    [not yet solved] Tevo Little Monster DuetWifi errors
    My Duet controlled machine
    10
    140
    21.7k
      That height map looks very good to me. Is there a problem?
      • RafBundefined
        RafB
        Yes, it's the same printer as Giostark so why the map is not more circular as can be seen on the Giostark map above.
        I am french and use googletrad and the tracduction of technical words to link to the impression are poorly translated. I still do not understand why my 1st layer is still so bad.
        I can tinker with some modify G31 P25 X0 Y20 Z0.84 but it's perfect. I think that on the mechanical side the printer is well tuned but I must not understand something in the calibration procedure.
        I do not know what information to bring for help with my problems.
          My guess is that you have a Z probe that is offset from the nozzle and you have a geometrical error that causes the effector tilt to vary with XY position. This causes the apparent trigger height of the Z probe to vary with XY position. It's possible to correct for this using H parameters on the G30 commands in bed.g, but tedious.
          • RafBundefined
            RafB
            I will try to control all these points but it is not obvious to be precise. By the way, what is the order of magnitude XX.XXXmm?
            When I do my calibrated to find the value G31 ZX and that I launch my impression I always 0.20mm too high. So I change the value of G31 Z0.687 + 0.20 to have a 1st layer that hangs and rotates between 0.25 and 0.35mm.
            I controlled the distances between the top of the printer and a point of the carts that had different values. I now have about 4cm everywhere I will try to do this with the caliper.
            But it did not really change the quality of my first layer (Nozzle 0.8mm)
            L'imprimante
            • RafBundefined
              RafB
              dc42
              what should be changed as parts to solve this problem of geometry?
              • boldnutsundefined
                boldnuts
                Try this guide and join this TLM group, https://www.facebook.com/groups/TEVO.Monster.Delta.Owners/
                0_1550049851528_TLM Ultimate Calibration Tutorial (1).pdf
                • RafBundefined
                  RafB
                  I thank you, I will study with precision.
                  • RafBundefined
                    RafB
                    I just control the angle of the towers and I do not have the same exactly the same value. This can be my geometry problem?
                    I will now control the length of my Delta Diagonal Rod
                      Auto calibration will sort out the tower angles for you.
                      • RafBundefined
                        RafB
                        I think it would be complementary to bring illustrations and or videos to the Duet manual on the essential control points of a perfect machine calibration. Especially for the illiterate technicians like me.
                        • RafBundefined
                          RafB
                          I still do not understand the procedure of calibrating a delta with Duet but I will not give up. how to disable auto calibration? I think I can have a 1st more homogeneous without the self calibration. I checked everything manually and my tray with borosilicate glass is really flat.
                          • RafBundefined
                            RafB
                            My geometry problem may come from this problem (see video)
                            When I make a home and I go back 5mm to put out the leds of the endstops I always have an endstop that stays on.
                            I change endstop, screwed to racemess and unscrewed to lengthen the head of the screw, set the ten micro to have exactly the same distance between the three cart and the problem is the same, the led remains lit while the trolley is perfectly in front of the optical fork. When I push the cart slightly, the led goes out.
                            Can you help me understand this problem?
                            https://www.icloud.com/iclouddrive/0od7VaaViYMMcV5_HiBiwm8dA#IMG_5224
                            Stephen6309undefined 1 Reply Last reply Reply Quote 0
                            • synergy41undefined
                              synergy41
                              I have exactly the same problem as you.
                              I have an identical printer is impossible to turn off the limit switches,
                              I LOVE MY DUET WIFI
                              Board: Duet 2 WiFi (2WiFi)
                              Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.1 (2022-06-01)
                              Duet WiFi Server Version: 1.26
                              Duet Web Control 3.4.1
                              Cura 4.10
                              • RafBundefined
                                RafB
                                Tu es Français non?
                                Tu as une couche de hauteur homogène avec ta TLM?
                                you have a 1st layer of uniform height with your TLM?
                                synergy41undefined 1 Reply Last reply Reply Quote 0
                                • Stephen6309undefined
                                  Stephen6309 @RafB
                                  @rafb Paint the flags with something that IR doesn't go through. Many plastics are transparent to IR.
                                  RafBundefined 1 Reply Last reply Reply Quote 0
                                    synergy41 @RafB
                                    @rafb
                                    Oui je suis bien Français...
                                    Pour la 1er couche c'est pas trop mal à condition que je n'imprime pas quelque chose qui est une trop grande surface
                                    I LOVE MY DUET WIFI
                                    Cura 4.10
                                    • RafBundefined
                                      RafB @Stephen6309
                                      @stephen6309 Hi, thank you for your proposal but it is a screw without black head
                                      Dougal1957undefined 2 Replies Last reply Reply Quote 0
                                      • Dougal1957undefined
                                        Dougal1957 @RafB
                                        This post is deleted!
                                          Dougal1957 @RafB
                                          @rafb sounds like you need to make it wider so that it definitely blocks the IR on the Endstops sitches
                                          • RafBundefined
                                            RafB @synergy41
                                            @synergy41 Ça m’a fait tilt quand tu as mis le lien les imprimantes 3D.
                                            Je pense pas que le problème vienne Du réglage de la mécanique. J’ai tout réglé au pied à coulisse. Je vais l’installer micromètre À la place du hotend Et vérifier la planéité du plateau. Si tout est parfaitement plat, je ferai une vidéo et demanderai de l’aide à dc 42 pour comprendre d’où vient le problème. Qu’en penses-tu as-tu d’autres propositions?
