    sd card size
    758
    • Monster Deltaundefined
      Monster Delta
      is there a maximum capacity for the micro SD? for instance could i dd a 128gb card or higher?
      DonStaufferundefined 1 Reply Last reply Reply Quote 0
      • UnderDoneSushiundefined
        UnderDoneSushi
        I switched to a 32gb sandisk which has worked well. It just has to be formatted correctly which is on the Duet Dozuki and is different than the included microSD card. I would save your money and not go for a 128gb card, its overkill. Especially if you use Google drive or Dropbox.
          Monster Delta
          I've got a few 128gb lying around or i'd have to swap one out from somewhere
            T3P3Tony administrators
            The SD card subsystem is SD 2.0 - that supports SDHC cards but not SDXC.
            That means the limit is 32 GB.
              Monster Delta
              ok great thanks
              • DonStaufferundefined
                DonStauffer @Monster Delta
                This post is deleted!
                  DonStauffer @T3P3Tony
                  @T3P3Tony I'd also like to know if there's a maximum SD card size for PanelDue.
                    jay_s_uk @DonStauffer
                    @DonStauffer the same as mainboards, so 32GB
                      dc42 administrators @jay_s_uk
                      For anyone interested, the issue is that FAT32 only supports up to 32Gb. Larger capacity SD cards use EXFAT format but that's subject to Microsoft patents.
