    fans not responding.
    2.7k
    • ohluckyirishundefined
      ohluckyirish
      == Diagnostics ===
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later
      Board ID: 08DGM-9T6BU-FG3S4-6J1D8-3SD6J-1VR7F
      Used output buffers: 3 of 20 (9 max)
      Static ram: 25524
      Dynamic ram: 98620 of which 0 recycled
      Exception stack ram used: 280
      Never used ram: 6648
      Tasks: NETWORK(ready,656) HEAT(blocked,1232) MAIN(running,3788) IDLE(ready,200)
      Owned mutexes:
      Last reset 00:00:19 ago, cause: power up
      Last software reset at 2019-02-12 20:13, reason: User, spinning module GCodes, available RAM 6648 bytes (slot 2)
      Error status: 0
      Free file entries: 10
      MCU temperature: min 18.3, current 21.5, max 21.8
      Supply voltage: min 12.7, current 12.7, max 12.8, under voltage events: 0, over voltage events: 0, power good: yes
      Date/time: 2019-02-13 17:55:58
      Cache data hit count 63519798
      Slowest loop: 6.96ms; fastest: 0.07ms
      I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
      Bed compensation in use: none
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 22.72ms; fastest: 0.00ms
      Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        WiFi firmware version 1.22
        WiFi MAC address cc:50:e3:14:b7:80
        WiFi Vcc 3.34, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 26008
        WiFi IP address 192.168.1.43
        WiFi signal strength -58dBm, reconnections 0, sleep mode modem
        Socket states: 4 4 0 0 0 0 0 0
        ohluckyirish
        here is what i put as my fans
        M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, gcode control for part cooling fan
        M106 P1 S0.5 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
          ohluckyirish
          which position should the jumper be in ?
            Phaedrux Moderator @ohluckyirish
            @ohluckyirish it looks like you have a 12v power supply so if your fans are also 12v you would bridge the vin and vfan pins with the jumper to feed the fans 12 volts.
              ohluckyirish
              so the two pins on the right ?
              it is currently on the Jumper: int 5V EN
                @ohluckyirish that's right
                  ohluckyirish
                  the part cooling fan came on that is plugged into the always fan port, but none of the green lights come on ?
                    ohluckyirish
                    is there only post to be one jumper in ?
                      @ohluckyirish said in fans not responding.:
                      I'm not sure what you mean.
                        ohluckyirish
                        i moved the jumper from the int 5v en to the v fan jumper fan select. now only the fan comes on and none of the green lights on the board come on
                          ohluckyirish
                            Take a look at this if you haven't already seen it. https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans
                            There should be a jumper that connects the V_FAN and VIN pins. I don't think you need to touch the INT 5V EN or EXT 5V EN pins at all.
                              ohluckyirish
                              okay i got it i needed to add a jumper to both the v fan and int 5v. im so afraid of damaging the board i have already damaged two gorilla boards on my anycubic kossel.
                                @ohluckyirish Well it definitely pays to be cautious and to make sure you're connecting things the right way. It also pays to read up before diving in.
                                This is a good place to start. https://duet3d.dozuki.com/Wiki/Step_by_step_guide
