.com/cskozlowski/mmu2
        • patakopecekundefined
          patakopecek
          I think it would be possible to do everything (even the checking with the finda) via the duex board, David suggested to set up the finda for a dummy axis that would try to home while moving the E and the dummy axis at the same time, that would be for the FINDA part, the macros would handle the filament switching part but the only problem I could find is the filament cutting part, it is not possible to assign macros to the stall detection, so the cutting could not be triggered
            dc42 administrators @patakopecek
            @patakopecek, supporting macro execution on stall detection is under consideration for a future firmware revision.
              gavatron3000
              the problem ive found when trying to home to endstop/pinda is if it doesnt reach the sensor it just carrys on with the rest of the macro, if there was a feature to home to endstop but if not reached by Xmm or Xseconds then pause or retry. but this may be leaning towards conditional gcode
              ive got a home built MMU2 unit hooked upto the duex2 now, just testing at this stage
                dc42 administrators @gavatron3000
                @gavatron3000 said in Multi color printing with Prusa's MMU V2 & Duet?:
                If it doesn't reach the endstop, then I presume either the amount of movement specified in your G1 S1 command is too low, or you are using G1 S1 without selecting relative coordinates first, or your axis is getting stuck. The first two are easily fixed, the last is mechanical
                  gavatron3000
                  Yes exactly, the drama is with relation to the mmu2 is if there is a jam during loading the firmware isn't able to detect this until perhaps the filament sensor is reenabled just before printing with a new tool
                  This also applies when unloading too
                  I guess though it still picks up the error eventually, I'll try jigging the macro's differently by enabling the filament sensor at different points see what outcomes occur during tool changes
                  Just thinking out aloud here, don't mind me
                    gavatron3000
                    Hi all, id thought id report back to say running the mmu2 with the duet and duex is possible and working even with loading and unloading detection using the "finda" style setup. its all working as expected now i just need to dial my ramming settings to get good tips. if anyone has any questions let me know. but its a win
                    my next thing is to setup filament-change.g to unload filament through the front of the mmu
                    • Ungreonundefined
                      Ungreon
                      I'm assuming you got the full thing working without the prusa MMU v2 board? If so did you modify the MMU assembly at all or just assemble it without the board? Would you consider sharing the g code or slapping together a short tutorial on how to accomplish your solution?
                      gavatron3000undefined 1 Reply Last reply Reply Quote 1
                        gavatron3000 @Ungreon
                        @ungreon said in Multi color printing with Prusa's MMU V2 & Duet?:
                        So my mmu2 is just the original without the Prusa electronics. It's hooked up to the duet and a duex2. Longest part in getting it running was getting the endstop configuration on the fly and loading and unloading detection triggers running correctly with additional axes. I'm happy to share my macros, I'll write some things down and share when I get some free time.
                        Hardest part is shaping the tips so it's reliable,
                          gavatron3000
                          Here's the first document I wrote for the mmu2. Treat it as a beta at the moment as I'm sure as more people get more hours with it I think there would be improvements.
                          https://docs.google.com/document/d/13r_6BTYTO-xlD6cQeNwOx4qeCEYYGrxOcHc0mC-tT8Q/edit?usp=drivesdk
                          • NicoLab28undefined
                            NicoLab28
                            I used the few scripts you had given me, and it's almost starting to work for my MMU.
                            But my questions are, do you use a cutter, and where?
                            Do you use ABS filament or just PLA or other.
                            For my part, I have big problems with the ABS, because it happens to make obstructions, or he puts me back pieces.
                            The only solution I found is to cut as close to the head as possible.
                            I saw that some used a cutter at the level of the selector, but it might congest too?
                              gavatron3000
                              I don't use the cutter, for me I didn't think it's necessary as the ramming before retraction forms the tip anyways. Abs just works but pla is more difficult. Make sure you use the correct I.D PTFE tube in the Hotend as well. 1.8mm to 1.85mm. capricorn tubing isnt narrow enough either, ive tried.
                              I almost forgot! I'm adding some modded STL and scad files soon so the filament change will function perfectly as the filament ejection will snag on T4 without a small mod to the selector and main body of the mmu2
                              nikschaundefined 1 Reply Last reply Reply Quote 0
                                NicoLab28
                                You are in live drive, I looked at your Tipsmoothing.g
                                10s break anyway, it's just for testing, or is it really necessary?
                                On my side, it is not too much a problem of diameter of ptfe, I ordered, but of hair, which does not see itself and accumulates until stuffing. I should test your method.
                                I put transparent tube, and it is obvious.
                                The worst thing is that it's not regular, it happens from time to time. 15-20 tool change without worries, and boom!
                                That's why, I put a cutter.
                                I have the impression, that reliability will be a very hard thing to obtain.
                                I think I'll test the standard version, what change do you think you'll make? Your files are coming soon?
                                  gavatron3000
                                  look at the link above the info is there, but the files ill add are only for filament changes that affect T4 so 90% of printing is unaffected. if you getting strings you need to tune your ramming settings correctly. this you need to do on your slicer to suit your machine
                                  @nicolab28 said in Multi color printing with Prusa's MMU V2 & Duet?:
                                  probably not its just a value that definitely works, i was finding that if i retracted too quickly through the extruder it was mashing my tips and causing jams
                                    gavatron3000
                                    adding a cutter to the macros wouldnt be hard youd just need to add a fast selector move across the mmu that chops the tip off if thats what you want but again it'll just build up under the selector anyway. better off just tuning the ramming right
                                    • fmaundefined
                                      fma
                                      Quality of the tips also depends on the time the filament spents in the nozzle (without extruding). Especially with PLA. I have a simple settings which work great, unless the PLA is sitting in the nozzle for 2 or 3 minutes (in this case, I get oozing).
                                      The solution is to pre-retract the filament at the end of a print.
                                      Frédéric
                                      • Scachiundefined
                                        Scachi
                                        Where do you buy 1.8mmx3mm ptfe tubing from ?
                                        I can't find a source for that. A german shop would be nice but shipping to Germany is good enough
                                          gavatron3000
                                          theres a link in the document above
                                          Scachiundefined 1 Reply Last reply Reply Quote 0
                                          • Scachiundefined
                                            Scachi @gavatron3000
                                            Thank you.
