    Too much layer shifting
    32
    7.5k
      Thanks for the info. One other question: what travel speed do you have configured in your slicer?
      • Huguesundefined
        Hugues
        300mm/s for travel speed
        145 mm/s for infill and shell 50% for outline
        • dvmourikundefined
          dvmourik
          I had the same issues with the 1.15 and higher. Yesterday even tried the 1.16beta5 but still this problem exists.
          Will keep mine on 1.14 as it runs very smooth on this version.
          DC42 if you need more development info please let me know. Can make a report or something for you if you would like.
          It's not my first delta (build around 250 delta's now… ) so maybe i can help a bit.
          Bigger and bigger… sky is the limit.
          • dvmourikundefined
            dvmourik
            Strange enough i uploaded on my testprinter 1.16beta10 and first test was ok. Not the speeds that i used to but ok in printing. Anything changed on stepper/motion part?
              Nothing changed in the stepper motor driver code in either 1.15 or 1.16. There was a bug fix to pressure advance in 1.15.
              Can you confirm that you are using the on-board stepper drivers?
                deckingman
                IMO, layer shifting is always due to some mechanical problem - especially when it's as bad as the pics in the first post. Have you checked that the pulleys are securely fixed to the motor shaft?
                • Huguesundefined
                  Hugues
                  Those shifting in first post was not due to mechanical, otherwise it will not append strictly at the same height…
                  I've made few test without stepper interpolation and it seem to work better, i didn't have shifting since removing it. But this result have to be validate with real comparaison test...
                  • DjDemonDundefined
                    DjDemonD
                    It can be mechanical i.e. a print bed not properly secured so that it moves laterally my mini kossel does this as the bed mounts I made for FSR's are not clamps so the bed can shift it its not properly inserted, or electrical i.e. a motor skipping steps due to insufficient current, or being asked to move faster than it is able (i.e. insufficient current).
                    www.precisionpiezo.co.uk
                    • dvmourikundefined
                      dvmourik
                      I am using the onboard drivers in this model. Nothing hardware related because changing the board will make it print flawless.
                      Sadly i was using pressure advance and this last print i removed it.
                      But i don't want to hijack this thread. So we keep it to the shifting of the topic owner.
                      • Huguesundefined
                        Hugues
                        @Djdemon i monitored the print and there was not mechanical, nothing move like bed shifting. It's more like the board forget few step
                          deckingman
                          @cubexupgrade:
                          But it only affects one motor, hence the 45 degree angle of shift (corexy). Loose wire? Bad motor? Can you swap the XY motors and see if the shift then happens in the other direction? Looking at all the stringing at the bottom of the model, are you sure the nozzle didn't catch on a lump of plastic which either shifted something mechanically, caused the pulley to slip, or caused the motor to skip a few steps?
                          @DC42, does interpolation affect motor torque? Just wondering if there is a mechanical resistance to movement, might a motor be more likely to skip steps with interpolation enabled.
                            Interpolation will have only a tiny effect on motor torque. Maximum torque is produced when the motor is nearly 2 full steps behind the commanded position. A few 1/256 steps either way isn't going to make much difference.
                            @cubexupgrade, are the two motors of the same type and definitely running at the same current? If you are using M584 to remap drivers, you should specify the mappings for all axes and extruders, and set the motor currents afterwards.
                            • Huguesundefined
                              Hugues
                              @dc42 motors and current are the same. I haven't use motor mapping for this printer.
                              Since i deactivate interpolation i use pressure advance function without problem even with high accl/jerk. Maybe it's just hasard.
                              I do not push test because i've to print lot of stuff for works.
                              • Phil Maddoxundefined
                                Phil Maddox
                                Hi all
                                Was this issue ever resolved ?? Im having similar problems ( 1,5 & 1.16)
                                Prusa i3 steel Cartesian . Works fine with a ramps 1.4 with TMC 2100's
                                Doesn't always happen.
                                Doesn't happen at the same height
                                When it occurs its X and Y at the same time but not by the same amount.
                                Checked all the usual suspects but as yet no real culprit to be found
                                All help / input appreciatted
                                • Sniffleundefined
                                  Sniffle
                                  scientifically(one test print at a time), try reducing or eliminating your pressure advance first, then lowering your accel and jerk settings to what would be a more "normal(i3)" level.
                                  I eliminated my layer shifting by greatly reducing my accel and jerk settings and there has been mention of potential issues with to many steps being generated on circular moves from pressure advance that can cause steps to be lost, though i think this was also squashed or its impact reduced.
                                    Phil Maddox
                                    Thanks ill certainly try that
                                    Whats wierd is in the 2 months or so that ive been using the Duet Wifi its worked fantastically well on large and small prints alike . Just this past week or so ive had problems.
                                    I'm not 100% convinced it the Duet Wifi but with all the usual suspects checked and double checked, i'm at a bit of a loss as to whats going on.
                                    The only thing that has actually changed that i know of is ive upgraded to Simplfy 3D 3.1.1 but i cant really see how that would create this issue.
                                    Maybe i should try another slicer to be sure.
                                      T3P3Tony administrators
                                      Sometimes layer shifting is caused by slipping pulleys at high speed acceleration.
                                      • capundefined
                                        cap
                                        one thing i noticed sorry no tech guy here but are any of the motor wires crossing are touching as this coursed me problems
                                        warning brain may explode
                                          Phil Maddox
                                          @T3P3Tony:
                                          Would seem odd that both X & Y slipped at the same point in time/ the print and only once per print
                                          Already checked them and am 100% sure they are super tight.
                                            Phil Maddox
                                            @cap:
                                            Im confident the wiring is not the issue
