    Mid Air Prints unless I Restart
    2.4k
    • p40whkundefined
      p40whk
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v2 on Thu Jan 03 2019 13:44:38 GMT-0500 (Eastern Standard Time)
      G91 ; relative positioning
      G1 S1 X-240 Y-240 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 S1 X-240 Y-240 F360 ; move slowly to X and Y axis endstops once more (second pass)
      G90 ; absolute positioning
      G1 X15 Y15 F6000 ; go to first bed probe point and home Z
      ;G91 ; relative positioning
      ;G1 S2 Z5 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
      ; bed.g
      G28 ; home
      G30 P0 X20 Y20 Z-99999 ; probe near a leadscrew
      G30 P1 X115 Y115 Z-99999 ; probe near a leadscrew
      G30 P2 X210 Y210 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
      G29 S0 ; probe the bed and enable compensation
      G28 ; home
      Slicer End-Code:
      G91
      G1 Z10 E-1 F1200 ; move Z up and retract filament 1mm
      G28 X0 Y0 F1200 ; Home X and Y Axis
      M104 S0 ; turn off extruder
      M140 S0 ; turn off bed
      M84 ; disable motors
        Does the printer not home itself when starting the new print?
        What firmware version are you using? DWC version?
        • p40whkundefined
          p40whk
          It does home itself, and DWC is at 1.21.
            Phaedrux Moderator @p40whk
            @p40whk is the firmware at 1.21 as well?
            There was a bug around that version that would stack the z offset causing problems like you describe. I suggest you upgrade your firmwares.
            • p40whkundefined
              p40whk
              Thanks but I misspoke, I wasn't at the computer where my printer is but I am up to date on firmware
              • RandomFactoidundefined
                RandomFactoid
                I've seen at least 3 posts of this kind (one from myself) about this exact issue - Z height increment between subsequent prints. Don't think there was ever a solution but to babystep for the 1st layer (in my case for instance the Z babystepping required would be around 0.4-0.5mm) and then reset babystepping for the 2nd layer and magically 2nd layer comes back to normal layerheight. Interestingly, even though it prints in air, stopping the print and sending G1 Z0 sends the nozzle to the bed as it should be. I ended up migrating to klipper for this very reason, but reverted back as DWC/PanelDue were too much of a sacrifice 🙂
                Can't wait for a solution. Btw, if it'd help with debugging, i'm happy to post my configs.
                  When the G32 leadscrew bed levelling runs at the start of your print, does it run correctly at the start of the second print, and what corrections does it report?
                  p40whkundefined 1 Reply Last reply Reply Quote 0
                    dc42 administrators @RandomFactoid
                    @randomfactoid said in Mid Air Prints unless I Restart:
                    Are you able to construct a short GCode file that demonstrates this if I run it twice? Preferably without involving heating or extrusion.
                    Are you also using G32 leadscrew bed levelling?
                      RandomFactoid
                      @dc42 will try to do that asap...maybe today.
                      I am using G32 gantry leveling on Voron 2.1 using 4 z steppers with corrections of 0.0x or 0.00x on each one after 3 passes.
                      • p40whkundefined
                        p40whk @dc42
                        @dc42 said in Mid Air Prints unless I Restart:
                        Yes, it does run correctly at the start of the second print however, I didn't note what it reported, I'll set up a couple of jobs today and check that.
                          RandomFactoid
                          @dc42 thanks to your suggestion about the simple gcode, I think I found the problem.
                          Apparently if you have G10 in your pause.g (or, I suppose anywhere in your Gcode) and have Z hop defined in M207, after cancelling the print (or, I'd guess, finishing it without unretracting), after starting a new print, z=0 becomes the value of the Z hop height in M207, because it zhops, the print gets cancelled or finishes and never actually zhops down to previous height.
                          I tested this by uncommenting G10 from my pause.g and the problem disappeared. I also tried setting M207 Z(random number) and after starting a new print, Z=0 is at a height of (random number) and actually you can jog the nozzle into negative numbers after stopping the print...and it goes right to the negative height of M207 Z value.
                          This seems like a bug in the firmware as Zhop height doesn't get cancelled after the print finishes without unretracting.
                          p40whkundefined dc42undefined 2 Replies Last reply Reply Quote 0
                          • p40whkundefined
                            p40whk @RandomFactoid
                            @randomfactoid So I just checked and don't have G10 anywhere in my code and am not using M207 yet I still have this issue. So, my problem even though related does not seem to be the same.
                              RandomFactoid
                              @p40whk what values does M207 return ?
                              • p40whkundefined
                                I'm in the middle of a print right now, where/when would I use the M207 command?
                                  RandomFactoid
                                  Overall - at any point, but it'll probably be hard to see the output while printing. Although try that in console - it might work.
                                  Tbh your issue sounds exactly like mine, but, you're right, it's different if you aren't using G10 anywhere.
                                    @p40whk said in Mid Air Prints unless I Restart:
                                    M207 sets the parameters for firmware retraction. If you haven't set it up in the slicer to use it, it won't tell you anything. If you were using it, you'd know.
                                    • p40whkundefined
                                      p40whk @Phaedrux
                                      @phaedrux said in Mid Air Prints unless I Restart:
                                      That's kind of what I thought, it's not set up in my slicing program.
                                      I'm waiting for the first print to be done and I'll take a video of what it does when I go to print a new print.
                                      • jasperkmundefined
                                        jasperkm
                                        @p40whk could you check if there is a G10 command at the end of the .gcode file that you're running? (just before the end gcodes will run)
                                        • p40whkundefined
                                          p40whk @jasperkm
                                          @jasperkm said in Mid Air Prints unless I Restart:
                                          0_1550429099237_3030_filament_guide_v2.gcode
                                          I've attached the file I'm currently printing. Checked a few others as well and there is no G10 command present.
                                            RandomFactoid
                                            I was just told that GitHub is not very much looked at when it comes to firmware issues (posted the issue here just in case: https://github.com/dc42/RepRapFirmware/issues/266) ...so just want to check with @dc42 if there's anything else I could contribute to this ? I know you asked for Gcode...so just not to leave any unanswered questions, it was:
                                            G21 ; set units to millimeters
                                            G90 ; use absolute coordinates
                                            M83 ; use relative distances for extrusion
                                            G1 Z0.100 F18000.000
                                            G1 X50 Y50 F18000.000
                                            G1 F2000
                                            G1 X150 Y150
                                            G1 X50 Y150
                                            G1 X150 Y50
                                            With pause.g having
                                            G10
                                            G1 Z+20 F6000
                                            Armadillo1 created this issue in dc42/RepRapFirmware
                                            closed G10 changes Z=0 for following prints if not followed by unretract (G11) #266
