    Why am I having to run with an extrusion multiplier of 60%?
    143
    28.4k
    • peridotundefined
      peridot
      @deckingman:
      No probs. It's just that I don't like mysteries. There has to be a logical explanation and it's bugging me that I can't find it.
      The under extrusion is due to me changing the setting in slic3r from 0.5 to 0.6. When I run 0.5, I get over extrusion (or some effect that looks exactly like over extrusion). It's looking like the sweet spot will be somewhere between the 0.5 and 0.6 but I need to do more tests to be sure. In any case, it seems that, for whatever reason, my machine is very sensitive to how the nozzle width is set in slic3r.
      As for the patterns, the only time 2 motors turn is when it lays down the perimeter. For infill, it was near left to far right of the build plate for BOTH of the "cubes". That is to say, the left hand motor tuned but the right hand motor was stationary when doing infill in BOTH cases. It seems that when you set infill direction in slic3r it is the direction on the build plate, regardless of how the object perimeters are orientated. Don't forget that as far as slic3r is concerned, this was single object created from a single stl file.
      So the mechanics/dynamics of the machine were identical (apart from the fact that one cube is physically offset to the right of the other). That's really freaking me out.
      In an effort to resolve the mystery, would weighing objects help? I mean, you can weigh a piece of filament to find out its density (optionally linear density), and then weigh a printed object to see whether the weight of the printed object equals the weight of the filament you told the extruder to put into it. Unfortunately my kitchen scale is only good to the nearest gram, so I'd have to print something big (and my extrusion multiplier isn't doing anything weird) but it would answer whether the amount of filament coming out is really the amount the slicer thinks should be coming out. You can also, of course, measure the length of filament extruded against the amount the slicer thinks needs to be extruded.
      I got some weirdness when I had troublesome retraction settings: normal extrusion would work, retraction would work, but un-retraction wouldn't. so I'd get strange under-extrusion problems, and ultimately I got a hot end jam as the molten plastic was pulled back into the heat sink. This isn't what you're describing, but could retractions be failing to actually retract? That would produce extra extrusion, depending on the model.
      What difference does nozzle size actually make to this? All the plastic that goes into the melt zone has to come out somewhere, and unless it's squeezing out the top (keeps happening as my E3D v6 unscrews itself) it's got to go into the print. Similarly, there's no extra plastic coming from anywhere. The nozzle size just sets how thin you can expect an extrusion to come out okay.
        deckingman
        @ Peridot,
        I know this is becoming a long thread so maybe you haven't read it all through but if you go back a bit, you'll see that I've done everything you suggest (apart from weighing object that is). On printing a 1cm cube, slic3r calculates that it will need 417.8mm of filament which is exactly right when you do the maths for 1.75 mm dia filament. On printing that object, my initial steps per mm where a little high and it actually used 437mm of filament. Adjusting the steps per mm from 424 to 405 has got it very close. That is to say, when I print the object it uses very close to 417.8 mm of filament. That's with retract on layer change enabled so it's a good "real world" test which gives me confidence that the extruders are doing exactly what hey are supposed to do. The freaky thing is that the resultant cube has all the attributes of an object where the extrusion setting was too high (bulging corners, poor finish, lumps and blobs and dimensionally slightly too large). If I then print the same cube with an extrusion factor of 0.8 then it uses 80% less filament (around 330 mm) but the resultant object looks perfect, (although it is dimensionally a little under sized).
        Ref difference in nozzle size? It beats me. When sliced, the calculated filament usage and object volume are the same, yet the print quality is totally different. 0.5 gives the effect of severe over extrusion (as detailed above), whilst 0.6 gives the effect of under extrusion - gaps between the lines, poor adhesion etc. My only thought is that the spacing between lines must be different. e.g for an object that is say 30mm across, if the slicer thinks the extruded filament is 0.6 mm wide, it will take 50 lines of filament to span that width, but if the slicer thinks the filament width is 0.5 mm, it will take 60 lines. Of course, the 50 lines should have more filament per line so it ought to cancel out.
        I'm planning on doing a series of prints with the same object sliced using nozzle widths between 0.5 and 0.6 in 0.01 increments just to see.
        After that, I think I need to find a nice sun bed, somewhere hot and sunny, next to a pool, in order to restore my sanity.
          Hi Ian,
          You can store the gcode files on dropbox or a similar cloud storage site and post a link.
          You said that your cubes are a little under sized. By how much? If your X and Y axes are not moving enough, that will lead to over extrusion.
          David
            deckingman
            @dc42:
            Hi Ian,
            David
            1. I'll put the file on my google drive and post a link then.
            2. Cubes are a little undersized when extruding at 80% (about 0.2 to 0.3 mm) and a little over sized when extruding at 100% (again, about 0.2 to 0.3 mm). That's regardless of the size of the object so on a 10mm cube its 2 to 3 % but on a 100mm it's 0.2 to 0.3%
              deckingman
              Herewith link to gcode file
              https://drive.google.com/file/d/0B_MwtHtQR_ZvVlRUaHpfX3VZYzA/view?usp=sharing
              Permission is set to anyone with link can view. Let me know if you want me to change that to "edit".
              • peridotundefined
                peridot
                @deckingman:
                @ Peridot,
                Sorry about that. I see you have been pretty darn thorough - I just don't like mysteries either.
                It's starting to sound like a slicer problem of some kind - if the extruder is putting out just what it was asked to, then the slicer must be asking for too much plastic, surely?
                The nozzle diameter does affect what thicknesses of filament and layer heights are a good idea. Specifically, you can't easily lay down tracks much thinner than the nozzle size. So for slicers that automatically determine the width of infill, a bigger nozzle will lay down thicker lines (and fewer of them). So there will be differences in what the print looks like. Some of these differences will be non-obvious: the cross-section of a piece of extruded filament is a complicated rounded-edged shape that depends on the layer height, the nozzle width, the intended width, whether there are any other lines nearby, and even whether the path is curving. So the prints should look different, including whether there are air gaps inside them, but the total amount of plastic should not change.
                The sun bed is starting to sound like a good idea.
                  deckingman
                  @peridot:
                  Nothing wrong with that logic. However, when I slice a 1cm x 1cm x 1cm cube, with 100% infill and no skirt or brim, then check the gcode file, slic3r reports the volume to be 1cm^3 and that it will take 417.8 mm of filament to produce the object. If you do the maths, using 1.75 mm dia filament you get (1.75/2)^2xPi x 417.8 = 1000mm^3 (or 1cm^3). So on that basis, the slicer is asking for exactly the right amount of filament (and I now know that the printer will deliver exactly what it is asked to deliver).
                  When I print the object, it has the appearance of being printed with too high an extrusion rate and if I print it with 80% of the correct amount of filament, it has the appearance of being printed with the correct amount of filament. Note that I am now using the expression "appearance of" rather than stating that it is over extruded. I think there is a distinction somewhere between the two - but I'm not sure yet what that distinction is.
                  Not that this is driving me crazy but I have to go - there is a little man wearing a white lab coat knocking on the door….....
                    Have you tried a different filament?
                    • botundefined
                      bot
                      I wonder if your printer is not printing in the correct x/y scale? Have you verified this? If your 10x10 cube with the correct volume of plastic is trying to take up 9.5x9.5 area, it would be squishy. Maybe incorrect Z scaling, too?
                      *not actually a robot
                        deckingman
                        @bot:
                        Hi bot
                        As per one of the above answers, cubes are a little undersized when extruding at 80% (about 0.2 to 0.3 mm) and a little over sized when extruding at 100% (again, about 0.2 to 0.3 mm). That's regardless of the size of the object so on a 10mm cube its +/- 2 to 3 % but on a 100mm it's +/- 0.2 to 0.3% depending on the extrusion amount I use. Given that it can be under or over, I'm reasonably certain that the steps/mm in X Y and Z are correct.
                          deckingman
                          @dc42:
                          I only have PLA - that's all I've ever used to date. I get the same result with "solid" Black and White and translucent Red, Yellow, and Clear, so 5 different reels but all PLA. They were from 3 different sources and bought at different dates about 4 months between the earliest and newest. I keep the filament in evacuated plastic bags with silica gel in the bag - the colour changing stuff that tells me when it's becoming saturated (and it's not).
                            deckingman
                            Latest (and probably final) update. Firstly here is a link to a picture of the issue.
                            https://drive.google.com/file/d/0B_MwtHtQR_ZvbkJoN0l1Y3FUYTQ/view?usp=sharing
                            It's exactly the same part, the only difference is that the one in the foreground was printed using an extrusion factor of 1.00 and the (better) one in the background was printed using an extrusion factor of 0.80. When the printer puts down the first layer, with extrusion factor of 1.00, the edge of the extruded filament is "rippled" - as if there is too much filament with nowhere to go, but with an extrusion factor of 0.80 it's a nice smooth "tube" of filament. When the vertical sides are being printed, these large blobs appear using 1.00 and I get stringing as if there is too little or no retraction, but there is no sign of any of this using a 0.80 (80%) extrusion factor. It's almost as if there is a build up of pressure at the nozzle tip caused by too much filament trying to be forced out through too small a gap and then suddenly is just "explodes" and releases the pressure but causes the blob. It looks like it can happen at any point, either on the perimeters or in the solid infill.
                            My thoughts at this moment in time are that it has to be over extrusion and that there is nothing else weird happening that is being masked buy under extruding. There also seems to be quite a bit of discussion on the "interweb" with many users of slic3r version 1.2.9 having the same problem. Some have said that rolling back to an earlier version fixes it. I know that if I slice a 1cm^3 in slic3r it generates exactly to correct amount of filament to fill that space. Maybe that's the problem. As someone has said, because of the way the filament is laid down, it's not "cube" shape so there will be gaps between individual threads at some points. So, it should take less filament to fill a given space to account for these gaps (but 20% or more seems an awful lot).
                            I've looked at other slicers but don't want to pay money in case that's not the problem. Other free ones don't have the features I need (like support for firmware retraction and multi colour parts for example). So, much as it pains me, in the interest of saving what little sanity I have remaining, I'm going to give up and just run with slic3r and a low extrusion factor, or maybe try an earlier version.
                            (Unless of course, someone comes up with a better idea…........).
                            • iDeveloundefined
                              iDevelo
                              You tried this? https://www.raise3d.com/pages/ideamaker
                                deckingman
                                @iDevelo:
                                Thanks for the thought - had a quick look- seems to be specific to their machines - apart from anything else, it only support 2 extruders and I have 3.
                                  T3P3Tony administrators
                                  Hi Ian
                                  Try Cura to see if its the slicer, even if it does not suit all your other needs.
                                    deckingman
                                    Hi Tony,
                                    I'm convinced it's slicer (slic3r) related. Got Cura but it doesn't do firmware retraction (at least I can't find it). So even if it worked in other respects, I'd be printing with effectively no retraction and the prints would still be awful. At least with slic3r and setting extrusion factor of 80% in the filament section, I can get decent quality prints. I've enquired of S3D as to whether they have plans to support firmware retraction -waiting for a reply. AFAIK, slic3r is the only one that does multi part (multi colour) objects and firmware retraction.
                                      Ahh fair enough, I don't use firmware retraction, never found the need at least in a single extruder setup.
                                        I have it in mind to support auto firmware retraction as Marlin does, i.e. identify retraction/un-retraction gcodes and use the firmware retraction parameters for them. But there is the possibility of mis-interpreting moves. So firmware retraction support in S3D would be better.
                                          deckingman
                                          Just looking through the online documentation, it doesn't look like S3D can support 3 extruders either. Dual extruders but not 3 (unless someone can advise me otherwise).
                                          Slic3r actually gives you the choice of 4 extruders (tools) to choose from if you define the printer as having 3 extruders. I guess the authors were aware that with a mixing hot end you can have any number of combinations. Shame it's giving me this problem because otherwise, it does everything I need (but at least I've found a workaround).
                                          • Dougal1957undefined
                                            Dougal1957
                                            Looking at my S3D Install it appears that it CAN support upto 6 Tools (Don't ask how you configure it) but you can select from tool 0 to tool 5.
                                            Doug
