Z probe X/Y offset
I have a quick question about setting up a Z probe. I am setting up a DC42 IR probe on my CoreXY and it is slightly offset from the nozzle. I've read the documentation about setting the Z offset, but I am wondering where/if I can set an X/Y offset from the nozzle. When I used Marlin before I had to set an X/Y offset, such as the probe point is 25mm X and 40mm Y offset from the nozzle. Is this needed here? I would assume so. I am also using 4 independent lead screws for bed compensation, so I'm unsure if it's needed or not.
With G31
