    [not yet solved] Tevo Little Monster DuetWifi errors
    My Duet controlled machine
    10
    140
    21.7k
    • RafBundefined
      RafB
      dc42
      what should be changed as parts to solve this problem of geometry?
      • boldnutsundefined
        boldnuts
        Try this guide and join this TLM group, https://www.facebook.com/groups/TEVO.Monster.Delta.Owners/
        0_1550049851528_TLM Ultimate Calibration Tutorial (1).pdf
        • RafBundefined
          RafB
          I thank you, I will study with precision.
          • RafBundefined
            RafB
            I just control the angle of the towers and I do not have the same exactly the same value. This can be my geometry problem?
            I will now control the length of my Delta Diagonal Rod
              Auto calibration will sort out the tower angles for you.
              • RafBundefined
                RafB
                I think it would be complementary to bring illustrations and or videos to the Duet manual on the essential control points of a perfect machine calibration. Especially for the illiterate technicians like me.
                • RafBundefined
                  RafB
                  I still do not understand the procedure of calibrating a delta with Duet but I will not give up. how to disable auto calibration? I think I can have a 1st more homogeneous without the self calibration. I checked everything manually and my tray with borosilicate glass is really flat.
                  • RafBundefined
                    RafB
                    My geometry problem may come from this problem (see video)
                    When I make a home and I go back 5mm to put out the leds of the endstops I always have an endstop that stays on.
                    I change endstop, screwed to racemess and unscrewed to lengthen the head of the screw, set the ten micro to have exactly the same distance between the three cart and the problem is the same, the led remains lit while the trolley is perfectly in front of the optical fork. When I push the cart slightly, the led goes out.
                    Can you help me understand this problem?
                    https://www.icloud.com/iclouddrive/0od7VaaViYMMcV5_HiBiwm8dA#IMG_5224
                    Stephen6309undefined 1 Reply Last reply Reply Quote 0
                    • synergy41undefined
                      synergy41
                      I have exactly the same problem as you.
                      I have an identical printer is impossible to turn off the limit switches,
                      I LOVE MY DUET WIFI
                      Board: Duet 2 WiFi (2WiFi)
                      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.1 (2022-06-01)
                      Duet WiFi Server Version: 1.26
                      Duet Web Control 3.4.1
                      Cura 4.10
                      • RafBundefined
                        RafB
                        Tu es Français non?
                        Tu as une couche de hauteur homogène avec ta TLM?
                        you have a 1st layer of uniform height with your TLM?
                        synergy41undefined 1 Reply Last reply Reply Quote 0
                        • Stephen6309undefined
                          Stephen6309 @RafB
                          @rafb Paint the flags with something that IR doesn't go through. Many plastics are transparent to IR.
                          RafBundefined 1 Reply Last reply Reply Quote 0
                            synergy41 @RafB
                            @rafb
                            Oui je suis bien Français...
                            Pour la 1er couche c'est pas trop mal à condition que je n'imprime pas quelque chose qui est une trop grande surface
                            I LOVE MY DUET WIFI
                            Cura 4.10
                            • RafBundefined
                              RafB @Stephen6309
                              @stephen6309 Hi, thank you for your proposal but it is a screw without black head
                              Dougal1957undefined 2 Replies Last reply Reply Quote 0
                              • Dougal1957undefined
                                Dougal1957 @RafB
                                This post is deleted!
                                  Dougal1957 @RafB
                                  @rafb sounds like you need to make it wider so that it definitely blocks the IR on the Endstops sitches
                                  • RafBundefined
                                    RafB @synergy41
                                    @synergy41 Ça m’a fait tilt quand tu as mis le lien les imprimantes 3D.
                                    Je pense pas que le problème vienne Du réglage de la mécanique. J’ai tout réglé au pied à coulisse. Je vais l’installer micromètre À la place du hotend Et vérifier la planéité du plateau. Si tout est parfaitement plat, je ferai une vidéo et demanderai de l’aide à dc 42 pour comprendre d’où vient le problème. Qu’en penses-tu as-tu d’autres propositions?
                                      synergy41 @RafB
                                      @rafb I think at home my tray is not really Top Top.
                                      I have to find a glass to try to see if I can print a larger area.
                                      What annoys me the most is the problem of limit stop.
                                      I LOVE MY DUET WIFI
                                      Cura 4.10
                                      • RafBundefined
                                        RafB
                                        yes the problem of endstop optical is a known problem with the duet. This is probably what leads to the problem of geometry and therefore the impossibility of having a suitable first layer. I have a borosilicate glass and I use a Thickness Gage to adjust the space between my nozzle and the boro glass bed. My bed is on 3 spring.
                                        I really have a hard time understanding? Having a 350mm bed to print pieces of max 100mm drives me crazy !!
                                          dc42 administrators @RafB
                                          @rafb said in [solved] Tevo Little Monster + DuetWiFi + DuetTouch7" errors:
                                          What problem are you referring to? The only problem I am aware of is that some optical endstops are designed to work with a 5V supply and don't work properly on 3.3V. The common ones can be fixed by changing one resistor (the one that feeds the IR emitter in the slotted opto switch). If it is an SMD resistor, soldering another resistor on top (to connect it in parallel) is easier because then you don't need to remove the old one.
                                          • boldnutsundefined
                                            boldnuts
                                            The optical ones supplied with the TLM work just fine with the Duet as is (well mine do) and I have a few spare ones that also work fine, it's just that the led switches on and off so fast that could be confusing you.
